Third Gen Swap Meet!!
Car: 85 Z28 Camaro
Engine: TPI 305
Transmission: 5 spd
Axle/Gears: Uh, Haven't investigated this yet
Re: Third Gen Swap Meet!!
Looking to buy one rear IROC wheel. Grey/Silver combo.
Looks like this
I have for sale a pretty nice set of Z28 wheels also. No tires. Two center caps say Camaro and the other two say Z28. Pickup only. 100.00 takes them. located Westminster md 21157.
Looks like this
For sale:
disassembled .060 over matching numbers 327c.i./365hp out of a '65 corvette
camel hump heads have new valves.
have receipt verifying $350 in machine work done on block and crankshaft
have all parts for engine block minus pistons, cam and oil pan
also have push rods and various other accessories
asking $1000 obo negotiable
pm if interested
pm if interested
Car: 85 Z28 Camaro
Engine: TPI 305
Transmission: 5 spd
I put the wrong pic on my post above. This is the style wheel I'm looking for.
For sale:
pm if interested
pm if interested
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
Polished Electric Meziere water pump, relay kit, inlet adapter. Part numbers in Summit. This stuff is still brand new in the box.
mez-wp101u
mez-wik346
mez-wp1175u
$250.00
mez-wp101u
mez-wik346
mez-wp1175u
$250.00
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
The water pump is sold.
If anyone is looking for some gold mess TA style wheels there is a teal TA in the crazy rays junkyard over by the key bridge. There were dirty of course but looked to be in great shape from what I saw.
Car: '88 GTA
Engine: L-98
Do you have the rear headliner plastic piece? It retains the headliner by the hatch? It should be a rectangle with 3 or 4 screw holes in it. Is it perfect? if so, I need it.
Car: 1992 Camaro RS t-top
Engine: 305 Jasper
WANTED-Owners manual (glove box book)for 92 Camaro.Need not be pristine,but I don't want one that is worn like a '92 Playboy LOL.
Also FOR SALE-2 stock AM FM cass. Delco factory radios; one is from a 85 Berlinetta and the other is from a 92 RS.The tape players don't work,but maybe somebody can use them for parts. CHEAP,I don't want to throw them in a dumpster if somebody can use them.
Also FOR SALE-2 stock AM FM cass. Delco factory radios; one is from a 85 Berlinetta and the other is from a 92 RS.The tape players don't work,but maybe somebody can use them for parts. CHEAP,I don't want to throw them in a dumpster if somebody can use them. Joined: Nov 2005
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I do believe I have it. I'll check it out tomorrow and drop you a PM, let you know what kinda shape it's in.
Car: 85 camaro z28
Transmission: auto to manaul
Thirdgen camaro 82-92 parts
85 ecm tpi
85 burn off module
85 throttle body (no sensors included)
brand new t5 clutch
mass air flow sensor
85 ecm tpi
85 burn off module
brand new t5 clutch
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
stock front k-member--$50
stock GTA springs--$20
stock GTA front sway bar--$20
stock upper strut mounts--$20
stock front control arms, ball joint boots torn on removal--$10
iroc wheels-some dings and scratches--$100
55# injectors--$250
stock tpi base, minor porting, painted-- $50
located in southern A.A./northern calvert 20711
55# injectors--$250
Car: 89 formula
Engine: 305tpi
Transmission: t-56
Axle/Gears: ford 9" 4.11s
i have a set of bfg drag radials 235-60-15 only one pass on them and no street use at all, only reason im selling them is i went to slicks for better consistancy, looking for 200$ for both, cost me 160$ each
Car: 92rs
Transmission: 350
Axle/Gears: 3.73/Moser 12bolt
BMR LCARB's ,bolt ons
dumb a@@ me ordered them without checking fit on Moser rear (which they don't).So they are unused,black hammer finish.
$100 so I can get the right ones
PM me if interested , pick up only I am in So.MD
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
parts are gone
I'm looking for some stock fog lights or just the glass.
I'm also looking for a power miror switch. that works
Car: 85 Z28 Camaro
Engine: TPI 305
Transmission: 5 spd
I have a engine to tank set of fuel lines that came off an 85 Carb Camaro. All 3 are in one peice, not bent out of shape and still together with all of the mounting brackets except for one. Lines look to be in good condition. They were flowing fuel leak free before I removed them. Also have a 85 Carb tank with the sending unit still installed. Gas inside smells bad but the tank looks to be in good condition.
I was thinking 50 bucks for the tank and lines picked up.
I went TPI and have no need for this stuff.
I also have flip cover for the trunk area with the panel the it sits against. The carpet on the cover is shot, (Greasy) Tan in color though. The plastic the of the flip panel is black. The panel that this thing sits on that covers the tailight area was painted tan originally black(Paint is peeling). The thin peice of plastic where the hatch latch gose through is broke. 40.00 picked up. (T-top slots with tan carpet covering)
I also have another center tailight panel cover thingy similar to the one above except it dosen't support the flip panel. Also this panel is black in color and for a Non T-top car. No t-top hold-down things holes. 10.00 picked up
I have the top peice for center console Basically just the main plastic peice that runs from the front of the console to the back with the glove box well. no other plastic peices for it. 10.00 picked up.
let me know if any of this stuff interests you.
Let me know if any of this stuff interests you.
Car: 91 camaro rs
Engine: 305 tbi
hey all, i have a shopping list of wants for my 91 rs.
1 center console lid
2 shifter bezel not burned all up
3 good set of seats from a 4th gen prefer cloth non power
let me know what you can help me with!!!! scott
