bought another one!
Old May 8, 2011 | 08:31 PM
talover111's Avatar
Car: 1985 & 1988 trans am
Engine: 350 tpi ; 355
Transmission: 700r4 auto; converting to 6 speed
Axle/Gears: 9 bolt 3:27 posi; 2.73 open
bought another one!
well i found a deal i just couldnt pass up it is a 1988 pontiac trans am it is a hardtop its almost mint inside. its not bad on the outside other than the paint being faded on the roof. it has the digital dash.i will post pics as soon as i can . i am going to take some parts off my 85t/a for this one and then fix the 85 later
Attached Thumbnails bought another one!-0508012014.jpg   bought another one!-0507011730c.jpg
Old May 8, 2011 | 08:57 PM
karl's-92'-z28's Avatar
Car: Too many cars
Re: bought another one!
Niiice
Old Jun 3, 2011 | 07:59 PM
talover111's Avatar
pics added
Old Jun 3, 2011 | 08:58 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
why does the passenderisde front wheel look like its pushed back a lot?
good looking car though, i like the color
Old Jun 3, 2011 | 11:02 PM
talover111's Avatar
because i stupidly took pic where the wheels were turned to the right just slightly and the angle of pic isnt perfect but there isnt anything wrong with it honestly
Old Jun 21, 2011 | 11:03 PM
talover111's Avatar
ok i got 1 minor problem but after sitting 13 years im not complaining. sometimes the headlights go up normally sometimes not at all. sometimes only go part of the way but when turning off there is a grinding noise. is the headlight motor my problem or any ideas ? i havent had the chance to really look into this. and if it is the headlight motor will one from my 85 trans am work in the 88?
Old Jun 22, 2011 | 08:30 AM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
sounds like the gears in the headlight motor, and they should...just look at them close before you start ripping it apart
Old Jun 22, 2011 | 09:42 AM
88TransAmGuy's Avatar
Car: 88' White-Black Trans Am
Engine: Trying to find a motor
Awesome bird! But you know,those wrap around wings are TOTALLY out of style, so i guess i can take it off your hands for ya :P
Old Jun 22, 2011 | 10:46 AM
maroman88's Avatar
Car: 88 Camaro Coupe - 99 Corvette
Engine: 305TPI - LS1
Transmission: A4 - A4
Axle/Gears: 3:73 - 3:15
very nice! the gringing would be the gears in the motors... pop some brass gears in and never look back! as for them doing nothing when u turn them on... could be the switch on the dash, i had an 89 formula and u really had to push the switch hard and hold it so theyd go up, i replaced the switch and that problem went away
Old Jun 23, 2011 | 07:28 PM
talover111's Avatar
well ive looked into it the 85s headlights are a 3 wire plug but the 88s are a 2 wire plug and i was thinking could it be the headlight control module ? i think the switch is ok but ill check it
Old Jun 24, 2011 | 07:16 PM
SpeedDemon91's Avatar
Car: '18 Jeep Wrangler, '19 Honda Accord
Engine: 2.0T in both
Transmission: 8 speed auto, 10 speed auto.
nice!!
Old Jun 25, 2011 | 07:02 PM
talover111's Avatar
problem fixed i went ahead and put 2 new headlight motors in and changed the control module. now i got headlights
GTAman
Jul 3, 2024 07:29 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
pimprs
Aug 24, 2015 11:20 PM
