Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
need trans guidance
Old May 13, 2003 | 05:03 PM
jc33's Avatar
Car: 1992 Camaro RS
Transmission: T5- manual five speed
need trans guidance
ive run into a snag. i am putting a 350 tpi in my 92 that had a t5 and a v6. i am planning on using my t5 with the new engine but i just noticed the input shaft and clutch for a v8 dont match up. does anyone know of a solution
Old May 13, 2003 | 05:56 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
you're going to have to buy a v8 T-5 trans. no other solution.
Old May 29, 2003 | 08:23 PM
Soulrev's Avatar
Car: Formerly - 87 T/A, 87 Bird.
Re: need trans guidance
Yeah you probably should have inquired a bit more on the swap.. the V6 T5 won't work with a V8. Maybe you should check out a junk yard.
Old May 30, 2003 | 04:31 AM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
i read a big long post a ways back were if you get a clutch and bellhousing from a certain year van it will work...
Old May 30, 2003 | 07:38 PM
jc33's Avatar
Car: 1992 Camaro RS
well the engine clutch and trans are all in the car. i had to use 9 11/16 clutch with a cover made for the v8 flywheel. i havent actually ran the engine yet as everything else has to be hooked up. my next worry is the wiring, matching a 89 350 to a 92 v6 wiring loom promises to be tricky. plus the brake lines and headers arent getting along.
Hawk312
Aug 22, 2017 08:55 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Hello, Michael
Aug 20, 2015 03:19 PM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
