Mid-Atlantic Region Regional board for all of the Mid-Atlantic states. Discuss gatherings and get togethers.
New MD kid
Old Jan 17, 2009 | 02:10 AM
  #51
1991TransAm's Avatar
Car: 1991 Trans Am GTA
Engine: 357sbc
Transmission: TH350
Axle/Gears: 2.73 stock rear
Re: New MD kid
So whats done to your engine? if you dont mind me asking.
Old Jan 18, 2009 | 10:01 PM
  #52
85z28LT1's Avatar
Car: 1985 Camaro Z/28
Engine: 5.7L 350TPI
Axle/Gears: stock 3:42 open
Re: New MD kid
Well its not a 305 as you probably know. its a L98 350TPI, I had it rebuilt about 1300miles ago. its stock internals minus a Erson cam that has .465 lift and 290 duration. which helps me pull estimated 325-350hp and 400lbs trq
Old Jan 18, 2009 | 11:43 PM
  #53
Engine: 357sbc
Transmission: TH350
Re: New MD kid
Okay. Nice little bit have power without doing that much.
Old Jan 19, 2009 | 11:38 AM
  #54
85z28LT1's Avatar
Engine: 5.7L 350TPI
Re: New MD kid
Yeah and you can definitely tell the power increase. I just need to get a LSD cause the one tire fire is killing my traction.
Old Jan 19, 2009 | 11:43 AM
  #55
Engine: 357sbc
Transmission: TH350
Re: New MD kid
Yeah that might help. I spin my tires through 1st and 2rd when i had my 700r4.
Old Jan 19, 2009 | 11:50 AM
  #56
85z28LT1's Avatar
Engine: 5.7L 350TPI
Re: New MD kid
Yeah I do it too lol. Plus the TPI system just give the engine so much trq to begin with
Old Jan 19, 2009 | 11:55 AM
  #57
Engine: 357sbc
Transmission: TH350
Re: New MD kid
Yeah that why i like the tpi unit so much. I have a stock 2.73 posi rear in mine still.
Old Jan 19, 2009 | 11:59 AM
  #58
85z28LT1's Avatar
Engine: 5.7L 350TPI
Re: New MD kid
but you changed the transmisson?
Old Jan 19, 2009 | 01:36 PM
  #59
Engine: 357sbc
Transmission: TH350
Re: New MD kid
yes i did. when the engine went up. i was driving with the 700r4 like 5 weeks before the engine went up.
Old Jan 20, 2009 | 10:01 AM
  #60
85z28LT1's Avatar
Engine: 5.7L 350TPI
Re: New MD kid
Yeah. I had my motor rebuilt cause about 2months after I got the car it was knocking. so I parked it, took it apart found out the bearings were all shot to hell cause they put a 305 crank in it when it was first rebuilt. but I still have the 700R4. im thinking about doing a swap for a TH350 or a 400
Old Jan 20, 2009 | 10:15 PM
  #61
Engine: 357sbc
Transmission: TH350
Re: New MD kid
Thats good you rebuilt it when you did. Mine had a crack block so i had to get a whole new one and get same stuff done.
You should go with one of them, unless you have got someone that can build the 700r4 right.
Old Jan 21, 2009 | 09:47 AM
  #62
85z28LT1's Avatar
Engine: 5.7L 350TPI
Re: New MD kid
How would you build a 700R4? I know a good transmission shop
Old Jan 21, 2009 | 03:05 PM
  #63
Engine: 357sbc
Transmission: TH350
Re: New MD kid
I really dont know much about building them. I could talk to a buddy of mine. His 700r4 is holding up to a big block 427 in his chevelle.
Old Jan 21, 2009 | 03:18 PM
  #64
chevypower1's Avatar
Re: New MD kid
sweet car. u definetly scored
Old Jan 21, 2009 | 09:22 PM
  #65
85z28LT1's Avatar
Engine: 5.7L 350TPI
Re: New MD kid
so they advntage to getting a 350/400 is that they can hold more power without tearing everything to shreds on the internals basically?
Old Jan 21, 2009 | 10:10 PM
  #66
Engine: 357sbc
Transmission: TH350
Re: New MD kid
350 are very cheap to build. i never check on the 400. but any trans cvan be built to last but it all depends on the parts put in it.
Old Jan 21, 2009 | 11:31 PM
  #67
85z28LT1's Avatar
Engine: 5.7L 350TPI
Re: New MD kid
Yeah, I just know 400's are beast's and they can take a beating, which is what I need but you find TH350's alot more then you do 400's. Ill see what happens. that is along way from now. but I really think getting the transmission rebuilt might be and idea since idl when it was done last
Old Jan 21, 2009 | 11:38 PM
  #68
Engine: 357sbc
Transmission: TH350
Re: New MD kid
yeah just wait till you have problems or that before you do anyhting to it.
Old Jan 22, 2009 | 10:18 AM
  #69
85z28LT1's Avatar
Engine: 5.7L 350TPI
Re: New MD kid
exactly dont spend money to fix something unless its broken lol
ALIENhumanoid
Members Camaros
80
Apr 23, 2016 11:35 PM
Jynx88
Oct 4, 2015 08:19 PM
gord327
Sep 29, 2015 10:18 PM
