My 1987 IROC
Old Apr 24, 2017 | 08:16 AM
  #201
J. Chris Davis's Avatar
Re: My 1987 IROC
Old Apr 24, 2017 | 08:24 AM
  #202
Re: My 1987 IROC
Here is the steering stuff. Too bad the rest of the car don't looks as good underneath right now.
Old Apr 24, 2017 | 08:25 AM
  #203
Re: My 1987 IROC
Old Apr 24, 2017 | 09:49 AM
  #204
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: My 1987 IROC
Th steering wheel looks great. Nice choice. Hurst Dual Gate = Jealous.
Old Apr 24, 2017 | 10:18 AM
  #205
Re: My 1987 IROC
Thank you. Looked at a lot of steering wheels online till I decided this is the one I wanted. I think it looks more modern and fits the car well.
Old May 10, 2017 | 09:35 AM
  #206
Re: My 1987 IROC
Still working away at the car. I modified the brackets for the Dual Gate shifter to get it over to the left more in the console so it would not be hitting the top plate. I still need to mess with the cable at the transmission. I started working on the A/C system again. Found out the Evaporator Core is leaking so I have a new one on the way. Should be here by Friday. I also have a new dryer and an orifice tube for a Ford to put in. When I removed the lines I thought I had let off most of the pressure that was left. Also thought the Evaporator Core had as well. So when I left those lines off it sprayed all over and made a nice mess. got all over me and the car. Hopefully it cleans off easily since the car wont get a bath for a couple of days till this is fixed. It's pretty much all oil anyway. Here are some pictures of the core removed from the car.
Old May 12, 2017 | 08:29 AM
  #207
Re: My 1987 IROC
Old May 12, 2017 | 09:20 PM
  #208
Re: My 1987 IROC
Got the evaporator core today and got the A/C fixed tonight. I exchanged the screen and front foam from the old core and bought some weather stripping material from the hardware store. The refrigerant I used was R12 and R134 substitute from Enviro-save and I used 3 5oz cans of it. It was starting to cool off outside to about 65, but I was getting A/C temps of 40 degrees. I need a warm day to really test it. I'm posting some pictures of different stages of reassembly just incase any one needs them for reference.
Old May 20, 2017 | 11:57 AM
  #209
Re: My 1987 IROC
Got a cup holder installed real quick this morning.
Old May 23, 2017 | 04:27 PM
  #210
DynoDave43's Avatar
Re: My 1987 IROC
Looking good in there. Double DIN, Hurst, Momo wheel, cup holder...you are the king of tasteful interior mods!
Old May 23, 2017 | 06:01 PM
  #211
rurnt88's Avatar
Car: 1988 IROCZ
Engine: ZZ4
Axle/Gears: MOSER 9"
Re: My 1987 IROC
I agree. . . well done! What's next?
I can watch people work and spend money for hours :-)
Old May 23, 2017 | 08:15 PM
  #212
Re: My 1987 IROC
Thanks guys! This was what I was just working on. It could have turned out better. I was hoping that the texture coating and paint would fill some of that in (first time using that stuff). I'll have to come back later sand it down and redo it. At least it's hidden under the ash tray lid. This usbl/hdmi adapter is for my stereo for being able to use the Android Auto feature or Pioneers mirror radio or whatever else. Next project is get the stereo and climate control aligned and get that double din bezel finshed up.
Old May 24, 2017 | 10:20 AM
  #213
StansFBM's Avatar
Car: 1985 Iroc-Z
Engine: 6.2L LS3
Re: My 1987 IROC
Love the cup holder, it's definitely better than asking my wife "can you hold this bottle?" LOL
Old May 24, 2017 | 11:19 AM
  #214
Re: My 1987 IROC
That's for sure. It is certainly one of those must have items in a car.
Old May 25, 2017 | 08:19 AM
  #215
Re: My 1987 IROC
Well I can't comment to the product quality of this dual gate shifter. I was still trying to get the shifter adjustment quite right which left me having to do a little filling on the shifter stops so the shifter could go a little farther to get it to go into first gear and over drive. I tried to get the cable adjustment as close as possible. So then I'm testing the shifter while stopped and the shifter arm falls off. Cheap looking push pin rivets seem to be what hold it on the assembly. Going to go to the hardware store tonight and try to find a good solution to get it back together without anything being in the way of the internal assembly. What I need to find is a pin and clip type fastener that fits in the hole and has the right length to it.
Old May 25, 2017 | 08:58 AM
  #216
rurnt88's Avatar
Car: 1988 IROCZ
Engine: ZZ4
Re: My 1987 IROC
Hey J.D.
It's always something with after-market products. They seem to be about 90% there but there's that one little area. . .
Still a very cool piece and worth finding a solution for.
You'll make it right.
Old May 25, 2017 | 09:18 AM
  #217
rurnt88's Avatar
Car: 1988 IROCZ
Engine: ZZ4
Re: My 1987 IROC
Good idea, what did you use to make this?
It is a bit rough, and will look a lot better once sanded smooth? As you noted it is hidden until you do.
It's in the right place for the stereo for certain.
Like many have done, I plan to install a USB in the lighter opening/area. One guy even cut down the lighter, keeping the **** to cover the port.
Old May 25, 2017 | 09:28 AM
  #218
Re: My 1987 IROC
Originally Posted by rurnt88
Hey J.D.
That's for sure! It's always something. I should be able to find something at the local hardware store tonight. I might be there a while, but I'll find something, lol.
Old May 25, 2017 | 09:31 AM
  #219
Re: My 1987 IROC
I had some scrap plastic from work. Basically someone left over ABS plastic dash bezel from a Police squad install and I cut a section of that out and glued it in with JB Weld. Then went over it with the SEM 39853 black texture coating and then some black low gloss paint. I will fix this later and retry the texture coating. It probable I wasn't using it correctly. I have a radio bezel to do with that stuff yet so I hope I get it coating better.
I put a push button start where my lighter was, but I did another one to the console by my parking brake handle.
Old May 25, 2017 | 01:27 PM
  #220
DynoDave43's Avatar
Re: My 1987 IROC
Yeah, but dude...it LOOKS awesome!
Old May 25, 2017 | 01:34 PM
  #221
Re: My 1987 IROC
That that it does.
Old May 26, 2017 | 08:12 PM
  #222
rurnt88's Avatar
Car: 1988 IROCZ
Engine: ZZ4
Re: My 1987 IROC
Did you do a write up on the push button start? I checked through a bunch of your posts but couldn't find it. Looks like a nice upgrade.
Old May 26, 2017 | 09:50 PM
  #223
Re: My 1987 IROC
I don't know the brand of it. I got it off of EBay a couple of years ago. I'll scan and post the instructions I have when I get back to work on Tuesday.
Old May 27, 2017 | 06:48 AM
  #224
rurnt88's Avatar
Car: 1988 IROCZ
Engine: ZZ4
Re: My 1987 IROC
OK. I see several on eBay, did you buy just the button? I see some reviews that claim the use of a button improves starting. Did you find that to be true? The instructions would be nice to have. Thanks!
Old May 27, 2017 | 10:49 AM
  #225
Re: My 1987 IROC
This looks like the one I have. I'll post the instructions when I have access to a scanner on Tuesday. They are the instructions that came with my button, but I see this auction does not include any instructions. If I remember correctly it was just hooked up to fused switched 12v, ground and ignition sense. I did not bother hooking up the LED light for it. It is a little bright. I did not notice any difference with starting vs the ignition switch itself. It does not drop power to the acc while starting as the ignition does. You can wire that way if you want with an extra relay, but I wasn't concerned about that. My temp gauge needle likes to bounce up and get stuck when starting with the key so this helps that issue since it doesn't effect the acc power.
http://www.ebay.com/itm/12V-Red-LED-...JXV7NO&vxp=mtr
Old May 28, 2017 | 05:03 PM
  #226
Re: My 1987 IROC
Fixed my brake light switch so I got my 3rd brake light working again. The internal contacts needed to be cleaned. I had to order a set of bulbs for it since 3 are burned out. I also got the 3D printed radio bezel filed and fitted in the car and put the spacers on the climate control to fit the bezel. I still need to texture coat and paint it. Hopefully that turns out better than the ash tray piece. Still got an issue with the shift arm which I'm still working on a fix for that.
Old May 30, 2017 | 09:02 AM
  #227
Re: My 1987 IROC
Ripped my dual gate shifter out yesterday. Could not find a good local solution to get that thing properly reattached without having play in it. I'm just going to weld the arm on to the assembly and be done with it.
Old May 30, 2017 | 09:03 AM
  #228
Re: My 1987 IROC
Old May 30, 2017 | 05:30 PM
  #229
rurnt88's Avatar
Car: 1988 IROCZ
Engine: ZZ4
Re: My 1987 IROC
J Chris Davis:"This looks like the one I have. I'll post the instructions when I have access to a scanner on Tuesday. They are the instructions that came with my button, but I see this auction does not include any instructions. If I remember correctly it was just hooked up to fused switched 12v, ground and ignition sense. I did not bother hooking up the LED light for it. It is a little bright. I did not notice any difference with starting vs the ignition switch itself. It does not drop power to the acc while starting as the ignition does. You can wire that way if you want with an extra relay, but I wasn't concerned about that. My temp gauge needle likes to bounce up and get stuck when starting with the key so this helps that issue since it doesn't effect the acc power."
Hey JD, thanks for posting the instructions. I will be adding one of these to my growing list of electrical mods.
Old May 30, 2017 | 05:34 PM
  #230
rurnt88's Avatar
Car: 1988 IROCZ
Engine: ZZ4
Re: My 1987 IROC
3D printing is amazing. The look of that bezel is factory. Can't wait to see it finished.
As for the 3rd brake light, the one on my 88 IROCZ had some brighter than others and a few burned out. Disassembly showed a variety of bulbs, with 2 or 3 of them soldered in! I cleaned everything up, glued the broken base back together and ordered the lower wattage bulbs from Top Down Solutions. The factory bulbs get too hot and burn out quickly and/or cause damage. TDS is also where I got the epoxy from. I also cleaned the contacts and found some of the wiring was getting pinched. Upon reassembly the upper contact mount would not rotate down freely, so I took it apart, clean & lube and finally, it all works. It always seems to be the little things that take the most time to get right.
Old May 30, 2017 | 08:21 PM
  #231
Re: My 1987 IROC
No problem. It's a fun little mod to have.
Old May 30, 2017 | 08:23 PM
  #232
Re: My 1987 IROC
I'm pretty happy with how the radio bezel turned out. The factory look is what I was hoping to get with this. I had a printer in Texas do it and it was only about $20 to have printed with the climate control spacers. I did see that TDS had those bulbs. I ended up ordering a pack of 10 from EBay so I'll see how they work out. Eventually I'll be converting the exterior lights to LED.
Old Jun 6, 2017 | 02:41 PM
  #233
StansFBM's Avatar
Car: 1985 Iroc-Z
Engine: 6.2L LS3
Re: My 1987 IROC
Got my new Momo steering wheel today. Just waiting for the adapter to get here before I can put it on for a test fit. Then I'm going to paint the aluminum on the steering wheel black.
Steering wheel looks great!
Old Jun 6, 2017 | 04:03 PM
  #234
Re: My 1987 IROC
Thank you!
Old Jun 6, 2017 | 05:11 PM
  #235
rurnt88's Avatar
Car: 1988 IROCZ
Engine: ZZ4
Re: My 1987 IROC
Hey Chris, Whats next? Last I read you had ripped the dual gate back out and was threatening to permanently fix it :-)
Old Jun 6, 2017 | 05:32 PM
  #236
Re: My 1987 IROC
I drilled out the shifter arm and the mount for the arm in the shifter 1/4" and bought a couple of clevis pins that had multiple holes and added some spacers so the colder pin would fit tight in the hole. Then I trimmed off the rest of the clevis pin that was sticking out so they would clear the gate. So far so good. Been thinking about what is next. I need to get around to tinting the windows to 35% and get that hood sanded and in primer so the whole car matches. I have a couple other small projects I probably need to get out of the way before I do much more. Right now just enjoying the ride.
Old Jun 6, 2017 | 08:19 PM
  #237
rurnt88's Avatar
Car: 1988 IROCZ
Engine: ZZ4
Re: My 1987 IROC
"Right now just enjoying the ride."
I am so jealous...been working on mine for nearly 14 years now. BUT! I plan to have it running by the end of the year. Here's a picture so you understand;
Buying a house so things are on hold for now. But following your build has been motivational. Enjoy the Summer.
Old Jun 6, 2017 | 08:26 PM
  #238
Re: My 1987 IROC
That's going to look really clean in that engine bay with all that smoothing out and panel patching. Some day I will get there. Probably not for a while though, lol. Enjoy your summer too!
Old Jul 12, 2017 | 09:49 AM
  #239
Re: My 1987 IROC
Been a month since I last posted. Still driving around in the IROC. Doing small things here and there to it. Still need to figure out why my cruise control quit working. Replaced the brake switch for it which had no effect. It was working when I went to 3rd gen expo then a few days later it quit. Hoping it's just a dry cracked vacuum line. Whenever we get a cooler day on the weekend and I'm not busy I think I'll be trying to sand and paint that hood so its all one shade of black and fix the roughness on the roof.
Old Aug 24, 2017 | 08:25 AM
  #240
Re: My 1987 IROC
Old Sep 27, 2017 | 02:07 PM
  #241
Re: My 1987 IROC
Just went through my thread. I guess I forgot to post pictures after I finished the bezel install with the double din DVD player. I will try to get those taken and posted tonight.
Old Sep 27, 2017 | 07:51 PM
  #242
Re: My 1987 IROC
Here are a couple of pictures of the dash bezel installed and after I used that texture coating on it. The coating went on so so. I'll have to get better pictures. I think my flash was off.
Old Sep 28, 2017 | 12:27 AM
  #243
TOM305T/A's Avatar
Car: 1987 GTA 350 auto
Re: My 1987 IROC
nicely done
Old Oct 18, 2017 | 10:17 AM
  #244
Re: My 1987 IROC
Thank you! It looks like my alternator may be on its way out. Drove the car yesterday and it had a high pitch wining noise coming from the engine bay and I saw my volt gauge go from above 13 volts to about 8 or 9 volts.
Old Nov 13, 2017 | 09:07 AM
  #245
Re: My 1987 IROC
I don't think I will have any more updates on this build. I will be fixing or replacing the alternator this winter, removing the one touch windows and the stereo system and putting a CD player and stock speakers in its place and selling the IROC come this spring. I will be buying another car and will no longer have room for the IROC. If I do get back into a 3rd gen it will most likely be a Firebird for a KITT conversion. I still have threads I follow and will still be around.
Old Nov 13, 2017 | 07:00 PM
  #246
KCG's Avatar
KCG
Car: 89 IROC
Re: My 1987 IROC
Why remove the one touch? Using it in another vehicle or is there problems with it?
Old Nov 13, 2017 | 07:05 PM
  #247
Re: My 1987 IROC
I'm keeping it for future use or another car. I made it so it was plug and play that way it is easy enough to remove. I also could only ever find 4 of those modules so I don't want to let them go either.
Old Nov 14, 2017 | 08:57 AM
  #248
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Axle/Gears: 3.42 T2R
Re: My 1987 IROC
Do you have the contact info of who printed it? I like that it's somewhere "local" to me.
Old Nov 14, 2017 | 09:09 AM
  #249
Re: My 1987 IROC
I signed up on Treatstock.com and you can search by location. Looks like the business that I had do mine was called Modern Blacksmith 3D Design, Printing and Scanning.
Old Nov 14, 2017 | 11:04 AM
  #250
KCG's Avatar
KCG
Car: 89 IROC
Re: My 1987 IROC
You did a lot of cool things here. Hate to see you go.
I got a few ideas from you thats for sure...
Thanks!
