84 T/A Project Car
Old Nov 17, 2010 | 08:21 PM
Keegan84's Avatar
Car: 84 trans am
Engine: 350 bored .020 over
Transmission: TH350 w/ stage 2 B&M shift kit
Axle/Gears: 9 bolt/3.27
84 T/A Project Car
I recently purchased this car as a project to restore to semi original but still customized with my own style..anyways onto the pictures..
This was right after it came off the tow truck. Pretty solid and almost no rust.
This is the 350 that is in it, it has a slight knock and I'm still unsure whether to rebuild it or just swap another engine in.
I'm on a limited budget but I will continue to upload pictures as I get more done. any and all input is welcome too.
Old Nov 18, 2010 | 07:18 PM
maks10's Avatar
Car: 1990 Trans Am
Engine: 5.7 350 HSR afr195 xfi268
Axle/Gears: 3.08 posi
Re: 84 T/A Project Car
good to see no top cut to the fuel pump!!! looks like a solid project...is that the original engine or was it swapped in??? Anyways good luck with it and hope to see it brought back to life !!!
Old Nov 18, 2010 | 09:47 PM
Keegan84's Avatar
Car: 84 trans am
thanks, and the engine isn't original the previous owner dropped it in..He was definitely not a mechanic or electrician to say the least lol.
Old Jan 8, 2011 | 05:54 PM
Keegan84's Avatar
Car: 84 trans am
After months of procrastination, I finally get some work done.
#1 driver side and passenger side floorpans.
#2 rear
#3 Passenger side wheel well.
Attached Thumbnails 84 T/A Project Car-both-floorpans.jpg   84 T/A Project Car-rear.jpg   84 T/A Project Car-passenger-wheelwell.jpg
Old Jan 12, 2011 | 05:26 PM
Keegan84's Avatar
Car: 84 trans am
After a snow day a lot of work gets done.
1. The front carpet finally in and bolted down
2. I don't even want to know what the guy before me was trying to do with this wiring, he had it wrapped in duct tape and hanging under the dash.
3. Just realized these recaro t/a doorhandles..too bad this isn't a recaro..
Attached Thumbnails 84 T/A Project Car-front-carpet.jpg   84 T/A Project Car-wiring.jpg   84 T/A Project Car-doorhandles.jpg
Old Jan 12, 2011 | 08:30 PM
maks10's Avatar
Car: 1990 Trans Am
^better to have duct tape vs black/burnt wires under there....lol.....lookin good
Old Jan 12, 2011 | 09:01 PM
Keegan84's Avatar
Car: 84 trans am
Yes I guess this is true, I'm still collecting the interior plastic parts but I have the seats. Also do you think I should change the seatbelts to match the black or keep them to match the door inserts?
Old Jan 14, 2011 | 12:47 PM
IROC#1's Avatar
Car: 1988 IROC Z
Engine: 5.7 litre
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
No fuel pump in the tank on a carb'd car.
Old Jan 14, 2011 | 06:43 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Not necessarily true.
Old Jan 15, 2011 | 01:20 PM
84transamdude's Avatar
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
yeah that carpet was looking rough. good job.
Old Jan 15, 2011 | 07:10 PM
Keegan84's Avatar
Car: 84 trans am
Thanks, can't wait to get the interior all together..
Old Jan 28, 2011 | 02:35 AM
howesbird's Avatar
Car: 1988 Pontiac Firebird
Engine: Pontiac 400
Transmission: 4L80e
Wicked good job on the floor boards!!!
Old Jan 28, 2011 | 01:01 PM
Keegan84's Avatar
Car: 84 trans am
Thanks , I should have all the interior in within a week or so, painting plastic interior sucks..So look out for interior pictures soon!
Old Jan 29, 2011 | 08:31 PM
Keegan84's Avatar
Car: 84 trans am
Got all the front interior in but still need to clean it up a bit. Next step rear interior.
Old Feb 13, 2011 | 08:14 PM
Keegan84's Avatar
Car: 84 trans am
Got the engine out this weekend with the help of a crane and some relatives/friends. Only bad thing is I learned the engine was junk >.>
Old Feb 19, 2011 | 05:57 PM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
It sucks that the engine was junk.
But it's lookin' good so far. I can't wait to see the finished product. I really like the early third gens.
Old Feb 20, 2011 | 08:41 PM
Keegan84's Avatar
Car: 84 trans am
Got a running engine for the car, it supposedly ran before it was pulled *crosses fingers*
Any opinions on the blower? I'm thinking about buying a flat hood and cutting a hole in it. Still undecided.
Attached Thumbnails 84 T/A Project Car-2011-02-20_19-21   84 T/A Project Car-2011-02-20_19-58
Old Feb 23, 2011 | 09:37 AM
maks10's Avatar
Car: 1990 Trans Am
ehh, eventually just to match...(sorry for late reply)...didnt even think carberator and no fuel tank fuel pump
good to see its coming along ... didnt think i saw stats on new engine????
Old Feb 23, 2011 | 11:24 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
that thing with 3 holes is not a blower. its a fake injector hat, sometimes called a bug catcher. In my opinion anything fake like that is stupid and has no place on a thirdgen.
Where in northern Indiana are you?
Old Feb 23, 2011 | 03:49 PM
Keegan84's Avatar
Car: 84 trans am
Thanks, I don't technically have the stats on the new engine. We pulled it out of an old chevy show truck that has been sitting for a year or two. We aren't sure if it runs but the exhaust holes were chalky, the spark plugs were dry and the rear main seal wasn't leaking so hopefully I can just drop her in and go. I think it has some aftermarket parts in it. Still not sure because it has all aftermarket bolts in it, chrome hose covers and looked like someone put some money into the engine at one time. I would pull it apart and see but I don't really have the money to pour into it at the moment.
Yeah I understand it technically isn't a "blower" but ya catch my drift and I guess its just a matter of opinion. I'm located in the Michigan City area.
Old Mar 10, 2011 | 09:19 PM
Keegan84's Avatar
Car: 84 trans am
Finally decided to pull the engine apart and research codes. Its a 96 crate 350 Goodwrench 4 bolt main. For now I'm just replacing all gaskets, rods and mainbearings. I will post and update if there is anymore damage the farther I dig.
Old Mar 13, 2011 | 11:17 PM
Keegan84's Avatar
Car: 84 trans am
Finally got the engine to the bare block. Everything looks good just going to replace all the bearings, gaskets, rering kit and timing chain for now. Might upgrade the pistons for a higher compression ratio. Its 8.5:1 right now but I would like 9 - 10:1 ratio. Anyone know any good pistons for a older 350? It has 4.00 in. bore and a 3.47 in. stroke and 76cc chamber heads. I also thought about upgrading the cam but it already has a low end torque cam in it which is what I want.
Attached Thumbnails 84 T/A Project Car-670.jpeg   84 T/A Project Car-2011-03-13_17-23   84 T/A Project Car-2011-03-13_17-24
Old Mar 14, 2011 | 02:58 PM
Daytona_83's Avatar
Car: 1983 Pontiac Trans Am "Daytona"
Engine: LG4 305 V8
Transmission: T5 5-speed
Nice resto job! Car does look pretty solid. Good to see more early 3rd gens here Also, I wouldn't use that hood scoop thingy...that would totally ruin the car and would look more "trailer trash" than the 3rd gen already does. But it's your car, so do what you want. Just trying to keep the car looking more original.
Old Mar 14, 2011 | 10:18 PM
Keegan84's Avatar
Car: 84 trans am
Thanks! Its taken a lot of work and time and I can't wait to get it on the road.
Yeah I have since decided against using it. Not that I think it would look all that bad, but its the time and money I have to put into it. Also there would be no guarantee I would like it.
Old Mar 14, 2011 | 10:27 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
I'd throw those 76cc heads in the recycle bin and get some vortecs. There are also lots of engine math calculators online that will help you pick pistons with the correct compression height and dish volume. Or you can call Summit and they can help you. Even if you're on a budget and have to keep the heads, you can still order pistons that will get the compression up with the lazy heads. I'd shoot for 9.5:1 with iron heads.
Old Mar 15, 2011 | 09:12 PM
Keegan84's Avatar
Car: 84 trans am
Yeah I wanted to change the heads but it just isn't in my budget at the moment. I might go to the junkyard and see if I can get lucky. If not it might just be new pistons. My problem is I'm to eager to get this thing on the road. I'm definitely tired of seeing it sitting in my garage. I want to get on the road lol
Old Mar 16, 2011 | 11:01 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
well if you are planning on running different heads in the future, get pistons that will work with the new heads and just deal with the dismal compression ratio you're going to have with the stock heads.
Old Mar 16, 2011 | 07:16 PM
Keegan84's Avatar
Car: 84 trans am
As of now I don't plan on upgrading the heads. I don't plan on keeping the car for too long either. I want to keep it for a year maybe two and then sell it and buy another third gen. So due to money and time I'm just going to re-ring my old pistons and drop her in.
Old Mar 17, 2011 | 09:57 AM
valicswarrior's Avatar
Car: 1985 Firebird S/E
Engine: SBC 350, mild cam Vortec heads
Transmission: Rebuilt 700R4 vette servo+shift kit
A lot of work done for a one year car imo, and good thing you didn't but the air induction thing on if your gonna sell it in the near future, seeing as most buyers prolly wouldn't like it. If you don't mind me asking why sell a third gen with that much time into it to buy another third gen? If the car is solid i would think it would be safer to do what you want with that car.
Old Mar 17, 2011 | 04:19 PM
Keegan84's Avatar
Car: 84 trans am
Thanks, and I see where you're coming from. I guess my problem is I don't want to dig myself so deep into the car that I can't break even when I sell it. I know the more money I pour into it the longer I'm going to want to keep the car and if I'm ever short on cash I will have to take a giant cash loss. If this was a 2nd gen or older car I would definitely keep it. I guess time will only tell.
Old Mar 20, 2011 | 08:02 PM
Keegan84's Avatar
Car: 84 trans am
So today I ordered a master engine rebuild kit from northern auto parts and upgraded the camshaft to Speed Pro 2000-4500 RPM # CS1013R 214/224 adv duration .443/.465 lift. I'm also going to bore the engine over .020. I will upload pictures when it gets here.
Old Mar 23, 2011 | 05:55 PM
Keegan84's Avatar
Car: 84 trans am
So stoked I got my parts today
The whole kit came with new oil pump, mr.gasket overhaul kit, ring/main bearings, camshaft(Speed Pro 2000-4500 RPM # CS1013R 214/224 adv duration .443/.465 lift), cam bearings, lifters, 8 new pistons .020, .020 rings, timing set, and frost plugs. All for $260 with shipping. Now to get the engine bored over .020
Attached Thumbnails 84 T/A Project Car-2011-03-23_17-41   84 T/A Project Car-712.jpeg   84 T/A Project Car-709.jpeg
Old Apr 18, 2011 | 07:39 PM
Keegan84's Avatar
Car: 84 trans am
**Update**
I should be getting the engine back this week so I'm working on cleaning up the wiring and painting the engine bay. I put the car on jack stands and noticed gas was leaking all over my floor. I now need a new gas tank...Also I was looking at the brake lines and for some reason the guy cut the back brake lines and put new zinc brake lines on the front. I have way more work ahead of me than I expected..
Old Apr 24, 2011 | 12:15 AM
Keegan84's Avatar
Car: 84 trans am
Got the engine back from the machine shop today
I also prep'd the engine bay and just got done finishing painting the whole engine bay. I will upload some pictures of it painted and the engine with in the next week.
Attached Thumbnails 84 T/A Project Car-964.jpeg   84 T/A Project Car-967.jpeg   84 T/A Project Car-2011-04-23_17-16
Old Apr 26, 2011 | 10:01 PM
Keegan84's Avatar
Car: 84 trans am
Finally got the engine bay painted and now I'm putting parts back in slowly.
Attached Thumbnails 84 T/A Project Car-994.jpeg   84 T/A Project Car-997.jpeg   84 T/A Project Car-2011-04-26_20-29
Old May 3, 2011 | 09:44 PM
Keegan84's Avatar
Car: 84 trans am
I have got a lot of work done in the past week or so. I put on all new brake lines, grinded down all the rotors, put on two new rear calipers, flushed the rear end out and figured out my gears are 2.?? I forgot to count the spines so I just rotated the wheels one whole turn and check how many times the drive shaft went around.
I'm undecided on this steering wheel. I like the looks but the padding is falling apart on the inside and is all mushy. I have this GT grant steering wheel that I got from a friend, it was all pitted but I've sanded it down and shined it to look decent again. All opinions are welcome.
Attached Thumbnails 84 T/A Project Car-steering-wheel.jpeg   84 T/A Project Car-grt-1108.jpg
Old May 18, 2011 | 10:29 PM
Keegan84's Avatar
Car: 84 trans am
Finally got the engine painted and 90% together. Now it looks like things are actually getting done!
Attached Thumbnails 84 T/A Project Car-2011-05-17_22-17
Old Aug 12, 2011 | 02:37 PM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
Any updates? I wouldn'tve painted the machined surface of the cylinder head where the manifold bolts onto but that's just me. Looks good man. Keep up the good work.
Old Aug 12, 2011 | 04:06 PM
Keegan84's Avatar
Car: 84 trans am
Yes, there are lots of updates. I just stopped posting because I didn't think I had anyone looking lol. I also didn't mind painting it because I figured its on the exhaust end so who cares.
I have done quite a lot to the car in the months I haven't posted here. I rebuilt the TH350 that was in the car, put in a new gas tank(with lots of problems), put a 9 bolt Borg Warner 3.23 rear-end in the car, replaced the valve covers and valve cover gaskets, did some body work, welded the exhaust together and that's about it.
Since the last post I have put the engine in the car and have almost a thousand miles on it.
Attached Thumbnails 84 T/A Project Car-1069.jpeg   84 T/A Project Car-1119.jpeg
Old Aug 12, 2011 | 04:08 PM
Keegan84's Avatar
Car: 84 trans am
Pictures
Attached Thumbnails 84 T/A Project Car-1106.jpeg   84 T/A Project Car-2011-06-05_10-01   84 T/A Project Car-1122.jpeg
Old Aug 12, 2011 | 04:10 PM
Keegan84's Avatar
Car: 84 trans am
More Pictures
Attached Thumbnails 84 T/A Project Car-1125.jpeg   84 T/A Project Car-1128.jpeg   84 T/A Project Car-1131.jpeg
Old Aug 12, 2011 | 04:15 PM
  #42
Keegan84's Avatar
Car: 84 trans am
I do have future plans for the car but have contemplated selling the car for an older car restoration job. Some things I need to get done are putting in the B&M slap shifter, rebuilding the center console(with a fiberglass type material), rewire the stereo, put a new carb on, put on new rims with some fatter tires,Headers with true dual exhaust and eventually repainting the car.
Still undecided on what I'm going to do with the car for now. If I keep the car this winter I plan on building a mean street/strip motor, new rearend, and new transmission.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Fast355
Dec 2, 2016 06:33 PM
Irocohio
Aug 12, 2015 08:03 AM
bryan623
Aug 10, 2015 11:33 AM
