Detroit Speed 1987 Camaro Test Car 2.0
#202
Car: 1987 DSE-Z Camaro
Engine: 388ci LS7
Axle/Gears: Ford 9" DSE Full Floater
Re: Detroit Speed 1987 Camaro Test Car 2.0
Today marks 1 year since we started working on the Third Gen Test Car 2.0!
How about some more paint?!
#203
#204
Before you guys go out and BUY a test car, just hit me up. You can use mine!
#206
This is how I did it:
https://www.thirdgen.org/forums/memb...ml#post5976194
#210
Engine: 388ci LS7
We've been staying busy wet sanding over the past week. Our paint and body specialist Austin also cut and buffed a small section of the roof to sample the outcome of this awesome shade of blue!
#211
COTM Editor
Wow the pop on that blue is huge! Gonna look amazing in the light with all the high and low light angles these cars create!
#213
It'll be interesting to watch it compete against the others in the Detroit Speed stable.
Better still if it outperformed them all.
Aside from the early 2nd gen Camaro, which I've always liked from day one of production, the 3rd gen is bound to be one of their better looking cars. It looks fast standing still.
#215
Car: 1987 Trans Am
Not sure if I'm correct, but they haven't mentioned modifying the lower control arm attachment point in the stock crossmember, so I would guess they made a washer with an offset hole in order to spread the clamping force of the control arm bolt out more efficiently.
#220
Engine: 388ci LS7
Re: Detroit Speed 1988 Camaro Test Car 2.0
Can you tell us what you did to fit the wheel/tire package?
Is that an eccentric on the A-arm?
[IMG]https://www.thirdgen.org/forums/attachments/members-camaros/311974d1493230402-detroit-speed-1987-camaro-dse-04-26-2017
What are the benefits of the torque box shown above and to the left of the tire?
[IMG]https://www.thirdgen.org/forums/attachments/members-camaros/311975d1493230402-detroit-speed-1987-camaro-dse-04-26-2017
We won't be running the factory power antenna, so our fabricator decided to close that out and punch flare for strength and looks.
#221
Engine: 388ci LS7
The car has made it's way back up to our Test Car facility for assembly...
#224
What you are seeing is actually the stamping on the crossmember, it is not an eccentric.
Thanks for the reply.
#226
COTM Editor
Received 1,860 Likes
Car: '89 Firebird
Engine: 7.0L
So you can see which way it flying down the track.
I think the answer is why spend a lot of money on paint that won't be seen.
#230
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
I cant stop looking at this! I wish I had some fiberglassing skills, thats exactly what i wanted to do so i could run a proper splitter. I would assume the man hours into that would be pretty pricey.
Jay
Jay
#231
Engine: 388ci LS7
Pieces of the puzzle coming along nicely...
#232
Car: 1986 Z28
Transmission: T5 WC
Axle/Gears: 3.42 T2R
Plus pro-racecars are built from a 'body-in-white' because I think white is the cheapest color to paint.
#233
Engine: 388ci LS7
You are all correct about the undercarriage color. Plus, dove gray looks pretty awesome!
#235
I love the build...Question, is the DS solid steering shaft streetable? Also, curious what kind of steering box you are using.
#236
Engine: 388ci LS7
As far as the steering box, this is our DSE 600 Steering Gear that has been re-built with a 10:1 ratio. The frame rail has been modified to allow for a 4th fastener on the box.
#238
I am also going to assume they are using one of their own steering boxes. They don't list them for 3rdgens but do have them for earlier cars.
#239
With the removal of the rag joint in our Steering Shaft Kit, you can certainly feel less vibration in the steering. This would be ideal for a street application.
#240
#241
Engine: 388ci LS7
Curious as to the selection of a 10:1 ratio. I've been researching a new box for our car and was going to go with a 12:1 so it wouldn't be too twitchy on the road course. Is this a concern at 10:1 or is the expectation that it will be fine for autocross and road course laps with this ratio?
#242
I'm also curious as to what the first expected event is for the car. I'd love to see it in person. NSRA Lousiville in early August might be too soon for it. LSFest and FBody Nationals are both in September as is Cruisin the Smokies in Pigeon Forge.
#243
Engine: 388ci LS7
How streetable do you expect the ratio to be? I know most of the DSE cars don't see thousands of miles of street driving every year but do see enough to be concerned about this. Our car has the same tire size (315 square), but does see a few thousand miles of street driving every year which causes some concern on a 10:1 ratio. I'm also assuming you'll be using a 13 inch or smaller steering wheel in the car.
We have not yet determined the car's first event.
#244
We don't have any concerns for the 10:1 on the street. We do plan to street drive this car as much as possible and compete in events that include a road rally. We will be running the DSE Edition MPI GT1 steering wheel in this car which is 13".
Assuming the DSE team has cars at NSRA Louisville again this year, I plan on asking about the steering wheel. It looks awesome in the photos and writeup but I kind of want the driver to get her hands on it to see how it feels before buying one. She spends too many hours behind the wheel to use one that isn't comfortable.
As for the ratio, I know how hard the DSE team drives the cars so I'll have to reconsider the ratio now. At least I haven't placed the order yet. I was thinking 12:1 to retain street manners but if you don't expect any issues with street or track manners, I have to give more thought to 10:1.
#245
Car: 1987 Trans Am
Hopefully it makes it at least one of the August - September events. But there's quite a bit of assembly and shakedown to do before then.
I guess with the 10:1 box, it would be the same as having a 16.5" steering wheel, therefore requiring quite a bit less steering input for the same result.
#246
Too lazy to do any math, but they mentioned a 13" wheel with that 10:1 box. I think the stock wheel is about 14.5" with the 12.7:1 box.
The end result of switching to a 10:1 ratio with a 13 inch steering wheel will be a reduction in steering wheel motion from 2.5 turns to about 1.75 or possibly less turns of the steering wheel to take the car to full lock. If you know the box is that quick to turn in, there will likely be no issues. Issues will arise when drivers not expecting the car to turn that quickly try to drive it and don't react appropriately when the car turns much quicker than expected. This could lead to problems on the street in normal driving if they aren't used to it. It might also lead to issues with "panic" turns on the street when the unexpected happens and you need to get out of the way. Hence the question about were they concerned about streetability.
#247
Engine: 388ci LS7
Matt is making it difficult to keep up with the progress! Check it out...
#248
COTM Editor
WOW!!!
#250
Engine: 388ci LS7
I was out of the shop yesterday, so your updates are coming in just a day late...
