"it" has begun....
#106
Engine: 4++,350 & 305 CIs
Re: "it" has begun....
It's the battery box. I may have done it differently than SLP did but this is how they did it for the Firehawks
#109
#111
Made my own rear seat delete covers.
NOS tri-y header install kit and a few other SLP goodies
NOS Tri-Y headers, Ypipe and cats
#112
NOS SLP tri-Y headers
Original fuelpump and dual end pickup used with 89ish and up cars
Racetronix is my go to for replacement pumps
Repop T-ram brackets
Some of my cam collection
Lot of cleanup and detail yet to go back here
#113
Original Firehawk tires
Bolt in roll bar painted
Interesting strut tower brace I've seen on several cars
Aluminum for the hubs and caliper brackets
rear seat delete
Single cat and 89-91.5 N10 SLP totl intermediate pipes
rear seat delete
#115
New fuelpump install
Dual cold air trial fitting
NOS front bumpercover and aluminum hood
#116
dup
#117
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I want that PONTIAC sign!! Can you put me in your will? You have a lot of cool stuff I think I deserve
TTOP350 (03-15-2023)
#118
Car: 1991 Camaro Z28
Engine: 5.7L
Transmission: 700-R4
Love the those Tri-Y headers, Also is their a difference in the front bumpers from a hawk and a stock one?
#122
Axle/Gears: 10 Bolt 2.73 Open
So much cool stuff Tony! Thanks for sharing the photos.
So I'm following along pretty well....but what are the aluminum boxes on the floor behind the front seats?
Is the Racetronix pump what was originally used, or an equivalent?
Passenger strut tower to rail brace...I thought that was an IROC only thing. Under what conditions did the Firebirds get them?
#123
So I'm following along pretty well....but what are the aluminum boxes on the floor behind the front seats? Rear seat delete parts that cover the body colored seat bracket.
Is the Racetronix pump what was originally used, or an equivalent? Racetronix is just the replacement I used.
#125
The base bird and formula bumper cover has a plastic insert that covers the empty spot where the fog lights would go. So if someone wanted to add fog lights, they can with very little work. I have a NOS set of the inserts.
#127
workbench/storage shelf/ catch all...
Fun fact of the day, the aluminum hood has different part numbers for the hood struts and popup spring than the steel hoods.
#128
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
well I looked again and really cant tell that its Aluminum but with this guys colossal stash of parts its no wonder
So educate me here, I've heard of em but were they only on ____ years and what model? Formulas? what else?
how light are they compared to steel?
#129
Had started stripping the original paint off is why it looks crappy.
The hoods were made for part of 1 yr maybe? They weigh 21lbs, stock formula hood is around 50lbs? IIRC. Most of the aluminum hoods have a large A reverse stamped in the bottom, for some reason,this one does not.
#130
NOS front bumper inserts for if/when I paint the car
Close but not quite
Early on before I found a real set of comp brakes
ZF 6speed trans torque arm mount to f-body adapter
Rough 1st try, not quite right
Ed and Dave signed them. Have just a touch more work to add to them ;-)
#131
Engine: 5.7L
Wow, I'm impressed with your dedication! That center console is just crazy! Is that ZF mount custom?
#134
Never know but the odds are..... It may or may not already be done.. ;-)
#138
Great stuff man. Bunch of stuff I'm seeing for the first time. Looks fantastic Tony.
#140
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
I haven’t been a member on this forum for very long but over the past couple of days have begun to explore a bit. This morning I located this thread, and haven’t been able to leave it, this stuff is SO up my alley. If you’re a 3rd gen, or for that matter any auto enthusiast, TTOP 350 is doing exactly what we all wish we could be doing. Those pics of his work environment just wreak of a place many of us wanna be, all the time.I did notice the requisite reference to time spent with the family, something I can identify with.Tony, you are obviously a true 3rd gen warrior.Very interesting, and I also look forward to following this thread to where we get a look at the end result.
dead giveaway
dead giveaway
#141
Thank you very much for the kind words 427seven! Your car is outstanding from top to bottom and is deserving of any award its ever given!
Bring on the warm temps!!
#142
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Right now I'd be grateful for dry weather, it seems to never stop raining long enough to dry out for any car activities here in the south.
#143
COTM Editor
Received 1,855 Likes
Car: '89 Firebird
Engine: 7.0L
#144
We had 8" of wet heavy snow 2 nights ago and more on the way...I'm ready for spring!
#146
I keep checking back here for some progress, I thought you - like me - would be all over it while the weather prevents driving.... no progress? Or are you holding out? What's new?
#147
With this thing it's really hard to find a lot of the correct small parts, like bolt markings and correct vintage fittings. Some of the rubber vac fittings are very hard to find. Have had to order some of the fittings and parts from 5-6 different places to find enough of the old stock to complete "the look". The behind the scenes hunt and prep is really fun but also just as stressful as the actual build. There are so many little things that were changed from the factory cars and or different from car to that its mind bending. I am working on about 20 plus different things all at once so it should come together fast when the time comes.
#148
Car: 90 Formula / T-tops
Transmission: MD8
You gotta a helluva parts collection there! I'm curious on the spindles, been meaning to ask this question for a long time. Did GM paint these? Mine appear to have some gun metal grey on them, but haven't really put them under a microscope (yet)
#149
99% sure GM didn't paint them, However, even though they didn't need it, I did clean and paint these, they are a complete set of low mile 1989 1LE brakes.
#150
Transmission: MD8
TTOP350 (08-13-2023)
