Project Motivation– ’92 RS LS1/T56 and then some
Old 01-03-2019, 11:55 AM
  #301
Billgluckman's Avatar
Re: 14-Oct-18
Originally Posted by GMan 3MT
Not yet. If I do end up dropping the pan, I'll replace the oil pump and put on the pickup girdle I have from BRP. ICT makes a nice one too.
http://www.brphotrods.com/mm5/mercha...gory_Code=CNV4
LS1 rear end. Front has 1.5" adapters I bought from someone on CL, I think they are ezaccessory. *edit to add* 1.5" adapter plus 1le hub (increased offset) plus 5th gen rotor hat thickness, so you can't necessarily just put a 1.5" adapter on a stock 3rd gen brake setup and expect it to work. You'll need 2-2.25"
awesome thanks
