StansFBM Build Thread, extension of TBRays98 Build
Old Feb 11, 2018 | 01:59 PM
  #101
StansFBM's Avatar
Car: 1985 Iroc-Z
Engine: 6.2L LS3
Re: StansFBM Build Thread, extension of TBRays98 Build
Hopefully I got everything under that damn dash done, LOL! Installed electronic pedal mounting plate and pedal... also mounted Direct Link connector for PCM, reverse lockout, reverse lights, break pedal switch, PCM ignition wire, reinstalled master clutch.
Hawks throttle plate mount for electronic throttle pedal
pedal mounted to mounting plate
throttle pedal meets 4th gen pedals !!!
direct link connector for pcm mounted
Old Feb 11, 2018 | 02:02 PM
  #102
StansFBM's Avatar
Car: 1985 Iroc-Z
Engine: 6.2L LS3
Starting to look like an interior again! Stick shifter installed, boot, manual shift plate, and mocked up steering wheel ... I plan on doing interior restoration next, but this fine for now.
Old Feb 11, 2018 | 02:08 PM
  #103
StansFBM's Avatar
Car: 1985 Iroc-Z
Engine: 6.2L LS3
Well, I have to send the Racetronix pump and harness back because I ordered the wrong year. That will set this back a week or so. So I started to work on all the finer details...Installed and routed alternator cable, heat wrapped some wires around headers and starter, installed ARP starter bolts, also tie wrapped wires around O2 sensors and wrapped a couple around starter to pull starter wires further away from the heat. Finally bolted torque arm, but the damn bolts ruined threads because the mounting holes were too small...more modifications
Alternator cable bolted on
Trying to figure out where to route alternator cable...right now I have it going on radiator support mount
nice shot of clearance
wires all secured...O2 harness
Used some thermo wrap around starter wires
Ran a couple zip ties to pull in wires even further away from pipes...may change to some stainless wire
Old Feb 11, 2018 | 04:08 PM
  #104
92BLKL98's Avatar
Car: 1992 Black Z28 Hardtop
Axle/Gears: 2002 10 bolt w/3:23
Nice build
Old Feb 12, 2018 | 07:10 AM
  #105
TBRays98's Avatar
Car: 1989 Formula
Axle/Gears: 3.45 1LE Disc LSD
Love seeing all the awesome work you've put into this car. Before you know it youll be in the drivers seat melting tires!!
Old Feb 17, 2018 | 05:58 PM
  #106
StansFBM's Avatar
Car: 1985 Iroc-Z
Engine: 6.2L LS3
Belt and hoses on! Check! Used 4th gen radiator hoses and had to make a couple of trips back to auto parts store for the right belt.
Old Feb 19, 2018 | 11:48 AM
  #107
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
for removing and installing the engine, did you leave the car in place on the jack stands and use the engine hoist to raise the engine/tranny or did you do something different? I couldn't tell.
Old Feb 20, 2018 | 08:24 AM
  #108
StansFBM's Avatar
Car: 1985 Iroc-Z
Engine: 6.2L LS3
I used the engine hoist to get the car high enough, then once the engine was out/in put it back on stands. The hoist chain was bolted to the wonder bar mounts (it's pretty light without engine). I really like this approach and I was super careful not to be under car while just on hoist.
Old Feb 25, 2018 | 10:38 AM
  #109
StansFBM's Avatar
Car: 1985 Iroc-Z
Engine: 6.2L LS3
Air intake from 5th gen mod - I decided to cut off the stock air box off the 5th gen air intake and bought a K&N cone filter. I also acquired the coupling and clamps to the throttle body. I’ll probably add another piece to extend the filter further towards radiator, but this will get me started. I have about $55.00 in the intake!!
Old Feb 25, 2018 | 10:48 AM
  #110
StansFBM's Avatar
Car: 1985 Iroc-Z
Engine: 6.2L LS3
Cleaned 4th gen tank - you could eat Totina’s pizza rolls off the inside! Also installed 0-90 ohm fuel sending unit to properly operate fuel gauge. Tested sending unit for 90 ohms with full float position. The Herko 0-90 ebay sending unit snaps on the fuel bucket a little different (because it's raised more) and the clip cannot be used. Also, that wiring harness is useless and the connector will not work on 4th gen fuel pump- since I'm upgrading later to Racetronix with Hotwire Kit, this is a non-issue for me. The Racetronix is on back order - so I'll need to put that in once I get it.
Clean!
sending unit in, the click fits kind of funky, but it's secure - this gives us the 0-90 ohm compatible with stock fuel gauge
Measure ohm at empty tank - 0 ohms
moving the fuel float to full gets the 90 ohms - we are good!!
Dropped existing 3rd gen tank
4th gen tank is ready to go in - snapped 4th gen lines and harness.
A view into the fuel door - the hose was cut around 2"
After a few trimming, it sits in there nicely.
4th Gen tank is secured.
Comparing 4th gen (left) and 3rd gen (right)
Old Feb 25, 2018 | 11:44 AM
  #111
Tibo's Avatar
Car: 1991 Z28 Vert
Curious, is the fuel filler neck bolted to something or held down at all?
Old Feb 25, 2018 | 12:02 PM
  #112
StansFBM's Avatar
Car: 1985 Iroc-Z
Engine: 6.2L LS3
Yes, it has a small bracket - once the hose was shortened, it was a perfect place to put a screw on inside body next to the tank.
Old Feb 25, 2018 | 04:52 PM
  #113
Tibo's Avatar
Car: 1991 Z28 Vert
Are you able to take a picture of what you've done?
Old Feb 25, 2018 | 05:23 PM
  #114
StansFBM's Avatar
Car: 1985 Iroc-Z
Engine: 6.2L LS3
I'll snap one when I pull it to put the Racetronix pump/wiring in. I do have this photo that shows the bracket - I mounted it in that area to give you an idea.
Not mounted but in this general area
The bracket flipped to other side - just giving you a better pic of what bracket looks like.
Old Feb 25, 2018 | 07:02 PM
  #115
Tibo's Avatar
Car: 1991 Z28 Vert
Thank you
Old Feb 26, 2018 | 05:11 PM
  #116
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
That plastic tank WAS clean inside, wasn't it.
A gaggle of lines, tubes, vents, hoses...not to mention wires. I'm sure I'd screw something up!
Old Feb 27, 2018 | 10:40 AM
  #117
StansFBM's Avatar
Car: 1985 Iroc-Z
Engine: 6.2L LS3
Wired up the fuel tank last night. Ran a dedicated fuel feed sender wire that will eventually be the trigger for the Racetronix relay (still waiting on that to be shipped ). Also, I bought a 4th gen Body-side 8-way connector and wired that to the stock third gen connector. Turned on the key and pump is on!!! Tonight I’ll plumb the return line and maybe fire it up!
Old Feb 28, 2018 | 10:15 AM
  #118
StansFBM's Avatar
Car: 1985 Iroc-Z
Engine: 6.2L LS3
It's Alive! First startup!
Old Jun 4, 2018 | 01:21 AM
  #119
RocketyMan's Avatar
Car: '96 Camaro-Vsux -- SOLD, '84 Z/28
Engine: 3.8L, 305 SBC
Transmission: 4L60E, T-5
Axle/Gears: 3.08s, 3.23s
I think it's awesome that you integrated the original cluster into your build!
Old Dec 29, 2019 | 02:36 PM
  #120
jazzdadss's Avatar
Car: 1989 IROC LSX
Engine: Swapped LS6 Forged by LME
Transmission: 4L65E
Awesome Work!
