tune needed
Car: 1991 rs
Engine: 350 carb
Transmission: 700r
Axle/Gears: ??????????????
tune needed
Hey all just bought a 91rs with a 350tpi swap, It runs but not good at all. That's why I got it so cheap, the guy gave up. is there anyone in or close to Salisbury that can help me get it tuned in. Heres what im told its a 355 with mild cam. the car does run just rough. please let me know if anyone can help me out. I am no kind of mechanic and don't pretend to be. Maybe a chip needs to be burned or something???
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Re: tune needed
Start with the basic stuff.
Fuel pressure and quality of spark.
Then check for vacuum leaks, compression pressure.
Check codes.
But really, if you are not a mechanic, and you don't want to trial-and-error all sorts of things, don't you think you'll save money in the short-run to simply take it to a reputable shop, and have them evaluate it?
You might have bought it for cheap.
Not likely that its going to be cheap to own.
Check codes.
Car: 1991 rs
Engine: 350 carb
Transmission: 700r
Re: tune needed
Check codes.
Check codes.
with out a dout I would save, but again just because its a shop don't mean they know our cars and about swaps. Im looking for someone local who eats and sleeps camaros
