Mid-Atlantic Region Regional board for all of the Mid-Atlantic states. Discuss gatherings and get togethers.
Venting...can anyone help?
Old Apr 13, 2006 | 08:56 AM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
Ok, so as most of you probably know my tranny went out a while ago. I bought a replacement and finally got it in, only to find out that the next week it died just like my old one. anyways, i took a huge chunk of my bank account to get it rebuilt under warranty. got ripped off, overcharged, cheated, etc. anyways, on the way home from the shop, the car goes nuts and stalls out on me and wouldn't start back up. so im left with a problem (guessing its the mechanics fault) where my car would only run fine for about 10 minutes and then just go crazy and die. anyways, a couple hours later i went back to it and it was fine...then same thing, die after 10 minutes. george came over and we replaced all the parts in my distributor and set the timiing...and guess what, didnt help anything! and the worst part is, now it wont start up again at all. im getting codes 41 and 23. this car is just driving me nuts now, i paid a lot for it and it drove flawlessly for a few months. i think my mechanic might have messed something up...can anyone even guide me in the right direction of what might be wrong. me and george think its either the computer or something in the wiring harness.
Old Apr 13, 2006 | 09:49 AM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
sounds like the wiring behind the motor got pinched between the block and trans when he put the new tranny in.
Old Apr 13, 2006 | 09:51 AM
ZZ4 86 Z28's Avatar
i knew it, thats what i put up in my other post...is there any way to prove that? should that be covered by him technically? thanks a lot, and i hope he understands, because that is an expensive piece and a lot of work.
