My build for the 3rd time, long story of the Orange Iroc
Old May 7, 2013 | 10:51 AM
  #101
rwstegne's Avatar
Car: 1989 Iroc Z 5.7L
Engine: 5.7L
Axle/Gears: built 4.10s
Re: My build for the 3rd time, long story of the Orange Iroc
What is the bore on your block?
Do you like the hedman shorties? I am considering purchasing the 68470 and y-pipe 17478.
Old May 7, 2013 | 10:55 AM
  #102
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
.030" overbore 350 block.
I had the Hedman 68470 on my car before, with the matching y pipe. Very happy with them, so I got them again.
If I had more cash I would have gotten Dyno Dons for sure though.
Old May 7, 2013 | 10:58 AM
  #103
Car: 1971 Camaro
Engine: 427
That Y pipe will not work with 68470.
You need Y pipe 17470.
Old May 7, 2013 | 11:56 AM
  #104
hrspwr's Avatar
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
What is the purpose of welding the seams?
Old May 7, 2013 | 12:00 PM
  #105
Car: 1971 Camaro
Engine: 427
Increased chassis strength, in theory.
Old May 7, 2013 | 02:47 PM
  #106
rwstegne's Avatar
Engine: 5.7L
When replacing my head gasket, can the head bolts be reuse? I have heard yes and no. What are you doing on your build?
Old May 7, 2013 | 02:49 PM
  #107
Car: 1971 Camaro
Engine: 427
Depends on the engine. For a typical sbc yes.
I am using New Jegs Brand Head bolts.
Old May 7, 2013 | 03:10 PM
  #108
rwstegne's Avatar
Engine: 5.7L
These "JEGS Performance Products 83400 - JEGS Head Bolt Kits"?
Old May 7, 2013 | 04:40 PM
  #109
Car: 1971 Camaro
Engine: 427
Those are The ones.
Old May 7, 2013 | 06:02 PM
  #110
rwstegne's Avatar
Engine: 5.7L
so which to choose
Head gaskets : Fel Pro 1094 or Chevrolet Performance 10105117
Intake gaskets : Felpro 1204 or Chevrolet Performance 10159409
Old May 7, 2013 | 06:05 PM
  #111
Car: 1971 Camaro
Engine: 427
I like fel pro
Old May 8, 2013 | 08:43 AM
  #112
Car: 1971 Camaro
Engine: 427
NuffNuff has got me thinking hard about getting a set of the Race Star 17x9.5"s
They are about 14lbs lighter per wheel then may sterns. The 17" tires would be cheaper as well.
Of course that leasves me with a set of modified Stern wheels that I probably can't get much out of.
Anyone want some 18' sterns?
Old May 8, 2013 | 08:55 AM
  #113
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
2nd set of wheels? I think those racestars will look great on your car. I'll probably order mine from him today.
Old May 8, 2013 | 04:32 PM
  #114
Car: 1971 Camaro
Engine: 427
Ordered 4 17"x9.5" race stars!
Gonna strip the gold paint off the sterns, clean them up and put them up for sale.
Anyone interested?
Old May 8, 2013 | 04:37 PM
  #115
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Can't wait to see the pictures!
Old May 8, 2013 | 05:29 PM
  #116
Car: 1971 Camaro
Engine: 427
Those wheels are gonna make me do a brake upgrade sooner! I have some c5 calipers sitting on the shelf.
Old May 11, 2013 | 10:22 AM
  #117
rwstegne's Avatar
Engine: 5.7L
Originally Posted by Johnny Blaze
Head gasket Fel Pro 1094
Intake Gasket Felpro 1204 or maybe 1205. Got to see if the intake has enough meat to port to a 1205.
Headers are Hedman Shorties.
Question, the 1094 is a thin gasket, are you getting the block and heads shaved?
If not, how much variance is allowed with that head gasket?
Old May 11, 2013 | 01:39 PM
  #118
Car: 1971 Camaro
Engine: 427
Heads have been milled flat, chambers cc out to 64cc.
Block was decked as well.
Will measure again when rotating assembley gets back from machine shop, though I expect the pistons to be in the hole a little, so that gasket should get me close to ideal quench.
Old May 13, 2013 | 03:07 PM
  #119
Car: 1971 Camaro
Engine: 427
New wheels came today!
fronts clear tie rod.
Old May 13, 2013 | 03:17 PM
  #120
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
They look GREAT man. I'm glad you're happy with them!
Old May 13, 2013 | 04:02 PM
  #121
Ed1LE's Avatar
Engine: 5.7, 5.0
Look awesome, mine will be here tomorrow.
Old May 14, 2013 | 10:56 AM
  #122
Car: 1971 Camaro
Engine: 427
Been practicing welding, getting back in the hang of it.
Welded my Founders bolt on lcab's.
Also welded the cowl plate for my edelbrock stb to the cowl. Probably pointless, but what the heck!
Also welded a patch in the floor where a po cut an "access hole" for the fuel pump. Will
post pics.
Been working on the slp runners. Shaving a lot of aluminum out of them as well.
Old May 18, 2013 | 09:17 PM
  #123
Car: 1971 Camaro
Engine: 427
Not much to update on the iroc, spent last two days working on the daily drivers brake.
Had to replace master cylinder, went to bleed brakes, pass rear bleeder rounded off. Drivers rear would loosen, but Jo fluid would come out, yet brake worked.
Drivers drum would not come off for anything. A lot of pb blaster, prying, beating and a torch finally removed it.
Swapped both wheel cylinders, did sone bleeding.
Drivers front bleeder, rounded off.
Picking up a new caliper tommorrow.
Gotta love working on a 42 year old on restored car!
Old May 19, 2013 | 09:09 AM
  #124
Car: 1971 Camaro
Engine: 427
Parts is parts!
Gotta love ordering parts!
Today I ordered,
poly bump stops for the rear.
Hawks HPS pads for the rear to match my fronts
long wheel studs for all four corners
a 3" single in single out Dyno Max Ultraflow muffler.
A3" maderal j bend to make my tailpipe.
I am not a fan of crossflow mufflers, so I went with a high flow single in and out and will tuna single tailpipe turned down behind the bumper like the mufflex system.
Also ordered 1205 intake gaskets to see if I can open the stock intake that much.
Off work the next 2 days, so hopefully I can get some work done.
Machine shop is dragging their feet with my assembly, but that's ok, I have plenty to keep me busy in the mean time.
Probably going to get done 275/40/17 BFG's this week as well.
Can't wait to see it as a roller again!
Old May 19, 2013 | 09:24 AM
  #125
LivinLarge's Avatar
Dam those wheels look badass on you car!! What size tires are you going to run?
Old May 19, 2013 | 09:37 AM
  #126
Car: 1971 Camaro
Engine: 427
Thanks! Going with 275/40/17 in all 4 corners.
Old May 20, 2013 | 10:42 PM
  #127
TBRays98's Avatar
Car: 1989 Formula
Axle/Gears: 3.45 1LE Disc LSD
Awesome build i'm all caught up now. BTW im trying to build the same type of engine. I have my 350 torn apart. I am getting the block and stock heads machined real soon. Even with stock heads and a manifold would you recommend that same cam? Just want the same good economy and some pep
Thanks!!
Old May 21, 2013 | 06:04 AM
  #128
Car: 1971 Camaro
Engine: 427
I would probably go with the 500 cam with stock ports. That's actually the cam vomp suggested, I went one size bigger.
I am having trouble finding a timing tab.
I went with a jegs balancer, a 6 1/4" diameter, based in them listing it as the proper one for a late model block.
Anyone see any issues using a tab for a 6 3/4" one?
On another note, got the brakes working on my daily driver again!
Old May 22, 2013 | 07:28 PM
  #129
Car: 1971 Camaro
Engine: 427
Got some 1205 intake gaskets and have been working on matching the base to them.
Old May 27, 2013 | 12:14 PM
  #130
Car: 1971 Camaro
Engine: 427
Rear end, stripped, one coat of Por 15, two coats primer sealer, two coats gloss black, two coats clear.
New brake lines from inline tube.
Carrier caps machined for cover, bolts replaced with ARP studs.
Rear cover torqued to spec.
Got to install new longer wheel studs.
Old May 31, 2013 | 05:02 PM
  #131
Car: 1971 Camaro
Engine: 427
Rebuilt capliers installed!
Rear is ready for install, but the body is not ready for it.
Took the panhard bar, lca's, torque arm, strut plates, and other random parts and painted them semi gloss black.
Machine shop called today, block is preped, and rotating assembly is balanced.
Probably pick it up Monday.
Now I need to get moving on painting the underside.
I have pretty much all the parts to start assembling the engine and the rest of the car.
Old May 31, 2013 | 06:17 PM
  #132
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
man, your car is coming along real nice. really like the rims alot! the rear looks tight! glad to see somebody taking they're time and doing a good job.
Old Jun 3, 2013 | 02:16 PM
  #133
Car: 1971 Camaro
Engine: 427
Just picked up thr block and rotating assembly from thr machine shop.
Ready to assemble!
Got this coming weekend off, should be able to make sone real progress!
Pics to come.
Old Jun 4, 2013 | 08:15 AM
  #134
KFCCASEY's Avatar
Car: '92 Camaro
Engine: 305 HO
Transmission: N/A
Axle/Gears: N/A
Trying not to go black, tend to lose some of the detail off the wheel when it's black. May go dark though.
First test was vintage racing gold.
Thought?
What wheels are those?!
Old Jun 4, 2013 | 09:05 AM
  #135
Car: 1971 Camaro
Engine: 427
Those are Stern Hypermesh II.
I just sold them for $300 plus shipping.
Old Jun 4, 2013 | 10:13 AM
  #136
Car: 1971 Camaro
Engine: 427
Got the Block painted last night.
Should have short block assembled by the weekend.
Old Jun 4, 2013 | 05:47 PM
  #137
Car: 1971 Camaro
Engine: 427
Mock up.
As you can tell they had to remove a lot of material from the rear of the crank.
some pistons needed a good bit removed too.
Old Jun 4, 2013 | 06:29 PM
  #138
cHEVy hEAVy's Avatar
Car: 1989 IROC Z
Engine: 5.0 tpi. stock [for now]
Subscribed! Sweeet car bro!
Old Jun 5, 2013 | 08:54 AM
  #139
rwstegne's Avatar
Engine: 5.7L
Looks great! I am jealous! Can't wait to hear about your results/MPGs !
Old Jun 5, 2013 | 09:33 AM
  #140
Car: 1971 Camaro
Engine: 427
I can't wait either!
So, here's the details.
The Block had been bored when I got it. So, I had the Machine shop hot tank it again, ad Brass Freeze plugs and Dura Bond Cam Bearings.
The Did a light hone to the cylinders due to it sitting so long. Also honed the Lifter Bores.
The Rods were new, but had no name bolts, so I had ARP Wave Lock bolts installed, and had the rods resized. The Also pressed on the New Speed Pro pistions.
The Crank is a New Eagle cast, and as you can see, they took a lot out of it to balance it.
The rotating assembly was fully balanced.
I cleaned the block and chased all the bolt holes.
Wiped it down with wax and grease remover (just the surfaces to be painted)
Masked the block off, put 3 coats of VHT Eangine Paint Primer on it, followed by 3 coats of VHT Gloss Black, and last 2 coats of VHT Clear.
As you can see, studs are installed for the oil pan and timing cover.
New ARP Main bolts are being used as well.
Going to mock it up to check clearances, and should have the shortblock buttoned up by the weekend.
Old Jun 6, 2013 | 12:38 PM
  #141
Car: 1971 Camaro
Engine: 427
Just picked up my Camshaft from the MAchine shop. Due to some recent issues with Comp Cams, I had them Polish the journals on it to make surre it doesn't wipe out my bearings.
Should get the shortblock assembled this weekend, and hopefull get the under hood and floor painted as well.
Old Jun 8, 2013 | 06:33 PM
  #142
Car: 1971 Camaro
Engine: 427
Shortblock blueprinted and assembled!
rear axle ready to roll under body!
Progress!!
Old Jun 8, 2013 | 06:42 PM
  #143
rwstegne's Avatar
Engine: 5.7L
what did you torque your heads and intake too ?
Did you go with the 68 lb ft on the jeg bolts ?
Old Jun 8, 2013 | 06:59 PM
  #144
Car: 1971 Camaro
Engine: 427
Quench is gonna be a little tight, .035". Compression cones out to 10.29:1
Guess I'll be running 92 octane!
It's that or thicker headgaskets, which would drop the compression to 9.73:1 and quench at a poor .059"!
Old Jun 8, 2013 | 07:02 PM
  #145
Car: 1971 Camaro
Engine: 427
Heads are not yet installed.
Old Jun 11, 2013 | 04:30 PM
  #146
Car: 1971 Camaro
Engine: 427
So turns out the timing cover would not work. Would not allow oil pan to sit flat.
I have seen many timing covers are listed for up to '86 engines. I could not find any that listed for later models.
So I saw Canton Racing had a cover, but it did not list years, so I emailed them. Withen an hour I had a reply stating it fit the 1 piece rear main blocks!
A click later and I have a cover coming. It's steel, and gold, like their pans, and just as nice, I'm sure. I'd like to run one of their pans, but can't really justify it for my dd at the moment.
Also, curious on the cam. I plugged it into desktop dyno, and it showed good gains 4*retarded.
Of course DD seems optimistic for my build, 369hp@4500rpm??
Old Jun 16, 2013 | 10:19 AM
  #147
Car: 1971 Camaro
Engine: 427
New canton timing cover painted and installed.
Spent a good bit of yesterday under the car with a wire wheel on a grinder cleaning the underside.
Then went to the local track to watch the outlaw steet cars race.
Getting ready to head back out to the garage to hopefully finish prepping the undercarriage. I hope to get paint sprayed on in tomorrow.
Things will start moving fast then.
Old Jun 25, 2013 | 11:15 AM
  #148
shawnc16's Avatar
Car: 86 IROC, 89 GTA
Engine: 350 blocks, both of em
Transmission: 700r4s
Axle/Gears: 10 bolt and 9 bolt, 3.73, 3.23
Sweet build! Would have liked to see those other wheels mounted. What was the offset and what did you have to do to get them to fit?
Old Jun 29, 2013 | 08:45 AM
  #149
Car: 1971 Camaro
Engine: 427
Not much too update, got distracted by a couple other paint jobs. Should be down with them after next weekend and then I'll be back on the iroc.
Old Jul 2, 2013 | 06:28 PM
  #150
Car: 1971 Camaro
Engine: 427
Haven't worked on the iroc in thr last week,
decided to paint my daily driver.
Warning, not third gen safe!
