Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
where to get sfc welded in
Old Feb 1, 2003 | 11:32 AM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
I live in Greenfield, a suburb of Milwaukee, and I was wondering where is a good, respectable place to get SFC's welded on, and are there any places to get sub frame connectors locally, or should i order them from the internet
Old Feb 1, 2003 | 01:28 PM
gflo383's Avatar
Car: IROC Z
Engine: 355 MINIram w/boost
if you wanna drive a little, i would be glad to install them for ya, hoist, welder everything we need at the shop to do it, ive done about 5 camaro's i usually charge bout $100, depending on what brand you buy, some are more work than others... the shop is in StPaul MN, its quite the drive from milwaukee.... not sure how many hours but if ya want, just reply to this post and let me know!
Old Feb 1, 2003 | 02:54 PM
Thanks for the offer..but i think it is like over a 6 hour drive there so i'll try to find a shop just a bit closer....thanks any way though
Old Feb 1, 2003 | 05:57 PM
WECoyote's Avatar
Damien,
I HIGHLY recommend you look into Alston subframe connectors. They are tubular steel type SFC's that can either be bolted or welded in. The latter being much much better. They come powdercoated in black. I bought mine at the Jefferson Swap Meet from Alston for $150 (in the fall of 2001). They are normally $189 on their website:
Alston Race Cars
A couple of weeks after buying them I scheduled an appointment to have them welded at their shop. They are in Antioch, Il which is just south of the WI/IL border. Im guessing it would probably be an hour drive from where you live. The install took about 3 hours. They put the car up on a lift (to keep the car properly 'loaded' on its suspension and straight), clean the areas on the car frame for welding, prep the areas on the SFC's for welding, pull back carpeting to prevent heat damage and/or fire, weld them in, clean the welds and paint it to prevent rusting.
Very professionally done! The SFC's made quite a noticeable difference in the stifness of the car. The installation cost was about $125. IMO......a very good investment at $275 and they are 'local'.
Mike
Old Feb 4, 2003 | 12:02 PM
Soulrev's Avatar
Car: Formerly - 87 T/A, 87 Bird.
Steve Spohn.
http://www.spohn.net/index.cfm?fusea...t&productid=31
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
no green
Jan 9, 2016 09:22 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
