Mid-Atlantic Region Regional board for all of the Mid-Atlantic states. Discuss gatherings and get togethers.
Mods that pass Maryland Emissions and inspection
Old Oct 10, 2004 | 12:12 PM
N8PHU's Avatar
Car: 82 Camaro
Engine: 2.8L V-6
Transmission: 4 speed
Was wondering if anyone has done the 2.8l to 3.4L swap in Maryland, or if anyone has done any other mods that caused problems when you took you car in for inspection or emissions test.. Like putting on a Edelbrock header or the Dynomax catback dual exhaust system? I have a 2.8L carbed model that I want t o rebuild, but have never been thru the inspection process.....
Old Oct 10, 2004 | 03:50 PM
Marc 85Z28's Avatar
As long as the car passes the sniffer, don't worry about what parts are or aren't on it. There is no underhood inspection here, and the visual inspection includes the gas cap, and sometimes for presence of a catalytic converter.
See all the mods I have? I fast passed. They never even raised an eyebrow over the look or the sound (a dead giveaway of what lies under the hood). Never even bothered to inspect for the converter
All you need to pass is an engine in good tune. A catalytic converter helps immensely, and can mask and out of tune engine, but is not always necessary. I know a few people that have passed without a functioning converter. This however is not the norm. Basically get the engine running good, put a good converter on it, and don't worry about it.
Old Oct 10, 2004 | 04:18 PM
N8PHU's Avatar
Car: 82 Camaro
Engine: 2.8L V-6
Thanks for the advice.
I was planning on doing the 2.8L to 3.4L swap and add a few performance parts. The overall Goal of this project car is to turn it into a daily driver for myself and try and teach a few of the kids some auto mechanics (we home school).
Old Oct 26, 2004 | 05:51 AM
92 Formula's Avatar
From: Avatar: My 34' 1989 Scarab III w/ twin 454's (502's Started!)
Car: 1989 Wellcraft Scarab III
Engine: Twin 454's
Axle/Gears: Twin Mercruiser Bravo I's
Hi Marc,
Is there no underhood inspection at all when you first title a car in Maryland? I was told they did. If you are correct this could be a big help.
The reason I am asking is that I may be moving back and this would be a plus in trying to get the IROC to pass...especially if I waited and registered it as an Antique or to that nature.
Thanks in advance for any further info you may provide.
Old Oct 26, 2004 | 11:38 AM
Ringmaster72's Avatar
Car: 1989 IROC
Marc, I got the inspection done, but when I need to go through emissions testing will they try to plug into my computer or is this only on the new cars. The reason I ask is because I have the Holley Commander 950 setup soi dont have the factory computer anymore. Also, what emissions station did you go to?
Old Oct 26, 2004 | 06:59 PM
Steve86TA's Avatar
Car: To many to list
Originally posted by 92 Formula
Hi Marc,
There is a underhood INSPECTION when you get a sticker for your tags.
No underhood for EMISSIONS.Like stated before as long as the car is in good running condition you shouldnt have a problem.For emissions they put the car on a treadmill and run it through the gears and up to speed a few times.
Old Oct 26, 2004 | 07:00 PM
Steve86TA's Avatar
They wont plug your car in,It will get the treadmill
Old Oct 26, 2004 | 08:51 PM
92 Formula's Avatar
Engine: Twin 454's
Hmmm...that was what I thought to be the case. The IROC will never pass visual. Looks like if I move back to Maryland I will have to keep the IROC registered in Virginia using my Mother-in-laws address. I don't know of any other way around it.
Thanks for the info Steve.
Old Oct 28, 2004 | 01:55 PM
Marc 85Z28's Avatar
DP
Old Oct 28, 2004 | 01:58 PM
Marc 85Z28's Avatar
I've never had an underhood inspection for license plate renewal on any of my cars. Not a single person I know has ever heard of that. All that is required to tag a vehicle is a title, proof of insurance, and an MSI. Getting stickers every two years is as simple as sending in the bill they mail to you and they send the stickers - no inspection necessary.
BTW - for those that asked, I've always gone to the Glen Burnie VEIP station on Ordnance Rd, and very early in the morning. The crew there seems to be fairly clueless, and the one "tech" that tested my S10 couldn't drive a manual trans worth a damn. Most couldn't tell an EGR valve from a hole in the ground.
Only select 96 and later OBDII cars get scanned.
Old Oct 28, 2004 | 05:04 PM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
I am sure Steve means the MD state inspection you have to get before you get plates. They will inspect all your emmissions crap to make sure it's all there and hooked up.
Why "only select OBDII cars get scanned?"
Old Oct 28, 2004 | 06:53 PM
Steve86TA's Avatar
Sorry,I meant inspection sticker
Old Oct 30, 2004 | 10:25 AM
Marc 85Z28's Avatar
Judging from what I've seen while in line and heard from others experiences, not all OBDII cars get tested. Some just get scanned, some get scanned and run on the dyno, and some just the dyno. I'm not sure why... never bothered to ask.
And while a state inspector does check for certain emissions items, they do not know which vehicle is equipped with what equipment. Not all vehicles share the same emissions equipment. On top of that, they only check for the presence and visual connections. It's only a simple visual, and they will not spend any amount of time looking over everything in the emissions system. The MSI is more of a safety inspection.
Simply put, make it look good, and don't worry if it actually does anything or not. If it's obviously hacked, you'll have trouble, in more ways than one.
92 Formula - From what I've seen TRAXION did a good job with that IROC, and other than the exhaust and cam characteristics, many would pass that off as an LT1 swap. You'll need shorty headers, a y-pipe, functioning cat, and a cam swap to pass emissions, and hopefully just exhaust to pass MSI.
Old Nov 2, 2004 | 07:17 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
If the car is in good tune, the cat isn't to big a thing. I've passed twice with my 89 IROC and once in my truck, both have cats that are somewhat "lighter" then they should be. Neither is stock.
Old Nov 3, 2004 | 02:15 AM
92 Formula's Avatar
Engine: Twin 454's
Hi Marc,
Thanks for the reply...I missed it earlier. The car has zero emissions currently and the inspector would have to be pretty blind to miss it. If they do an underhood check I'm fubar. I cannot even consider registering it as an antique in 2010 if I understand it correctly. I could do as you suggest and re-install all of it just to pass...but I may lean toward keeping an address in Virginia or not move to Maryland at all.
I'm considering all options...but am not really leaning toward re-installing the emissions and will not sell it.
Thanks again.
Old Nov 3, 2004 | 09:12 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
WooooWooooooooooooo! That car has a beautiful home. James is a good Daddy
Tim
Old Nov 3, 2004 | 10:56 PM
92 Formula's Avatar
Engine: Twin 454's
Tim
Thanks Tim.
And to all of those who have followed Tim's car on these boards, let me tell you that Tim's work on this car has been even better than described (seriously better). I've rarely seen such attention to detail as Tim showed with his car. I say this not because I am the owner of the car but because it is true.
I think I might add a big wing to the IROC, though...
Old Nov 4, 2004 | 07:23 AM
TRAXION's Avatar
You Phuker j/k rofl. The Scooby is a good car ... just needs more powah! One day .....
Tim
1992Z28!
Nov 19, 2015 07:33 AM
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
RedLeader289
Sep 23, 2015 06:50 AM
