split second power loss
Old May 29, 2013 | 01:09 AM
whatalisten's Avatar
Car: 86 Camaro T-top
Engine: 305 vin:H
Axle/Gears: stock 2.73
my camaro suffers from a split second power loss when about 90 to 100% throttle. it feels more like a eletrical problem. and it dosent act like its starving for gas. any ideas?
Old May 29, 2013 | 11:38 AM
Engine: 305 vin:H
Re: split second power loss
also it does this split second power loss midway in the rpm range say around 3000rpms.so i have power right off the bat. up too the power loss. after the powerloss throught the rest of the rpm range.
Old May 29, 2013 | 01:14 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Sounds similar to what I experienced with a vacuum leak.
Mine was a leaking vacuum control valve to the HVAC controls.
Is there a hissing sound that comes from behind your dash?
Old May 30, 2013 | 11:27 AM
Engine: 305 vin:H
its not hvac i put a cap where that vacuum went. my hvac dosent work right now anyway.
Old Jun 9, 2013 | 02:06 AM
IROC#1's Avatar
Car: 1988 IROC Z
Engine: 5.7 litre
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
Have you replaced the fuel filter? Im 95% sure thats your problem
Old Jul 6, 2013 | 07:40 PM
Engine: 305 vin:H
i have replaced the fuel filter but still doing it
Old Jul 7, 2013 | 06:23 AM
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
What kind of fuel pressure are you getting?
theshackle
Sep 17, 2020 08:26 AM
formula_novice
Sep 5, 2015 03:58 AM
Warlocksirix
Aug 29, 2015 11:36 AM
sailtexas186548
Aug 24, 2015 10:11 PM
Bradsaundry
Aug 12, 2015 12:34 AM
