Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
Old Mar 12, 2005 | 04:59 PM
350WHT's Avatar
Car: 1992 camaro RS
Engine: sbc 350
Transmission: th350
what would happen if u dont degree your cam after u put a new one in?
just wondering
Old Mar 12, 2005 | 09:26 PM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
Yea thats a good question what does happen?
Old Mar 12, 2005 | 10:31 PM
Rick King's Avatar
Car: 1987 TA
Engine: 350 stock/twecked
Depending on the cam not much or a whole lot. if it is a mild cam stock small or rv you can put in in stright up and it should be ok, but if you do degree it you will have more acutare valve timming---If I had my .6 lift cam in the 327 with only 19 thousands clearence between the piston and valve at maximun lift and it was 30 degrees off--well all h-- could break loose--like the valve opening and closing at the wrong time causing lots of problems---best way to describe it is like your timming change jumping a tooth or two--just a world of timming issues--
worst case -- broken engine parts--
I degree even stock cams just my madness and 2 cents take it or leave it--
later and
gb
Rick
Old Mar 13, 2005 | 11:17 PM
sleeperZ28's Avatar
Car: 86 z28
Transmission: built 700R4
along with the broken parts, the cam may not perform like the manufacture claims it will. on a stock motor poor/less than expected performance sould be all you have to worry about
Old Mar 15, 2005 | 03:59 AM
Bill Speed's Avatar
Car: 1989 Formy droptop/88 Deville
Engine: L98 350 TPI
Transmission: factory RWD, WS6 susp
Tech savvy, but not spelling savvy hehehe
work on that a bit..it's hard to read
BILL
