post pics of your modified 3rd gens
lets see them. i dont mean shift ***** and steering wheels. i want to see that im not the only one willing to really custom/ modify my 3rd gens exterior/ interior. i went to 2 car shows this week and every 3rd gen looked exactly the same.
heres a before/after of the front view:
before rear:
as of right now:
interior before (i added the seats and pillar gauges):
interior after:
trunk before:
trunk after:
engine bay before:
engine bay after:
before rear:
as of right now:
interior after:
trunk before:
trunk after:
engine bay before:
engine bay after:
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: post pics of your modified 3rd gens
yeah no offense but it just looks hacked up now, the straight cut "notches" you have implemented everwhere just look like some guy without much fab skill got a saw out and made some cuts, then repaired it all with flat sheets of material.
I do a fair amount of glass work, it would not be hard to finish you ideas out to look ok if your willing to put in the time
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
your car not being done yet does not change my opinion or nayone elses
this site is full of modified third gens, nearly every pictue on here is a
pic of a "modified third gen"
Car: 89 formula
Transmission: t5
Axle/Gears: open junk
Dont listen to those ******. I think its a great project your building. Who gives a rats a$$ if its not what they like. Your putting lots of time and effort into it, and when its done you'll be able to stand back, look at it and enjoy what you have created. It will definetly be a show stopper once its done, and if people dont like it, then tell them where to go!
Car: 1984 Camaro Z28 H.O.
Engine: 5.0 H.O.
Transmission: Automatic
Axle/Gears: unknown at this point
I'm an old goat, traditional kind of guy... but I say "Good for you"! "Go for it"!!
David
David
Car: 88 GTA/86 C20 Burb/91 325i
Engine: L98/454/M20
Transmission: 700R4/NV4500/Getrag
Axle/Gears: 3.27 9-bolt/3.73 14 Bolt/3.73 IRS
I'm actually really interested to see how this turns out. It could go either way, but with the proper paint and body work, you might really come out with something cool.
1982 trans am, full tubular suspension, custom subframe conn., vogtland springs, bilsteins, j&m CC plates, Fluidyne monster radiator, C6Z06 brakes, fays2 watts linkage, T56, 3" aluminum drive shaft, monster billet flywheel & clutch, tick clutch master, recaro sportster cs seats, 495 lxs w/ modified LS7 heads, front drive distributor, custom headers & exhaust (under construction)
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
It's a mockup LS1 and it had a batwing on it that made it hard to put the engine in.
COTM Editor
Get some paint on there man. I wanna see how it all looks.
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Been very busy myself, working on my car every day. Not much time to play with the computer. Will put some pictures up as soon as I feel like doing it'
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
Been seeing the work on this thing on facebook, and gotta say its looking sweet
Car: 1987 Trans Am
Engine: 355 tpi
Transmission: 5 speed
very interesting thread, I almost missed it being in the camaros section as I don't really look in it much. I'm always interested in any modification of this kind. Maybe this thread should be moved out of members camaros section and put in the main auto detailing and appearance area, since this is for modified 3rd gens. This way those who have firebirds who don't come into this section may view and contribute.
And nice cars so far.
Car: 1999 Formula Hardtop
Engine: 6.2 forged ls3 Procharged
Transmission: t56 Magnum
Axle/Gears: midwest chassis fab 9/3.50
first posted ****ed that car right up . Why use a shitty tunnel ram . The tech is old and outdated and not good, Why use a cog belt setup also . Dash looks worse . Just burn it man . riced out 3rd gen .
Car: 87 iroc-z
Engine: 454
Transmission: th350
Car: 1987 Trans Am
Engine: 355 tpi
There is nothing wrong with a tunnel ram setup with duel carbs, It looks cool plane and simple, and if tuned right works great. I don't know why the OP is running a cog set up but I do know it sounds like there is a blower under under the hood. That's just an old hot rodders trick.
But if you are just going to bash someones work, someone vision you really don't belong here, Just because it's not your taste, Maybe you can't do this kind of work so all you can do is bash someones work instead of seeing the skill, the hard work and imagination it takes to do this kind of work. It is sad to think what kind of person bashes someone work like you did.
Car: 1988 IROC
Axle/Gears: 3:27 9-bolt
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
If all goes well, should be running by next week. Recently swapped in a 350 to replace the blown-up LB9. Low rise spoiler soon.
Car: 1991 Camaro Z28
Car: 1987 Camaro Z28, 1989 TTA #922
Engine: lb9, 3.8L turbo
Transmission: 700r4, 2004R
Hmmm surprised that more people haven't posted their modded third gens
Car: 1991 Z-28/ '94 Impala SS
Engine: 355 TPI/ 350 LT-1
Transmission: T-56 in both
Axle/Gears: 3.73 / 4.56
Car: 1986 Camaro Z28
Engine: 385" SBC
Transmission: built out 700r4
Axle/Gears: 4th gen, 373, LSD, GIRDLE
That red Camaro FTW! Realmac4 It seems you like that color?
Has this car won COTM yet? If not I think someone deserves a nomination
Last edited by 11ellswray; Jul 11, 2013 at 08:30 AM. Reason: Car was worth more than my original post
And the GP got traded in on a 201 WHITE Malibu, so we mixed it up a little, and added a 94 Black Impy SS as well
Car: 1989 IROC-Z Camaro 'Vert.
Engine: 350, ZZ4 motor
Transmission: TH-700R4
Axle/Gears: 2.73 ... for now.
That's awesome dude.
Lot's of pretty nice cars in here so far. Not sure about OP's, his future choice of paint could turn me either way on it.
Its going to be a light metallic gold. The camaros going through another exterior upgrade. A lot of people are judging way to early on my build. I haven't had time to finish the fiberglass work.
Car: 92 Camaro Rs.R
Transmission: wc t-5
[img]
[img]
I'm in love
:: ENGINE::
GM performance Crate Engine 350CID
Edelbrock RPM intake
Holley 600CFM Dual pump carburator
High Volume Water pump
Holley 90LPH Fuel pump
Moroso Dual chrome fuel bar
MSD Ignition
Tailor 8MM spark plug wires
K/N oil filter
Spektre breather
Spektre Open air element filter
Moroso pipe plug fittings
Mr Gasket oil Stick
AC Delco 120A Alternator
Champion 3 pass crossloop aluminium radiator
Dual thermostatic electric Fans
:: Exaust ::
Hookers headers
Custom Y pipe
Dynomax complete line
Dynomax super turbo muffler
3'' longtubes
Moroso bolts
:: Transmision ::
Rebuilt TH700R4
Mild shiftkit
HD drum
Kevlar Sonnax band
New oil pump
TCI 2800 STALL
TCI Lightweight Flexplate
ARP 180k Studs
:: Suspension ::
Complet FULL Urethane bushing kit
Tokico gaz suspension
Eibach prokit 1'' Drop
Big sway bar remplacement
Ajustable panhard bar
:: Differencial ::
2008 GM 2500HD LSD Carrier
3.73 gears
:: Brakes system ::
Cross drilled disks
Ceramic pads
Everyting redone brand new
:: Wheels ::
Cragars SOFT 8 4'' backspacing
8'' front / 245-45r17
9'' rear / 275-40/r17
2degres front camber
Custom allignement.
:: Interior ::
Noname Temp/volts/oils pressure gauges
Pioneer head unit
Infinity Kappa / Signature speakers
Shaved steering wheel
Used carpets lol
:: Exterior ::
New paint
New floors
New lips
Goodmark 4'' cowl hood
Clears front / side flashers
Black Camaro gril
All new Z-28 emblems
No wipers lol
MSD Ignition
K/N oil filter
Spektre breather
Mr Gasket oil Stick
:: Exaust ::
Hookers headers
Custom Y pipe
3'' longtubes
Moroso bolts
:: Transmision ::
Rebuilt TH700R4
Mild shiftkit
HD drum
Kevlar Sonnax band
New oil pump
TCI 2800 STALL
ARP 180k Studs
:: Suspension ::
:: Differencial ::
3.73 gears
:: Brakes system ::
Cross drilled disks
Ceramic pads
:: Wheels ::
Custom allignement.
:: Interior ::
Pioneer head unit
Used carpets lol
:: Exterior ::
New paint
New floors
New lips
Black Camaro gril
No wipers lol
