SNJ TPI help needed
Car: '85 IROC
Engine: TPI
Transmission: automatic
SNJ TPI help needed
I got an 85 IROC that someone brutalized. Need help figuring out where the wiring is supposed to go and what's missing and wrong with the beastie.
I got connectors that go nowhere, sensors without connectors and a fan with nothing but a hotwire. The car runs SUPER rich and will not rev at all.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: SNJ TPI help needed
There could be multiple issues , old injectors, bad cts, tps maf. Its hard to say unless you go through fix the gremlin issues with the harness and go from there. The 85 1226780 is a poor design ecm. Putting a 86-89 harness and a 1227165 ecm is one of the best upgrades you can do to a 85 IMO. The 870s slow baud rate , slow response . just something to ponder.
http://www.eecis.udel.edu/~davis/z28/ecm_swap/
Car: 90 Iroc Vert
Engine: 5.0L
Hey Guy - where at in SNJ - Im in Franklinville, I got 89 TPI/350 in the bird and a 90 TPI/305 in the Camaro ... welcome to have a look.
Where are you at ?
Where are you at ?
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by jerbear127
how do i post something on this site hah?
Car: '85 IROC
Engine: TPI
Thanks for the replies.
Tuned, while I like your idea, I'm just trying to get this running well enough to sell it.
Jersey89, I'm in Millville.
When I got it, the tranny(700R4) was shot. Got that replaced and it seems to be running a little better oddly enough. New plugs helped a bit but still running way rich.
Engine: Lb9
Transmission: M20
You might try seeing if you can blink any trouble codes. Or download winaldl so you can see sensor data, cts, maf, cts . Lack of communication would indicate a bad ecm.
http://www.ebay.com/itm/85-CAMERO-5-0L-ECM-1226870-CSJ-See-item-description-/171187559012?pt=Motors_Car_Truck_Parts_Accessories&hash=item27db92da64&vxp=mtr
Engine: Lb9
Transmission: M20
Car: '85 IROC
Engine: TPI
That winaldl looks interesting. Too bad I have no laptop. Might try to borrow one.
Will try to blink the codes.
beachrodder
Aug 25, 2015 08:05 AM
Sanjay
Aug 12, 2015 03:41 PM
