Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
I need a custom chip burned
Old Jan 7, 2005 | 10:24 PM
pellmanm's Avatar
Car: 1989 GTA
Engine: 383 Fuel Injected
Transmission: Pro-Street 700-R4 by Pro-built
Axle/Gears: Moser 12 bolt w/posi
I have a motor with the following mods and i will need a custom chip burned, and i want to know who or where can do it.
-ZZ4 Shortblock
-Trick Flow Heads 195cc intake ports CNC, milled down to 58 cc Chambers for 10:1 compression.
-Lingenfelter/Accel SuperRam intake Set-up
-Twin 58mm TB with Cold Air Intake
-30# injectors
-LPE 219 cam with 1.6 roller rockers. for 219 duration and .560 lift
-50 psi fuel regulator
-Hooker headers with 3" y-pipe, 3" high flow cat, 3" flowmaster 80 series
-Underdrive pulleys
-180 degree thermostat
-700R4 beefed up trans
-3.73 gears
Old Jan 11, 2005 | 01:52 AM
Kandied91z's Avatar
that's a nice little motor you have yourself...
good luck in the tunning, if they can't have your car in their hands while tunning understand it probably won't ever be the way it could be and expect many trial and errors along the way.
tunning is the worst part of this hobby.
Old Jan 11, 2005 | 08:26 PM
Roadvoyeur's Avatar
Car: 1987 Camaro Z-28 IROC
Engine: 5.0 305ci TPI
Custom Chip Burned
I know a guy in Waunakee Wi who burns chips for a living. He is a long time gear head, very well known in this area and does excellant work..But he needs to have your car to give it a true custom tune job..He did my 87 Z-28 IROC after I installed mods and it runs absolutely perfect..He also did a GMMG Berger 2002 Camaro ZL-1 with 600RWHP for a guy who owns a auto repair shop here in the area.. If you want his number just let me know..PM me or send me an e-mail..
F.I. 57 Belair
Aug 23, 2021 01:09 AM
85 Jimmy
Sep 30, 2015 07:56 AM
Deemax
Sep 12, 2015 06:53 PM
Ranbo108
Sep 9, 2015 12:20 PM
