Just bought 1992 trans am
Old Dec 7, 2008 | 04:16 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
im wondering if the car i bought was worth it.
its a hardtop 92 trans am rolling chassis
used to be a l98 car
has all the tpi fuel injection parts
Speed density car
ws6
all new suspention parts
new tires
700r4 with shift kit
it does have the wrong hood on it(but i like it)
my dad thinks im stupid for buying it for 600 bones
Old Dec 7, 2008 | 04:21 PM
bigbird89's Avatar
Car: 86 Firebird
Re: Just bought 1992 trans am
That's nice! Good score for 600, for sure. I think that's a great color and it looks clean and straight. Good luck installing an engine/trans - it should turn out to be an awesome car.
Old Dec 7, 2008 | 04:23 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
thanks for kind words. I have a built 327 just sitting in garage and i want to slap a tpi setup on it so i can retain fuel injection
Old Dec 7, 2008 | 04:29 PM
91z 2 8's Avatar
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
If its built dont use the stock TPI setup lol what you lookin at useing a HSR Or something else?
Old Dec 7, 2008 | 04:59 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
well im thinkin bout using the tpi for now so i can drive the car and then upgrading to slp eunners and such. then, when i can afford the HSR or gm mini ram ill go that route.
The 327 isnt a monster but good for mid to low 12's with good heads. I ironically have a set of 083 l98 iron heads on the 327. I just want the car to run and drive. If it runs faster than my buddies blistering 13.4 lt1 6spd car ill be happy
Old Dec 7, 2008 | 07:47 PM
87_GTA_5.7's Avatar
Car: 1987 Pontiac GTA Trans Am
Engine: Basic Stroked SBC..383
Transmission: PerformaBuilt 700R4 3000 Stall
Axle/Gears: Moser 9in. 3:70s
Go Carb man..it will make it so much easyer to finish and less wires..much cleaner look also. Carbs are not bad if you know what your doing when jetting and tuning..
Old Dec 7, 2008 | 09:12 PM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
stay fuel-injected
Nice buy....never seen a gray 92 GTA before
Old Dec 7, 2008 | 09:16 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
Originally Posted by avro206
stay fuel-injected
thanks and yes im staying fuel injected. I have had more problems with carb on my 85 trans am ive had enough.
I have to buy front drive accessorizes for my car also.
and i have checked and triple checked that its a 92 trans am. One of lowest produced cars due to hype over the 93 trans am.
so ive got 1 of 950(ish) made trans ams for 92
I cant wait to get it home and start putting it back together with my 327
Old Dec 7, 2008 | 09:24 PM
webeeZ28's Avatar
Car: 1992 Z28 L98 G92
Engine: 5.7 350 B2L
Transmission: 700 R4
It looks like you made out for $600. Is that just surface rust on the driver's side roof?
Old Dec 7, 2008 | 09:38 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
yes its very light.
big thing im actually excited about is the airbag and 4 wheel disc brakes
i know for a while my poor 327 is going to be choked down with the tpi, but im going to make this fuel injected car work
Old Dec 7, 2008 | 09:56 PM
ND4SPD86's Avatar
Car: 87 Buick Regal T
Axle/Gears: 2.56 blah
Nice buy For $600. I gave $500 for my 91 GTA I just wish mine was a hartop.
Old Dec 8, 2008 | 12:31 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
i did find out today i need pretty much everything for the front of the motor like the big aluminum brackets and such
Old Dec 8, 2008 | 01:35 PM
Camaro Z Man's Avatar
That was a great buy. The wheels and tail lights are worth more than $ 600 if they are in good shape. And yes keep it TPI. Carbs are a thing of the past.
Old Dec 8, 2008 | 03:38 PM
bigbird89's Avatar
Car: 86 Firebird
You should be able to find a complete accessory setup from a wrecking yard. Pretty sure a 305 or 350 tpi car will have what you need. It will be much easier to find a relatively complete donor engine than to try and piece it together yourself.
Old Dec 8, 2008 | 05:36 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
even a tbi v8 serpentine bracket will work,they're the same so yeah,a junkyard score should be pretty easy.
and toyota h8r, Glad to hear you sticking with the TPI!
and let your dad know that,you could probably EASILY triple your money back if you decided to just part it out.The wheels,taillights and wing alone are pretty sought after pieces,not to mention the gfx.(esp. if you have the front fender pieces)Trust me!I have bought all the parts listed above except the wheels and spent way more than 600!lol!
Take a browse at my photobucket album if you want to see how that car could look with a little TLC! and alot of time
Old Dec 8, 2008 | 05:39 PM
avro206's Avatar
Car: 89 Formula
ack do not part it out---92s are rare enough as it is!
Old Dec 8, 2008 | 09:13 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Did $600 buy the sweet minifridge in the passenger seat too? LOL
Old Dec 8, 2008 | 11:34 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
hey easy now! :P
no its a mircowave.
but i found something that i was put into shock....a FREAKING aluminum driveshaft!
Between 4 wheel disc's
aluminum drive shaft
ws6 suspension
and other stuff i think it was well worth 600 bux
i would never let this car go.....its my baby
im having a member tune the car sometime. If he can make my car runs as good as his 383 tpi car......ill be ecstatic
327+tpi+stalled 700r4 = hmmmmm
i know.....i know....i need alot of aftermarket things to take advantage of tpi on a 327 sbc......but right now it will serve me FINE
Old Dec 9, 2008 | 07:38 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I wouldn't even bother "upgrading" the TPI. Just got straight to an HSR or some other intake. The runners alone, unless used, will put you near the price of the whole HSR intake.
I like that body style.
Old Dec 9, 2008 | 11:54 PM
ws6jim's Avatar
Car: 1999 Firebird Formula
Transmission: Stalled 4l60e
Nice pickup I got a "now" running complete 91 GTA over the summer. Dad was against it at first too. But the trailer showed up LOL.
How many miles on the chassis
I like the color. Stay TPI and work within your means. Aluminum ds is a common upgrade from late model 4th gens. It seems like the car was in a transition stage.
Sell the mini fridge to prove to dad you can recoup money right away on the car if you needed it! Good luck and keep us updated.
Old Dec 10, 2008 | 12:39 AM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
I am planning actually to use a LT1 intake converson for my car. A friend is willing to give it to me for all the work ive done on his 84 trans am and his 95 trans am.
im just looking right now for someone to do all the conversion stuff to the intake and the other things i need like the fuel line conversion things
Old Dec 11, 2008 | 06:33 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
an lsx swap would be sweet
Old Dec 11, 2008 | 11:33 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
yes it would....but prices of ls1's
ill rock my 333ci sbc using world product heads and lt1 intake for now
and no 333ci is not a misprint
Old Dec 12, 2008 | 12:40 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Then try an LM7 for starters. $700 for a complete 5.3 w/ harness and computer is hardly astronomical.
That's what I'm doing.
Old Dec 12, 2008 | 08:06 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
most 5.3s are rated at 270-300hp stock. With headers that probably goes up a bit, but swap headers are outrageously expensive. you'd also need motor mounts which aren't too bad. I think an f-body or GTO pan will fit? bah, i might as well stop now, i'm sure there are stickys about this in the motor swap forum.
Old Dec 12, 2008 | 08:15 AM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
hey wow, nice find! you sure got to keep that 92 together and get it back on the road i agree, good idea on keeping it FI.
nice catch!
Old Dec 12, 2008 | 08:42 AM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Transmission: Built 700R4
Axle/Gears: Unknown 9 Bolt Posi, 3.73s
Nice buy, color is sweet!
Old Dec 12, 2008 | 01:15 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
ahh yes thanks for reminding me lol
im hoping my lil 333ci setup with lt1 intake makes more than 300hp
im looking at some world product sr heads local for good price.
lt1+WP heads+333ci=350 hp????????
Old Dec 13, 2008 | 02:05 AM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
I would have bought that for 600 bucks anyday gunmetal gta ftw looks like a fun project
Old Dec 13, 2008 | 02:26 AM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
i wish it was a GTA though....im not sure why 99% people i know that see the car call it a gta lol......
on paper it might not be a gta, but everyone thinks it is so oh well.
(BUT im not fake badging it to look like a gta)
Old Dec 13, 2008 | 02:35 AM
ND4SPD86's Avatar
Are you going to get a Trans hood to put on or stick with the one that is on there?
Old Dec 13, 2008 | 11:48 AM
I just assumed it was one cause I don't think Ive ever seen a 91-92 gunmetal ta hmmmm
Old Dec 14, 2008 | 01:38 AM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
stick with this one until i can afford a 96-97 lt1 stlye ram air hood. On these cars i love the look of that hood. Plus, it would have function for my tpi
i did find out the car is a true WS6/l98/g80 car
Old Dec 14, 2008 | 03:54 AM
ND4SPD86's Avatar
I like that hood too I plan use one on my 91 after I done with an LSx swap in my car
Old Dec 17, 2008 | 05:46 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
600 isn't a bad deal at all. If all else fails, it's easily worth over $600 in parts, the wheels alone should be worth around $400. The 91-92 T/A tail lights are worth a good amount too, as is the spoiler.
Old Dec 17, 2008 | 06:59 PM
ownor's Avatar
Engine: LS1 / L03
wow, makes it even nicer. i'd be curious as to know how many gunmetal 92 TAs they actually made with these options not a whole lot i suppose.
Old Dec 17, 2008 | 09:54 PM
19CAMARO85's Avatar
Car: 1979 Z28 / 1990 RS
Engine: Matching 350 / 305 TBI
Transmission: Built TH350, 3000 Stall / 700r4
nice find man thats gonna be an awesome trans am. Wish i could get a deal like that. Keep us posted -Matt
Old Dec 18, 2008 | 12:45 AM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
yah i only know of 1 other gunmetal t/a like mine and hes on this site. I know there are more out there....but i havent seen them.
only thing im kinda bummed out that the car doesnt have a 9 bolt BW rear end and the stock radio is gone
i do want to find a stock cd player for the car...its that or a newer delco from a truck or newer trans am.
finding the 90-92 tpi parts is a nightmare though......i mean its only until spring when i start playing with it then i will have enough money saved up to do the lt1 conversion along with world product sr heads
Old Dec 18, 2008 | 06:11 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
I'll likely be removing the stock tape player out of my '91 TA. It works perfectly, want that? LOL
Old Dec 18, 2008 | 11:28 AM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
no thanks
im trying to find a stocker cd player so my car is stock inside. I love the look of the car but the newer pioneer tape player looks out of place. It rocks out loudly as i wish......just doesnt look like it should be in a trans am
Old Dec 18, 2008 | 12:49 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
car is cleaning up well
and i thank everyone for the kind words
Old Dec 20, 2008 | 09:51 PM
  #42
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
i was gonna ask and forgot. Why did the pevious owner take the engine out and where did it go?
Old Dec 20, 2008 | 09:58 PM
  #43
LB9Iroc87's Avatar
Car: 1987 Iroc-Z28
Axle/Gears: G92 3.23, G80, J65 disc
the wheels and tires and worth what you got it for, nice score man. any idea what the plans for it are gona be????
Old Dec 20, 2008 | 10:10 PM
  #44
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
well, i forgot to tell that one. Guy bought the trans am for 3000. It had a VERY built 355ci tpi motor running the SD setup. The owner before the guy i bought it from had it setup(according to TPIS plans motor wise to run well into 11.80's) But, guy got a divorce before and had to sell before breaking in the race motor. The driveline never would of stood a chance anyways. But the guy i bought it off took the motor and ecu(didnt take harness) and dropped it in his 01 xtreme. Its a badazz motor. So im left with a roller minus engine and ecu(thats it)
the plans are currently to drop my 327 setup in it and running tpi. Then when money is more liquid, im doing a lt1 intake conversion and world product sr head swap. Then, ill be looking in to doping a t56 swap. Then, by summer time ill be re-painting the car the stock gunmetal grey.
BUT for now its stock tpi setup/700r4 mild built
wish i could get a roller 1-piece 355 or something....but im wanting different so 327ci and lt1 intake should be fun
Old Dec 21, 2008 | 07:26 PM
  #45
89GTAFirebird's Avatar
Car: 89 GTA
Engine: 5.7 TPI
Axle/Gears: stock
Good buy. I would go carb for now. enjoy it then go FI later if you want.
Doug
Griffin, GA
Speed density car
ws6
new tires
Old Dec 21, 2008 | 07:55 PM
  #46
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
Doug
Griffin, GA
sorry, ive had 2 carb'd 3rd gens and never will go back unless its a full built race car at 1/4 track. Then again ill prolly run a FAST injection BBC setup.
fuel injection nightmares of tuning and such are SO MUCH better than carb. Carb is dying thing and hope it dies out all the way. As much as i love my edelbrock 750cfm carb on my lifted 4x4 454bbc truck.......id go mpfi if i could.
and the 600cfm holley on my 85 trans am is great but it has its drawl backs
Old Jan 6, 2009 | 06:33 PM
  #47
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Nice looking car. Always loved the 92s.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
1992 Trans Am
Aug 9, 2015 04:32 PM
