Brought an 88 home today..
Old Sep 24, 2017 | 06:09 PM
  #101
razor99's Avatar
Car: '89 IROC-Z
Re: Brought an 88 home today..
Wow, that car has come a long way! Very nice work, that's quite a revival so far. I will definitely be following this thread for future updates
Old Sep 25, 2017 | 05:54 PM
  #102
Billgluckman's Avatar
OMG, the inside of that engine looks like someone did their oil changes with foundation coating instead oil oil. Anyways, great work and I wish I had half the drive that you do.
The bad part is that the engine had less than 150k miles. I heard the engine run before I bought it and it was quiet as can be. I didn't expect it to look that bad inside.
Update time...small update lol
Should have color tomorrow.
Old Sep 25, 2017 | 06:09 PM
  #103
I'm also trying something I've never used before. I didn't take before pics but we all know what our factory k members look like. Rusty and filthy.
I sanded and sandblasted most of the rust off and I'm soaking the k member in oshpho. We have an older guy at work who's a welder and swears by it. Worst case scenereo it reacts with the paint and I have a rusty k member again. I could live with that, but I don't think I'll have a problem.
Old Sep 26, 2017 | 10:54 AM
  #104
I didn't take the engine bay down to metal except in spots that had rust, and after the coat of primer dried I could still see spots where it transitioned from bare metal to factory paint or primer. I considered spraying base color anyway because I'm not sure if it would even be visible with the engine in the car or not.
I ended up heading to the parts store first thing this morning for a quart of surfacer.
Looks much better.
Old Sep 26, 2017 | 08:16 PM
  #105
This red is so red. Lol
Learned a lot today. If I was doing this again I wouldn't have had the regulator at the gun and I would have bought a smaller cup. Those tight spaces aren't the easiest to spray.
Old Sep 27, 2017 | 06:07 PM
  #106
K member mocked up.
My my camera keeps making the red appear more orange-ish. I played with the settings a little and finally got it to show the real color.
Old Sep 27, 2017 | 07:18 PM
  #107
razor99's Avatar
Car: '89 IROC-Z
That looks awesome! Very nice. Your car is going to be show quality at this rate
Old Sep 27, 2017 | 08:36 PM
  #108
TOM305T/A's Avatar
Car: 1987 GTA 350 auto
great tread
Old Oct 7, 2017 | 10:56 PM
  #109
New struts and mounts, primer, and door hinge kit. Installed struts and rolled the car out.
First time seeing it in the sun.
Realized I got in a hurry and forgot to install engine mounts before i installed control arms...
...whatever. I've put em in this way before, I'll do it again.
Drove the donor in, rolled it out.
This engine was nast nast nasty.
Old Oct 7, 2017 | 11:12 PM
  #110
It's just a 4.8 but it opens up my options in the future for a bigger ls. I actually know most of the history for this drivetrain. The donor truck was my fathers, he left it to my brother, who I then purchased it from. The 4l60e was rebuilt in 2012/2013. I know the engine was religiously maintained when my father owned it, and I know it ran great right up until I plucked it from the truck. At 275hp, it's a big improvement over the tbi 350 that was in this car.
This is under the valve cover. Much better than the last engine. Lol
Im still scrubbing the engine. Dirt roads and a few oil leaks made a mess.
Old Oct 7, 2017 | 11:18 PM
  #111
jwrebholz's Avatar
Car: 1989 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 2.77 Limited Slip
Don't be too hard on your phone's camera. Red can be REALLY hard to photograph properly. My car is dark red and depending on light, camera settings, the phases of the moon, etc it can look anywhere from the color of red wine to burnt ATF.
Old Oct 8, 2017 | 12:17 AM
  #112
Lol at phase of the moon but yeah I definitely know what you mean
Old Nov 4, 2017 | 09:41 AM
  #113
Finally got it clean, block painted. Installed f body oil pan and pick up tube, modified the truck windage tray to fit. New lifter valley, front/rear cover and oil pan gaskets.
Went with the cheap (car shop brand I think) ls adapter plates. Had to trim the right side clamshell a bit to make it work but no big deal.
I still need intake gaskets so it's just sitting there. I've got some left over silver base coat I used on a friends truck and considered using it on the intake but I think a new coat of flat/matte black will look better. Balancer is coming back off for paint too.
The 4l60 isn't in the car yet. I'm hoping to go in with it this weekend so I can get an idea of what needs to be done for the crossmember.
Old Nov 4, 2017 | 04:56 PM
  #114
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Car is coming along very well I think. That Buick engine looks like something we used to see back in the 60s with vent tubes and whale oil. Pretty decent looking truck for a donor, but nice to know the engine's history for sure. Interesting to see under the rear quarter too, no rust at all and clean. You located out of the snow belt? Keep us posted.
Old Nov 4, 2017 | 06:38 PM
  #115
The donor truck was in really good shape other than the front suspension/steering. And the fact that there was no title.
Im located in the south. Still see a lot of rust on these t top cars from what I saw when 3rd gen hunting, not as bad as some I see on this forum though. Also, there was some rust behind the quarter panel. It wasn't much but it did make me wonder about the other side. I definitely took care of what rust I found.
Old Nov 4, 2017 | 08:42 PM
  #116
700r4 out.
Old Feb 4, 2018 | 11:16 PM
  #117
Got the 4l60e installed and modified the factory crossmember. I did this back in November. At some point I rolled the car out of the shop and under my carport and covered it with a car cover. I hadn't had much interest in touching it lately until about a week ago when I lifted up the car cover.
Seeing all the shiney got me motivated again.
labled everything. Removed unneeded wires and connectors. Laid the harness out as it would lay from the factory..
This is how I originally planned to do it. I planned to mount the ecm on the driver side battery tray then run my intake to that side and cover it up. As soon as it was mocked up I knew I couldn't deal with those wires.
Old Feb 4, 2018 | 11:30 PM
  #118
Depinned ecm
Currently working on lengthening each connection one by one and routing the wires inside where I will mount the ecm under the dash.
I'm also planning on playing with some fiberglass on that air/heater box. I'm gonna need clearance over the valve cover and I plan to close it up because I won't be running a/c any time in the near future.
Old Apr 8, 2018 | 07:28 AM
  #119
jdracing's Avatar
Car: 92 RS 5-speed Garnet Red
Engine: 92 RS Automatic White
Transmission: 84 Z28 Automatic Red
Axle/Gears: Top to bottom 3.30, 2.70, 3.70
some great inspiration for an ole man like me....thanks for the postings so far....your work looks awesome....jd
Old Jun 8, 2018 | 11:48 AM
  #120
Thank you sir^^
The car keeps getting pushed out of the shop for other jobs. I've got it back in and ordered some parts.
I'm hoping I have everything I need to make it run. I'm hoping to finish the harness this weekend. I have not had the vats disabled in the ecm but I'm going to try a trick to crank it. I have the bcm and vats module resistance from the donor. If it doesn't work, I'll just have to buy tuning software sooner than I planned or have pcm tuned.
Old Jun 8, 2018 | 11:51 AM
  #121
Originally Posted by Billgluckman
Thank you sir^^
At this point I just want to hear it run. I think that will give the motivation to get my *** in gear.
Old Jun 8, 2018 | 11:52 AM
  #122
Thank you sir^^
Old Jun 8, 2018 | 05:14 PM
  #123
jdracing's Avatar
700r4 out.
I really like following your progress.....But I have a question about the wheels?....Do I see a Mustang pony on the center caps?....Will a Mustang wheel fit an 88 Camaro?....
Looking great so far,can't wait to see completed,
JD
Old Jun 8, 2018 | 09:08 PM
  #124
JD
Yes they are mustang wheels but no they won't fit without adapters. When I first got the car running the tires that were on it were dry rotted. I had a set of mustang wheels with practically brand new tires just sitting around. I didn't want to buy tires for the factory wheels when I know I'll go aftermarket later so I just bought a set of cheap adapters to get me by.
I will say though, I think the 99-04ish mustang bullit wheels would look good on a 3rd gen if I found a set cheap.
Old Jun 8, 2018 | 09:57 PM
  #125
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
It's coming along Wild Bill. Going to be nice
Old Jun 8, 2018 | 10:23 PM
  #126
i keep telling everyone it will be rotting in my front yard in 20 years and some young whipper snapper will stop by and try to buy it. Of course I'll say no, "I'm doin an ls swap". This project has gone on so much longer than I planned lol
Did you ever use the headers?
Old Jun 9, 2018 | 07:44 PM
  #127
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Not yet I recently acquired an L98 i plan to put them on maybe this winter or next spring. Let me know if you decide not to use that y-pipe.
Old Jun 9, 2018 | 08:38 PM
  #128
Nice. I should know soon on the y pipe.
Old Jun 9, 2018 | 10:39 PM
  #129
lonesomeloser's Avatar
Car: 1983 Z28
Very nice work!
Old Jun 10, 2018 | 07:50 AM
  #130
Originally Posted by lonesomeloser
Very nice work!
I was looking at your thread yesterday. Good work on that car. Part of me wishes I would have gone back original with mine. I'm hoping I can get my hands on an original iroc with 5.7 before prices get too crazy.
I got some some work done yesterday but nothing pic worthy. Other than the parts I showed earlier I also finally got the right exhaust manifolds(f body), f body dipstick, and 4l60e torque arm bracket. I got the torque arm bracket installed and the torque arm its self is finally secure. The engine dipstick is in. I also bent up my 700r dipstick to work with the 4l60. I almost forgot that I never installed the torque converter bolts so I knocked that out.
Its looking more like a real engine(for better or worse) with the coils and wires now mounted. Might have some pics later. I've gotta run around and see if I can locate some starter bolts. I bagged and labeled everything but somehow those two bolts got away from me.
Old Jun 13, 2018 | 11:58 AM
  #131
I hope enough people are reading this to give me an opinion..
My car started as a sport coupe with tbi 305. The sc badges simply say “Camaro” on the rockers, bumper, and dash. I’ve always disliked these badges, mostly the dash badge. I think the red “z28” or even the “rs” dash badges look so much better. I love the “Iroc” badges and door graphics, but I would never try to pass this car as an Iroc so I would never use those.
Im just curious how people feel about re badging a car after Its no longer what it use to be. I think switching to rs badges wouldn’t be commiting any crimes, but I really like the red z28 dash badges lol. I do feel like every time someone said “hey nice z28” I’d want to correct them.
Im definitely buying different badges because my stock ones (gold) don’t go with my color. What’s everyone’s opinion on this?
Old Jun 13, 2018 | 01:28 PM
  #132
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
I say badge it and make it what you want.
Old Jun 13, 2018 | 02:29 PM
  #133
Im leaning towards RS badges. I don’t know if they ever made a RS badge for the dash though besides the 25th anniversary though
Old Jun 13, 2018 | 03:04 PM
  #134
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Old Jun 13, 2018 | 05:18 PM
  #135
Bleh
Old Jun 17, 2018 | 03:22 PM
  #136
Theres a whole lot of temporary going on here but this is basically what my harness will look like. I’ve still got a ways to go to finish it off but I did a test fire today and it runs...for about 2 seconds. I’m assuming my vats bypass didn’t work, but it’s all good because I ordered hp tuners last week
Old Jun 17, 2018 | 04:56 PM
  #137
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Dang vats! I'm ready to see this thing in person when you get it done. Local kid just put a cammed 4.8 in an S10. It will stroll! I been trying to buy it.
Old Jun 17, 2018 | 05:42 PM
  #138
I bet it will. There’s not much difference in a 4.8 vs 5.3. I have a 5.3 Silverado and I drove the truck that this 4.8 came out of. The 4.8 actually felt just as strong, but it had a tune, air intake and true duals.
Old Jul 15, 2018 | 04:41 PM
  #139
Still figuring things out. The engine wiring is done for the most part. I received hp tuners and used that to delete vats so the engine will now run but I don’t have a cooling system yet so I’ve only ran it a few seconds.
I still need an air intake, the one pictured is from the truck and obviously won’t work if I run it to the driver side. I scored a brand new f body water pump for $30, still need radiator and hoses.
In the pic above if you look at the rear passenger coil you’ll see I’ve offset it from the rest. I cut the coil bracket and welded it up so it will clear the a/c box. I thought I would have more room than I do but it’ll work for now.
See the shiney bolt between upper frame rail and strut mount?
I thought this was a nice place for the little fuse panel.
Still have to clean/replace some of these parts. Also I forgot to mention, that is the truck accessory bracket on the driver side, I’m going to try to make it work at least for temporary use once I have a radiator so I can run the car for a while. If everything works out and the alternator clears the hood I may keep it
Old Jul 15, 2018 | 10:41 PM
  #140
jwrebholz's Avatar
Car: 1989 IROC-Z
Engine: 5.7 TPI
Looks like your build is coming along nicely. Good work!
Old Oct 15, 2018 | 09:35 AM
  #141
Gonna try to update the little bit I’ve done over the last few months with a couple different posts. Mobile version can be aggravating to work with sometimes.
F body water pump installed. Chopped up the truck accessory bracket and built an idler relocation bracket. Moved it just below the alternator like the aftermarket kits do.
Old Oct 15, 2018 | 09:42 AM
  #142
::::EDIT FROM THE FUTURE:::::: when I test fit this hood I wasn’t using my head and didn’t install the rubber bump stops that sit on the body. The bump stops raise the hood up significantly and the hood will clear. Keep in mind this is not the factory truck alternator, it’s a 3rd gen alternator. The truck alternator sit way too high. The alternator in the pic is the factory 88 replacement part. It sits lower but still high.
I test fitted the hood. Would not close.
Cut out a section where the alternator hit and the hood will now sit flush. This is still a problem because I still plan on using the factory louvered hood and not sure if this will work with that hood. I will eventually go to aftermarket brackets that will lower the alternator and place an a/c compressor in the factory 3rd gen location on the top passenger side. Until I do I’ll probably just have to run this hood once the car is driveable.
Old Oct 15, 2018 | 09:48 AM
  #143
I had to do a lot of playing around to get the pulleys lined up. I’m still not 100% it’s good to go but it passes the eye ball test.
Old Oct 15, 2018 | 09:56 AM
  #144
Installed a new radiator, hoses, and a fan/shroud combo I picked up at a local upullit. I didn’t know until I went to install it that the v6 shroud wasn’t as wide. I made a post on Facebook trying to find a recommendation for a new upper hose(this hose won’t work in my swap) and I got attacked for my “lack of attention to detail” lol.
The lower hose is perfect. The upper hose has that high spot in the middle that will be in my way when I run my air intake. I’ll be trying a 3.4 camaro upper next.
Old Nov 13, 2018 | 09:48 AM
  #145
Well the y pipe now fits an ls 3rd gen.
Ground clearance won’t be great but it’s gonna get me by until I buy long tubes. Plus I learned a little making the bends. I feel comfortable now spending the money on nice stainless pipe to build from headers back when the time comes.
Old Nov 13, 2018 | 09:55 AM
  #146
I’m horrible at documenting problems and what I’ve done to resolve a few I’ve had but i think this may help someone because I found zero info on this.
I hooked up my shifter cable to the trans last week and was having problems with the trans not actually going all the way into park. If anyone else has this problem, go get this shift lever
I pulled it off an 85 6cyl camaro.
Old Nov 13, 2018 | 09:59 AM
  #147
Started this little project too. I’m not sure if I’ll end up running these on the car for a while or not but I’ve always wanted to polish a set. I plan to paint the non polished area black like the old wheel above
Old Nov 13, 2018 | 01:06 PM
  #148
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Projects lookn good! I need to polish and repaint my rims.
Old Nov 13, 2018 | 01:40 PM
  #149
its definitely a job. The funny thing is some chrome 17” Iroc’s popped up for sale today in local classifieds. I don’t need to buy them, but they’re pulling at me pretty hard
Old Nov 13, 2018 | 01:42 PM
  #150
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Go get em. You may regret not pulling that trigger!
