A Firebird GTA the way they should have bult it....
The following 2 users liked this post by 427seven:
dannyboyemt (02-04-2020), ughmas (07-15-2019)
#257
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
Re: A Firebird GTA the way they should have bult it....
The way they are right now, they take so much time and are so expensive - no. I have some polyurethane mock ups that I will have printer plans made for when I get the time, those plans will be available. The phaser lights are pretty hard to get around here...
ughmas (07-15-2019)
#261
This GTA is a BEAST! Dude your fab work is absolutely amazing as well. I am re doing my Formula 350 now and I am envious of you car. My first new 86 firebird was that color and its my favorite on that car. In 1994 I had my 89 repainted that color. But its peeled, etc. So being its 30 years old and I literally bought in July 1989, its time to take it back to its former glory.
#262
Y'all are so complimentary, and I appreciate that there are still people who love these cars (third gen's). It's last half of the year already, and it's time to start showing some of the other work that's been done here. I'm about to start posting some of the interior, headliner to carpet, all new. Right off the start, there was difficulty with the headliner. Originally I wished to use the stocker, and although I accidentally ran over it, I used an ABS bust to reform and put it back together. But it was not to be, the leather used to upholster it needed a very ridged form, and the stocker does not have the strength to hold the shape under the stress from the pull, even though the leather is a very thin split. The deformation showed right where it could not be hidden. So, back to the ABS one which was also problematic in that it was almost 1 inch to short. I thought of getting another one, but in speaking to other users and upholsterers, that would not be useful as everyone reports misfitting one way or the other with these headliner busts. So, like most other things on the car, it had to be modified.
When installed with the front in the correct position, the back of the bust intruded into the t-top space by almost one inch. The goal in modifying is to section the bar area and hopefully add strength. We'll see how we can do that....
#263
A pic of the car waiting for it's next time out.....
#264
As the ABS bust had to be lengthened, I decided the best place to section it would be the front of the bar area as it had support at the visors in front of the cut and from the overhead light behind the cut.
#265
I got a little bit of practice covering up the shoulder harness openings at the rear or the ABS bust. The local plastics shop had sheets of ABS the same thickness as the headliner, and pieces matching the openings were cut, glued into position with ABS cement and then the face was 'bodywerked'....
#266
cut it into strips, this stuff cuts easy, but it's also easy to go off course. be patient and take yer time....
a 3/4" strip is cut to fill the gap inside the section cut
#267
2 part pu
i love this stuff....
Might not be something everyone needs to do, but I wanted a rigid 'backbone' to use after separation to insure that the angles stay correct during re attachment. I love poly urethane bc it's almost instant, it takes form, and it ends up hard...
#268
I dammed the ends with foam, put in a layer of saran covered by fg cloth, then poured the pu into the ABS headliner bust.
#270
a flexible straight edge makes for a good cut
I like a good knife, you don't lose any material and the line is clean.
#271
When working on darks, a good light makes a big difference.
#272
clean separation
Once again, take some time, this stuff is soft and the knife has a tendency to make it's own path.
#274
There is a 5/8" opening that has to be filled
#275
after the length adjustment
The fit before modification is also very visible in the back, the panel that holds the back end of the headliner up has a large gap in two places, a gap that goes away with the length adjustment.
WildCard600 (07-21-2019)
#276
[img][/img]
Cut a filler strip 5/8" wide....
#277
very rigid and a perfect fit...
the stabilizing tabs are glued into position
a piece of pipe the correct dimeter and a heat gun make pieces that prevent deformation at the curves
If you'd been puzzled by the creation of the PU 'backbone', here's where you use it. The two ends are strapped to it while you do your work so everything remains stable, in the correct position.
WildCard600 (07-23-2019)
#278
Because the pieces fit really tight, any adhesive that oozes onto the 'fill space' corners should be removed before it hardens
#279
ready to glue the front 'half' on to the backing tabs
finish gluing in the backing
fitting the filler
#280
remove the bust from the 'spine' and give it a check
re-attach to the 'spine' and glue in the final filler
#281
smooth out with some 60grit
no concerns about strength here, give it the shake test... The casting 'flash' at the edges should be left on until just before upholstery as it adds alot of strength while you work on it
#282
wipe down with some lacquer thinner and it's ready for a skim coat of body filler
quick install just to check fit. compare this to the opening photo. once the flash is gone it's perfect. you can still see the fill spot under the white circle
#283
soon will all look (and smell) like this...
finished a-pillar panel...
#284
just wait till you see these in leather.....
scooter (07-23-2019)
#288
Its DASH time... Always nice to be able to start with a mint piece, but too bad it can never be used as a stock dash again....
#289
needed to decide whether and what type of stitching to use, experimented with top stitches and double stitches using pieces of vinyl just to get a look
#290
tight double
tight top stitch and open top stitch
355SS (11-10-2020)
#293
I pulled the hide over and stretched it on and it looks as though it were stock.... I liked it...
#295
in preparing the dash for adhesives, any unecessary spaces that will trap air should be removed
#296
a sharp blade is all that's needed
slow and careful, a sharp blade will make it's way where you don't want it to in the time it takes you to blink....
#297
these turned up edges exist all around the dash, and the edge is where the upholstery has to grab, so a flat edge works best
#299
someone called this ****.... i dunno if i'd go that far....
#300
after a wash down with a good degreaser, dont forget to wash down the underside, particularly where the upholstery adhesive has to do it's work.
