My build for the 3rd time, long story of the Orange Iroc
Old Apr 12, 2013 | 11:44 AM
  #51
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: My build for the 3rd time, long story of the Orange Iroc
Originally Posted by DiabolicalRS
holy sh** man, your car looks good way better than my beater lol what products do you wash with?
I haven't washed in in about 2 years. I use Eagle One stuff though.
Its actually pretty dusty.
Thanks for the complement!
Old Apr 12, 2013 | 12:03 PM
  #52
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Oh no. The clearances are set to .0025, rods and mains. The tolerance(roundness and runout) is .0001. In other words, the clearances are to within .0001 of a perfect .0025.
.0025 is a large clearance for use with 40 weight or 20w-50 racing oils and a high volume pump like the Melling.
Old Apr 12, 2013 | 12:15 PM
  #53
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
The Melling P/N of the pump I've used in several engines is 10555. It's a high volume(25% over stock) high pressure pump that accepts a bolt on, 3/4" pick up tube. It comes with an 80psi relief spring installed.
Old Apr 12, 2013 | 12:18 PM
  #54
Car: 1971 Camaro
Engine: 427
Thats what I thought you meant. Thanks.
I used a stock replacement Melling. Not a fan of High Volume pumps. I typically run
10w30.
Old Apr 12, 2013 | 01:13 PM
  #55
Car: 1971 Camaro
Engine: 427
Ordered some slotted rotors for the rear, aluminum hub centric rings for my wheels, and some custom alternator and power steering brackets today.
Underhood almost totally bare metal throughout now, will prime and paint it soon!
Having second thoughts about all the polished aluminum on the engine. My original plan was cast aluminum, but got such a deal on all the polished stuff. Polished will be a pain to keep clean on a daily driver.
Thoughts,
Polished will probably look good with the bright orange paint around it.
Maybe I'll just clear coat it
or Have it all powdercoated silver?
The parts that are polished include;
SLP Runners, Upper Plenum. Valve covers, valve cover breathers, and Timing cover.
What do you guys think?
Old Apr 12, 2013 | 01:20 PM
  #56
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
I think the polished will be fine if you keep it clean and coated with wax or some other sealer. I wash my underhood every time I wash the body. I use the hot wax at the car wash to coat the motor after cleaning. Then, I spray it down with Black Magic protectant and wipe it down. Anything to keep the aluminum coated. My polished valve covers have kept their shine and my cast plenum and base haven't oxidized like so many I've seen.
Old Apr 12, 2013 | 01:23 PM
  #57
Car: 1971 Camaro
Engine: 427
Sounds good.
Old Apr 16, 2013 | 12:07 PM
  #58
Car: 1971 Camaro
Engine: 427
No exciting pics to show progress yet, but I have made a good bit.
Underhood area stripped bare, ready to paint, removed the panhard brace and heat shields so I can drop the tank, to swap in a walbro pump, and patch the access hole cut by po.
Waiting on some parts still.
Hope to get underhood painted this weekend so I can begin some reassembly.
Removed the auto pedals so I can install my 5 speed pedals.
Old Apr 16, 2013 | 12:12 PM
  #59
Car: 1971 Camaro
Engine: 427
Have an edelbrock strut tower brace on the way too. Probably going to get a founders panhard relocator while I'm down there.
Got some POR15 and topcoat coming to hit the underside of the car as well.
Old Apr 18, 2013 | 06:13 AM
  #60
Car: 1971 Camaro
Engine: 427
Using mr gasket 146 tpi gaskets as a templete you can see how much porting the slp runners need.
This is the stock base,
lower part of slp runners,
upper part of slp runners
upper plenum
Old Apr 18, 2013 | 09:32 AM
  #61
ImBrandon's Avatar
Car: 1991 Pontiac Trans Am
Axle/Gears: 3:42
Nice, this motivates me after having my firebirds transrmission blow up twice only after driving it 130 miles since I bought it 13 months ago. Rebuilt my 700r4 twice costing around me 1500$. Once being from wear and tear and traces of water causing the inevitable; the second time 30 miles later my valvebody gunked up and smoked everything. Just finished putting it in two days ago after being shipped the wrong replacement valvebody and not being refunded or swapped for the correct one. Sucks seeing it on jack stands for 10 months out of 13 I've owned it.
Old Apr 18, 2013 | 10:35 AM
  #62
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Awesome build! Glad to see you still have it and finally getting it back together! Do you have any more details on the wheels? They look good!
Old Apr 18, 2013 | 11:01 AM
  #63
Car: 1971 Camaro
Engine: 427
Wheels are stern hypermesh II. Fronts are 18"x8.5" rears are 18"x9.5". Going to blast them and may keep the centers cast, and polish the rims. We'll see.
Old Apr 18, 2013 | 03:18 PM
  #64
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
this is a good looking build man. I am subscibing
Old Apr 19, 2013 | 05:19 PM
  #65
Car: 1971 Camaro
Engine: 427
Aluminum driveshaft from a 4th gen came today via Cleveland pull
a part.
Nice!
Old Apr 20, 2013 | 11:37 PM
  #66
Lmancha96's Avatar
Car: 1992 Camaro (Z28 Clone)
Engine: LB9|TPI
I have always seen you around the board and always wondered what was up with the car in your avatar... Now I know...
Keep it up man, cant wait to see this build finished..
Old Apr 21, 2013 | 05:13 PM
  #67
Car: 1971 Camaro
Engine: 427
Porting intake
Old Apr 21, 2013 | 05:22 PM
  #68
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Looking good , Ill send you one to practice on and send back lol
Old Apr 21, 2013 | 05:32 PM
  #69
Car: 1971 Camaro
Engine: 427
There's a lot of meat to take out of that base!
I'm suprised how much you can open them up, should make quite an improvement.
Old Apr 21, 2013 | 05:40 PM
  #70
Car: 1971 Camaro
Engine: 427
Old Apr 21, 2013 | 05:43 PM
  #71
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
What is that hole in the runner?
Old Apr 21, 2013 | 05:46 PM
  #72
Car: 1971 Camaro
Engine: 427
Still trying to decide on the enginebay detail work.
Polished or cast color aluminum?
Gloss black or semigloss black other part? brackets, stb, strut plates, heater box, brake booster, etc....
Kinda think the bright orange would go well with other bright parts. But then again, I think the low gloss and cast would be a good contrast.
Old Apr 21, 2013 | 05:47 PM
  #73
Engine: Lb9
Transmission: M20
The egr passage ?
Old Apr 21, 2013 | 05:57 PM
  #74
Car: 1971 Camaro
Engine: 427
The egr passage ?
That's what I thought.
Old Apr 21, 2013 | 07:31 PM
  #75
Car: 1971 Camaro
Engine: 427
After a little more work and some finer grit.
Old Apr 22, 2013 | 09:19 AM
  #76
Car: 1971 Camaro
Engine: 427
Just about ready for paint.
Old Apr 24, 2013 | 08:07 AM
  #77
Car: 1971 Camaro
Engine: 427
Ordered a 9 bolt aluminum Rear cover today, as well as a Founders Panhard relocator.
Should be painting the under body and underhood soon, then I can begin reassembly.
Went ahead and started stripping the floors to bare metal. I POR 15'd it when I got the car years ago, but I did not do a good job and it did not hold up in some places.
Sanding it all back to bare, will prep well, and por 15 it again, this time I will also apply a POR 15 top coat.
Engine bay will get Epoxy primer/sealer, and a coat of Orange, had a quart mixed up the other day.
Decided to paint the engine block and heads Gloss Black, and the rest of the underhood items will get Black Pearl. Should look pretty good.
Had to order more sanding rolls to finish porting. I picked up some from Harbor Freight but they did not last long enough to make the price savings really a savings. So I ordered more from Eastwood. They last much longer.
Old Apr 24, 2013 | 07:27 PM
  #78
Car: 1971 Camaro
Engine: 427
Slotted rear rotor.
Old Apr 26, 2013 | 09:15 AM
  #79
Car: 1971 Camaro
Engine: 427
Ups man just dropped this off!
Old Apr 26, 2013 | 10:52 AM
  #80
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
Nice, progress is looking good. Great port work on the intake!
Have that girdle waiting for my rear a well, adds some attitude (and support of course)!
Old Apr 26, 2013 | 11:14 AM
  #81
Car: 1971 Camaro
Engine: 427
Thanks!
I actually burned up my harbor freight drill last night while working on the intake.
Ordered 100 sanding rolls, to finish the rest
Old Apr 27, 2013 | 09:45 AM
  #82
Ed1LE's Avatar
Engine: 5.7, 5.0
That's the beauty of Harbor Freight, burn one up, go get another for like $15!
Old Apr 28, 2013 | 02:44 PM
  #83
Car: 1971 Camaro
Engine: 427
Ordered complete hard brake lines and fuel lines from my favorite tube supplier, Inline Tube.
Old Apr 30, 2013 | 09:44 AM
  #84
Car: 1971 Camaro
Engine: 427
Took burned up Drill back to Harbor Freight, no recipt so the lady said
" I can return it this time, but you have to buy a warrenty" So, for $9.99 I got a new drill and a 2 year warrenty.
Just in time too, my sanding rolls from Eastwood showed up today.
Paint should be flying soon, and reassembly will begin!
Old Apr 30, 2013 | 11:36 AM
  #85
Car: 1971 Camaro
Engine: 427
I'm thinking it needs some IROC decals on the doors again. Thoughts? Color?
Old May 1, 2013 | 10:59 AM
  #86
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
I agree! Black maybe?
Old May 2, 2013 | 09:16 AM
  #87
Car: 1971 Camaro
Engine: 427
Founders Panhard Relocator came yesterday. Very nice.
MSD box I got from a member came yesterday too, not so nice. Waiting on member to respond before I post up, but looks like I am being ignored. Initial Text message replied to very quickly, now no reply.
Old May 2, 2013 | 09:48 AM
  #88
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
just wanted to say i like your car Johnny. the orange color looks awesome! id like seeing a few more shots of the ghost stripes if you get time one day. it might look good if you could get the same ghost color iroc decals or airbrushing? your car is coming along nice. what color are you doing the engine bay? nice job on the port work. a carbide bit will make short work of cutting.
Old May 2, 2013 | 09:51 AM
  #89
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
something like this for initial cuts.
http://drillsandcutters.com/dulsb3nf...FQpN4AodiGgA6w
Old May 2, 2013 | 09:56 AM
  #90
Car: 1971 Camaro
Engine: 427
Yeah, I am using carbide for knocking down a lot of the meat, then sanding rolls for finish work.
I have thought about the ghost for the ioroc letters as well.
Engine bay is getting matched in orange. Other stuff will be satin black.
Old May 2, 2013 | 10:01 AM
  #91
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
awesome! thats gonna look great! looking forward to some pics of your progress.
Old May 2, 2013 | 10:30 AM
  #92
Car: 1971 Camaro
Engine: 427
Thanks!
I have gone back and forth with the color. HAve been tempted to go back to factory bright red.
Old May 2, 2013 | 11:34 AM
  #93
Car: 91 Trans Am
Engine: 355 TPI
I second this
Old May 3, 2013 | 11:42 AM
  #94
Car: 1971 Camaro
Engine: 427
New brake lines and main furl lubes came today!
Old May 6, 2013 | 07:12 PM
  #95
Car: 1971 Camaro
Engine: 427
I think I've ground enough aluminum off this intake to melt down and cast a single plane intake with!
Here is today's shavings.
Old May 6, 2013 | 07:14 PM
  #96
Car: 1971 Camaro
Engine: 427
Also, got my tank filled for the welder today, andcstarted welding up seams under the hood.
Soon realized I was way out of practice welding!
Going to weld up all the seams on the inner fenders and firewall, just for the heck of it.
Old May 6, 2013 | 07:15 PM
  #97
Engine: Lb9
Transmission: M20
That's will shave some weight off your car lol
Old May 6, 2013 | 07:38 PM
  #98
Car: 1971 Camaro
Engine: 427
Yeah, probably shave 2lbs off the carcao far!
Weld?Name:  5fc871b30c88f189add50bd235070b0d_zpse1b0245b.jpg
Old May 7, 2013 | 09:45 AM
  #99
rwstegne's Avatar
Car: 1989 Iroc Z 5.7L
Engine: 5.7L
Axle/Gears: built 4.10s
What head gasket, intake manifold gasket, head bolts and intake bolts are you going to use? What headers are you going to run?
I am in the process of fixing a bad head gasket and interested in the parts you are using.
Old May 7, 2013 | 09:53 AM
  #100
Car: 1971 Camaro
Engine: 427
Head gasket Fel Pro 1094
Intake Gasket Felpro 1204 or maybe 1205. Got to see if the intake has enough meat to port to a 1205.
Headers are Hedman Shorties.
