1992 RS Autocross
Old Dec 4, 2013 | 06:46 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
1992 RS Autocross
Just thought these were cool pics...
Had a rough week. A really close friend/coworker got laid off today, a former coworker was killed in a car accident Tuesday. Bombed my differential equations exam yesterday...
So, basically Im just sharing these for the hell of it to blow off some steam. I thought a few of them were really, really cool action shots:
I placed 16 out of 24 overall.
This is the one where I got sideways:
Old Dec 4, 2013 | 08:13 PM
Screamin86's Avatar
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
Sorry about the recent issues but the car looks great. Looks like you had some fun. I haven't made it out to any autox events in a couple years. Hopefully this spring that will change.
Old Dec 6, 2013 | 09:44 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: 1992 RS Autocross
Yup. I'm thoroughly jealous that you can still AutoCross in December in Georgia. In Illinois after mid October it gets iffy. What suspension work have you done?
Old Dec 7, 2013 | 01:47 AM
Car: 1992 Camaro RS
Yeah it was cool all week, in the 20s-50s which for us is COOOLD. But Sunday was a relatively warm day. highs in the low 50's so by the time we were racing it was nice out. It hardly ever snows here in central GA. Maybe once every 5 years or so.
Suspension is actually mostly "stock". Has polyurethane bushings for the sway bars and front and rear LCA's. 34mm IROC front sway bar, 24mm TA rear sway bar (Which is probably why it's so tail happy in certain situations, the combo is a bit mismatched but I like it). It has cut springs from an IROC and Koni yellows. The panhard bar is a tube piece with a rod end on one side, it has LCARBS, and it has sfc's. That about covers it. It's a lot but it's nothing outlandish. Im hoping to get some rear LCA's with rod ends from Founders pretty soon. I feel like it will really help reduce binding in the rear suspension. It can move any way it needs to, but you can tell there's too much resistance from the bushings in the movement of the rear axle.
Old Dec 7, 2013 | 03:33 AM
((Mike))'s Avatar
Car: 1969 RS Z28 X33 Norwood built
Engine: 383 Stroker
Transmission: T10 4 speed
I like it with the flat black 82-84 hood!
Old Dec 7, 2013 | 10:49 AM
Car: 1992 Camaro RS
Thanks! I got back and forth on it even though Im used to it. I like it a lot usually, and then I decide I hate it for a week, and then I like it a lot again. It's plastidip. Looks a whole lot better and a whole lot easier than flat black paint. It's an SMC hood that I got for the weight savings.
This is what it looked like before I plastidipped it, note my old ground fx are on the car, and the combination of the faded hood and faded ground fx really made the car look awful. It looks much better now.
I later found out that the 82 cars got single stage paint, so I should be able to just polish that hood out and make it mostly match the rest of the car... So I'm keeping that in my back pocket for when I get tired of the plastidip. The headlight buckets are plastidip too.
Old Dec 9, 2013 | 09:15 AM
MMroc86's Avatar
Car: 1986 IROC-Z28 & 1987 GTA
Engine: 305 TPI & 350 TPI
Thanks for sharing those videos! Its really inspiring me to get out there & do some autocrossing. Unfortunatly while I was inspecting a few things the other day & changing my oil I found a stress fracture on either the crossmember or a-arm, not sure yet, it got dark on me that day.
But I'll check it out thourghly today..... Looks like its time for http://umiperformance.com/catalog/in...roducts_id=627
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Fireslash
Apr 11, 2016 06:43 PM
skirocz28
Members Camaros
Nov 12, 2015 07:52 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
ironbmt
Sep 27, 2015 06:00 AM
