Trans Am Downunder
Trans Am Downunder
Gday All
New member here from Australia, just picked myself up an 85 Trans Am 305 TPI. will be a while before I start on it as its a project to give to my nephew for his 21st Birthday and well hes only 3 at the moment so its a case of do it right the first time .. also added a pic of my daily driver .. lol
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Re: Trans Am Downunder
Welcome to the board. Always good to have a right hand driver on here.
Car: 1983 Z28
Engine: 385 Fastburn
Welcome to TGO and cool Bird!
And i gotta say...that is one heck of a truck!!! Makes the semi's here in the states look like tonka toys!!
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Welcome. Two sweet rides. You'd think they could have made a right hand drive version of the shifter too with the button on the other side. Looks like you could hang the bird from the bung bars and take it with you! Or find your own "Bandit" to run block for you.
Car: 1987 Camaro LT
Never paid attention to the shiter button. That is a bad place for a right hand drive model. GM could have fixed that issue.
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
shifter was the first thing i noticed as well
Car: 1987 Camaro LT
I'm sure it could have been a simple re-engineering piece or for export cars, use the Camaro shifter ****.
From: Doghouse Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
always thought it would be neat to get a hold of a RH drive for the US... it would really throw some people... I know in Aus, they make it mandatory to switch it from LH to RH Drive...
I noticed the shifter is still on normally (for right-hand thumb operation). Isn't it a bit awkward for you to shift out of park when the thumb lever is still for right-hand thumb operation?
Here's a GTA Notchback that was converted with the shifter turned around so that your thumb can disengage the safety lever:
I'm not sure... but you might be able to flip it around without any problem... Obviously the clip that is in the front would go to the rear so you would be able to see it... I would have to try it...
Gday All
Car: 1987 Firebird Formula
Engine: 355
Axle/Gears: Posi, 3.23
Road trains. They get even bigger than that.
OP, I work for a Mack dealer here in Indiana, just out of curiosity, how many of the Mack Titans do you see around there? Don't see too many here in the States mainly because there's not very many uses for them, but the new Titans are absolute beasts.
The longest I have ever seen here in the states are the 3 container train. They usually are interstate only, in Michigan I have only seen 2 (short) trailers, but in Ohio on the Turn Pike they allow 3. They are not the 110' trailers, but usually the shorter 60' or so.
1992 Trans Am
May 10, 2023 07:19 PM
Hawk312
Aug 22, 2017 08:55 PM
Hello, Michael
Aug 20, 2015 03:19 PM
