Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
Engine biuldere in MN good/reasonable??
Old May 27, 2003 | 01:38 PM
Cold Dark Shado's Avatar
Car: '86 TA wrapped in '84 skin
Engine: 305 carbed
Axle/Gears: unknown
Im lookin for a good and reasonable engine builder preffered in southern MN as i Live in Waseca,between owatonna and mankato, Im lookin to have a 3.4 built with the top end of my 2.8 and i dont have the time or space to do it myself.
Old May 29, 2003 | 01:41 AM
LaxStreetRacer's Avatar
Car: 91 Z28
Never used them personally but ive heard good things about a place called Run Automotive in Winona...check em out
Old Jun 3, 2003 | 03:30 PM
broham81's Avatar
my buddy could cut the motor mounts and slap a v8 in for ya
Old Jun 3, 2003 | 03:44 PM
Engine: 305 carbed
Axle/Gears: unknown
i was thinkin about goin V8 but im goin to stick with a 6 for right now. Imay be able to find a spot to rebuild it my self but i need to find someone to throw it in when its done.
Old Jun 3, 2003 | 03:56 PM
Guest
Guest
Posts: n/a
why would you need to cut them???
Old Jun 4, 2003 | 06:54 AM
broham81's Avatar
2.8's (and i'm sure 4clys) have differents motor mounts than the v8's, so you need to cut the old ones out of the frame and weld in v8 mounts.
Old Jun 4, 2003 | 10:04 PM
Guest
Guest
Posts: n/a
WRONG!!!!!!! look at the K-member on your F-body there are holes for V-6 or V-8 motor mounts that will BOLT right on. Thats why the F-bodys are so nice... all the parts are swappable
Old Jun 4, 2003 | 10:06 PM
Engine: 305 carbed
Axle/Gears: unknown
what would a V8 and trans swap cost me?
Old Jun 4, 2003 | 10:16 PM
Guest
Guest
Posts: n/a
it costed me about $3,500 (but i got some deals here and there like the block for free) it maybe $4,000 i don't know i owuld have to do the math. but then again i also did a rebulild with TONS of aftermarket parts and it took some time to do as all.
Old Jun 4, 2003 | 10:18 PM
Engine: 305 carbed
Axle/Gears: unknown
is that 3500 with rebuild of motor and puttin it in the car?
What would it cost me if i had a motor and trans and just needed some one to put it in and hook everything up?
Old Jun 4, 2003 | 10:33 PM
Guest
Guest
Posts: n/a
every shop is different i would a guy that works out of his house and his took out the old motor built the other motor and put the new motor and new trans in the car for $850 and that is dirt cheap.!!
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
