how do i go about removing the EGR system
Old Jun 18, 2018 | 02:25 PM
Letty's Avatar
Want a title? Post!
1985 Trans am 305 8cyc. 4 bbl, removing EGR system as a whole
Old Jun 18, 2018 | 05:20 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: how do i go about removing the EGR system
Why ?
It should just be bolted to the intake. Get a new gasket and use as a template and make a block off plate. Iirc the egr is controlled bye a vacuum line to a tvs. Plug the signal to the egr.
https://m.ebay.com/itm/Chrome-EGR-Bl...YAAOSw44BYSw04
https://m.ebay.com/itm/CHEVY-305-350...ss!90011!US!-1
You can look at RockAuto.com but I’m pretty sure yours uses a felpro 70950 gasket.
Old Jun 18, 2018 | 05:31 PM
92BLKL98's Avatar
Car: 1992 Black Z28 Hardtop
Axle/Gears: 2002 10 bolt w/3:23
Why do you want to remove the EGR system it is only active in cruise. At idle and WOT it is not operating. The tuning issues with removing it can be a pain
aseychell
21
Aug 1, 2018 06:53 AM
D Max
Mar 20, 2017 04:51 AM
knightinblackar
Dec 18, 2016 11:55 AM
RunawayRadio
Sep 18, 2016 10:28 PM
