Chucks 87 GTA
Old Aug 18, 2018 | 08:36 PM
  #201
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Chucks 87 GTA
When I got around to doing my 91 over I was going to do the same thing with the GFX retainers and do them in stainless. Some flat bar close in width and thickness, cut to length, a few holes and a screw of the appropriate size and tack the screw on the back side to retain it. Bullet nose the screw to make staring the nut in the blind area a little easier, should work like factory, only better and last longer
Old Aug 19, 2018 | 04:56 PM
  #202
jworks's Avatar
Car: 1987 Trans am GTA
Engine: 5.7 liter
Re: Chucks 87 GTA
so, spent the day sanding, so glad I got the compressor, I got basically the back half of the car along with the hood sanded in about 3 hours or so, found a couple of low spots that I didn't even know were there and also discovered that the clear coat on the roof seems to be a LOT thicker than the rest of the car, oh, and my front bumper is fully repaired and sanded. progress is slow, but it's still progress
Old Sep 2, 2018 | 12:50 PM
  #203
jworks's Avatar
Engine: 5.7 liter
Re: Chucks 87 GTA
10B 4/10/87 RW
found this on the driver side side skirt, though it was interesting.
Old Oct 7, 2018 | 02:18 PM
  #204
jworks's Avatar
Engine: 5.7 liter
Re: Chucks 87 GTA
so, been sanding and sanding, removed the side bumpers, dont know of they are going back on or not, kinda like the look without them. still looking for a decent center console and driver side front ground effect. now that im sanding for hours I'm noticing a lot of moisture building up in my air lines, so much so that it's making it past my drip leg and my filter, trying to decide if I need to put a larger drip leg in or another filter, I need to figure it out before I buy paint.
Old Jan 3, 2019 | 12:13 PM
  #205
jworks's Avatar
Engine: 5.7 liter
Re: Chucks 87 GTA
my new driver side ground effect is in the mail as of today, I have all of the metal on the car sanded down pretty well, been working on the plastics in my basement, slow progress since its cold. I found out I have to have the car painted before July, that is when baby #3 will be here and I really wont have any spare time left. reached out to a few people both on here and craigslist looking for a good center console, looking for one close enough so we can pick it up instead of having it shipped. also found out TCP global will mix "custom" colors (i.e factory colors that they do not advertise)
Old May 12, 2019 | 05:47 PM
  #206
jworks's Avatar
Engine: 5.7 liter
Re: Chucks 87 GTA
so my last post stated that I had my ground effect in the mail... it was not the correct one for my car. BUT i DID get the correct one now lol. now that i have a new part and it's not snowing I got some motivation to get back to it, back bumper is now sanded down, there wasn't much clear on it. so question, about paint, what kind of primer or sealer do I need to go over bare metal and body filler? I believe I need to get a sealer then a primer, is this correct? couple of pics of my sanding
cut the bill off the hat to make it more comfortable.
still working on the clear coat
Old May 12, 2019 | 06:04 PM
  #207
jworks's Avatar
Engine: 5.7 liter
Re: Chucks 87 GTA
thank you to dagwood for the new ground effect, only took 2 years to find this but its brand new, I'm stoked
brand new ground effect
Old May 23, 2019 | 09:52 AM
  #208
jworks's Avatar
Engine: 5.7 liter
Re: Chucks 87 GTA
been a while since I've gotten to work on the old bird, she's decided to squeal like a stuck pig every time I turn the key now, once she warms up it seems to go away. my daughter helped me to clean up my headlights and the front bumper honey comb, something minor but its bothered me since day one, just never been high enough on my priority list to mess with it. I'm hoping to get my primer next week (?), I'm at the mercy of the USPS and the guy sending me my check, once that get here I think I'm going to primer pieces individually the put them on the car before I spray the base, this seems to be the way everyone suggests spraying metallic colors. I did discover out of all things that 2 of the screws holding my driver side headlight are incorrect, and of course the clips are messed up as well, one of them is a 12mm head instead of a 10 and another one is a course thread. I need to find these while I'm thinking about it, if only there was a place to find random third gen parts...
Old May 23, 2019 | 05:36 PM
  #209
kenferrell's Avatar
Car: 1985 T/A
Engine: 5.0L
Transmission: Manual
Re: Chucks 87 GTA
Keep up the good work I look forward to seeing the finished project
Old May 24, 2019 | 07:22 AM
  #210
zman1969's Avatar
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
Re: Chucks 87 GTA
X2 cant wait to see it painted I like this color- alot
Get R Dun!!
Old Jun 7, 2019 | 10:04 AM
  #211
jworks's Avatar
Engine: 5.7 liter
Re: Chucks 87 GTA
ok so I've been researching this for a while and cant seem to get an exact answer so maybe I'll throw it out here and see if someone *cough* tibo *cough* can answer it. I think I think I'm correct in this-
epoxy primer on all metal (not sandable, used as a sealer (reduced more) to protect the metal and the new paint from possible bleed through).
high build primer on top of that ( can use in only problem spots to help even out scratch marks ect).
put the car back together??
base coat (KISS and follow directions on can)
clear coat (refer to previous)
BUT my question is, if I spray primer on all of the parts before I put it back together what are the chances that the paint will be able to get in all of the creases to cover everything? and what about areas like the mirrors which have that gasket? I don't want to paint the gasket, so do I paint the mirrors separately the put them on after the body is painted? I plan on buying at least the epoxy this weekend but might wait til I get a better ling term plan with these questions answered.
Old Jun 8, 2019 | 09:59 AM
  #212
jworks's Avatar
Engine: 5.7 liter
Re: Chucks 87 GTA
so, there are a few little things that have been bothering me, when I recovered my headliner I didn't do a great job, but its "ok?" I guess... kinda, but I cut to much out of the corners so some of the foam shows, I've been debating on whether to try to recover it again myself (I still have enough to try 1 more time) and my visors keep falling. a buddy of mine has a 4th gen Camaro and he put in a visor delete, so I'm gonna try it out, it was only $15 on Amazon l, so i figured if i dont like it it's not a huge deal i guess
sun visor delete
its billit aluminum, I sanded, primed and painted it black.
Old Jun 8, 2019 | 07:03 PM
  #213
jworks's Avatar
Engine: 5.7 liter
Re: Chucks 87 GTA
so the visor deletes are just a hair smaller than the actual mounting spots for the visor, not exactly what i wanted, hawks has them too but they are more than twice what I paid, hopefully a better fit though. maybe if I like it I will order those ones when I order the new headliner. I finally spent the time to look into why my windshield washer didn't work, check valve was clogged, then I broke it in half...
also guide coated all of my really bad spots on the body, only 1 spot came up as still needing fixed
I went to buy my epoxy primer, internet said open til 4, door to the shop said open til 1... I showed up at 130.... no problem I'll go up to napa and buy more touch up paint, awesome... it didn't match... not even close. the only upside today was that I got the correct screws from firebirddude installed. small win I guess
Old Jul 6, 2019 | 03:15 PM
  #214
jworks's Avatar
Engine: 5.7 liter
Re: Chucks 87 GTA
so I got my primer after talking with a big paint shop by where I work they all suggested sherwin William's paint, specifically the sherwin William's that they use, they guy there was super helpful, he said I can come in anytime with questions ect, absolutely awesome.
btw, had a baby 2 weeks ago, that kinda takes up a lot of time.
Joshua Charles
after reading one of the other threads on here I decided to just take the plunge and start priming, the primer goes a LONG way, I was only going to do the front bumper, rear ground effects and fender ground effects but I threw in the side skirt, and probably had enough to do the other ground effect but it wasnt clean.
started priming
Old Jul 6, 2019 | 07:03 PM
  #215
jworks's Avatar
Engine: 5.7 liter
Re: Chucks 87 GTA
amazing how once it's all one color how many little pin holes you find...
Old Jul 9, 2019 | 08:20 AM
  #216
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: Chucks 87 GTA
Congrats on the baby boy!
Old Jul 9, 2019 | 07:47 PM
  #217
jworks's Avatar
Engine: 5.7 liter
Re: Chucks 87 GTA
thank you, as if things were not going slow enough on the car, he one more little thing to spend my time on, but it's time well spent
Old Jul 10, 2019 | 06:37 PM
  #218
jworks's Avatar
Engine: 5.7 liter
Re: Chucks 87 GTA
back bumper sanded with 240 then with 400 grit. it will be primed this weekend. I didnt find any issues with it but it seem as if primer brings out all of the flaws...
back bumper sanded
I also plan on recoating the front bumper and driver side ground effects, and first coat the passenger side and all of the smalls. if all goes to plan maybe do the body 2 weekends from now?
Old Jul 10, 2019 | 06:54 PM
  #219
jworks's Avatar
Engine: 5.7 liter
Re: Chucks 87 GTA
my three year old doesnt like the compressor, but he does like his cheese pups
Old Jul 12, 2019 | 02:06 PM
  #220
jworks's Avatar
Engine: 5.7 liter
Re: Chucks 87 GTA
I found the source of my squeal, apparently this bolt is fairly important
missing alternator bolt
Old Jul 12, 2019 | 04:32 PM
  #221
jworks's Avatar
Engine: 5.7 liter
Re: Chucks 87 GTA
so I got both of my bumpers, side skirts and all the little extras primed today. it seems like in going to have to adjust my gun every time I use it, last weekend it was great, this time it seemed like it wasn't getting enough paint, or to much air, I was having a lot of dryfall (not sure if that's what its called in automotive painting, but in house painting that's what its called).
I plan on taping off the car starting tomorrow and hopefully I can do the body next weekend. I think I'm going to paint all of the unseen areas with my single stage then put it back together (loosely) then whenever I get my paint (it's super expensive lol) I can do it all together as I've read you want to paint metallic oriented as it will be on the car. so it's getting close.
on another note, I rerouted my radiator and overflow lines to make my intake sit a little better.
Old Jul 26, 2019 | 08:10 PM
  #222
jworks's Avatar
Engine: 5.7 liter
Re: Chucks 87 GTA
ready for primer
so getting the car ready to prime, I got all of the hidden bits painted with single stage, still need to prime the mirrors and do the final coat on the front bumper.
Old Jul 27, 2019 | 09:53 AM
  #223
jworks's Avatar
Engine: 5.7 liter
Re: Chucks 87 GTA
so
primed : )
I did a thing today...
I was planning on doing this sunday, but i was up early and everyone was still in bed so i just went for it. Igot some hairs and dust in it but it needs to be sanded before I paint anyways so it's no big deal. it's at least all 1 color now. and now I can put it back together and drive it til I get thr money together for the paint.
Old Jul 27, 2019 | 07:24 PM
  #224
jworks's Avatar
Engine: 5.7 liter
Re: Chucks 87 GTA
so the whole car is is primed and I'm working on getting it all back together, I got the back bumper, rail lights, rear side markers, and rear ground effects, passenger side mirror and lock back on. I WILL be able to drive this by next weekend... legally that is.
Old Jul 29, 2019 | 06:43 PM
  #225
jworks's Avatar
Engine: 5.7 liter
Re: Chucks 87 GTA
almost complete again
so spiler is on, passenger side handle, lock, side skirt all on, driver side lock is on, need to get speed nuts for the driver handle, 2 more for the front bumper and 2 screws for the spoiler. I'll put the door panels back on but they really need to be replaced.
Old Jul 31, 2019 | 05:08 AM
  #226
jworks's Avatar
Engine: 5.7 liter
Re: Chucks 87 GTA
so apparently I lost the new lock/ unlock buttons I ordered god knows how long ago, so I gotta reorder those, but the bigger problem is that i think i like the matte gray better than the shiney sparkley red... I may look into doing a complete color change, under the hood, hatch door jambs ect and paint it matte gray.
Old Jul 31, 2019 | 07:19 AM
  #227
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Re: Chucks 87 GTA
;When I lose parts it always helps to look for a DIFFERENT part, then I find other stuff I was missing or forgot I had
Old Aug 2, 2019 | 06:59 PM
  #228
jworks's Avatar
Engine: 5.7 liter
Re: Chucks 87 GTA
that's exactly what happened! but not exactly the way I wanted it to... looking for the switches I found my socket wrench I lost like 2 years ago.. apparently there is a neat little pocket right behind the radiator to hide tools in...
Old Aug 2, 2019 | 08:05 PM
  #229
jworks's Avatar
Engine: 5.7 liter
Re: Chucks 87 GTA
took the bird and the kids out for a cruise, no more hole in the door, no more squeaks, no more missing spoiler, no more squeal, no more headlights.... wait. welp I know what my next project is... oh and i need to finish putting it together
im in love...
Old Aug 2, 2019 | 11:30 PM
  #230
NoEmissions84TA's Avatar
Re: Chucks 87 GTA
On the road is ON THE ROAD. Wish mine was. Someday.
Old Aug 4, 2019 | 09:06 AM
  #231
jworks's Avatar
Engine: 5.7 liter
Re: Chucks 87 GTA
got my new lock/unlock switches in the mail yesterday, found my original ones I ordered today... also drove the car again today, gonna try to wash it a bit when I get home
Old Aug 5, 2019 | 02:16 PM
  #232
SteelDirigible's Avatar
Car: 84 Berlinetta
Engine: LR4
Re: Chucks 87 GTA
Car is looking good, even in primer.
Just noticed you're in Cincy. I'm up that way most weekends.
Old Aug 6, 2019 | 10:11 PM
  #233
dagwood's Avatar
Top Answer: 1
Car: 1986 Camaro Drag Car
Engine: 383 on Ethanol
Transmission: Automatic
Re: Chucks 87 GTA
Ha! I just now saw this post! And you're welcome! You would have probably NEVER found another brand new, factory ground effect lol.
Old Aug 7, 2019 | 06:35 AM
  #234
jworks's Avatar
Engine: 5.7 liter
Re: Chucks 87 GTA
Hey may I give credit where credit is due lol
Old Aug 13, 2019 | 04:24 PM
  #235
jworks's Avatar
Engine: 5.7 liter
Re: Chucks 87 GTA
so I previously posted (I think) that everyone, myself included likes the flat gray, even though it's just primer, but this got me thinkong about doing it 2 tone, probably breaking all sorts of rules and customs and laws and what not but I'm thinking going back to the flame red on top and keeping the flat gray on the bottom, or vise versa... any input?
possible paint combo?
Old Aug 13, 2019 | 09:37 PM
  #236
dagwood's Avatar
Top Answer: 1
Re: Chucks 87 GTA
Well bud, I really think you'll like it a lot more if you painted it like this....
Old Aug 13, 2019 | 11:13 PM
  #237
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: Chucks 87 GTA
Primer looks good by comparison from where you began, but primer does not look good. Paint that baby and it's going to look fantastic!
I'd stay away from the bright cheerful colors like my car. Your color combo will look real classy with a darker, rich color. Two-tone is sooooooo 1980's. The more simple it is the classier it will look.
Old Aug 14, 2019 | 09:56 AM
  #238
jworks's Avatar
Engine: 5.7 liter
Re: Chucks 87 GTA
just for clarification I was not going to leave it primer, the plan would be get a gray or silver thr use a flat clear coat over it, I hear flat is a pain to maintain though...
Old Aug 14, 2019 | 05:27 PM
  #239
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: Chucks 87 GTA
Old Oct 23, 2019 | 04:26 PM
  #240
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: Chucks 87 GTA
I agree no lol but one satin color I do like which I really don't like until I seen this one
and only one I have really like
Old Jan 21, 2021 | 01:36 AM
  #241
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: Chucks 87 GTA
Got any updates?
This is one of my favorite threads of all time. It's got so much heart and soul in it.
Old Jan 21, 2021 | 05:22 AM
  #242
jworks's Avatar
Engine: 5.7 liter
Re: Chucks 87 GTA
Unfortunately not really on the car. I got a promotion at work, I have a third kid now, the car has to be painted by June though, it's gonna be in a wedding.. My little sister (Chuck's only biological child) is getting married and instead of a limo she wants to be escorted to the wedding by me in the firebird, weird but kinda neat I guess.
June 2020
I installed new door handles when I painted it, then about 2 months later broke the driver side, they are made of a cheap
Pot metal, I need to replace it but I don't want to pull my door panels off again til I have new ones to install, the ones that I have are pretty flemsy and I don't know if they will make it through another removal.
I need to make time to get the little odd and ends wrapped up (center console, new door handle again and new door panels) and get it painted.
Old Feb 7, 2021 | 11:02 PM
  #243
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
Re: Chucks 87 GTA
Definitely get the paint on! It's not good to let the primer absorb stuff indefinitely.
That progress will inspire you and others. I always suggest a factory color - you can add your own flair to it, but start with factory color as a base to build on. I went with three coats of clear and factory red (Heis Specker). Go for shiny and learn how to wash without swirls (detailing 1001).
Factory vs Solid (same red):
Old Feb 9, 2021 | 07:20 PM
  #244
stuartswede's Avatar
Car: 1983 Trans am, June 2022 COTM
Engine: 305 Cross Fire Injection
Re: Chucks 87 GTA
Great story, thanks for sharing!
Old Nov 8, 2021 | 02:31 AM
  #245
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: Chucks 87 GTA
So was there a wedding??? Got me all hooked on this story now!
Old Nov 8, 2021 | 08:15 PM
  #246
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Chucks 87 GTA
Great story, excellent work saving it and its a C&C car.
shr00m
Oct 3, 2018 01:22 PM
Jbuchanan
Members Firebirds
24
Jun 20, 2018 06:23 AM
DD9TransAmGTA
Members Firebirds
Jul 13, 2014 10:55 PM
devianb
Nov 3, 2005 11:53 PM
FruityOne
25
Jun 17, 2003 04:12 PM
