700-r4,87gta radiator,dualfansetup,tpisetup Detroit-Harrison township
Car: 87gta
Engine: dont know yet
Transmission: 700-r4 race prep
700-R4 for an 87 rwd car. Non electric. Bought in 2002 never used. I bought it from these guys http://www.transman.net/parts.htm#hiperf
Its the high performance 700-R4 that reads like this:Comes with a high performance servo (not a Corvette servo), 30 spline input shaft, extra clutches in the 3-4 clutch drum (9 not 6 or 7), large pressure valve, special separator plate, special governor springs, and a ten vane pump (not 7), heavy-duty sprag, heavy-duty roller clutch and a 2300 rpm stall converter. Also a throttle valve cable, dipstick, and tube.
Mine has no dip stick or tube. Might have the TV cable somewhere. It will come with the 2300rpm Torque converter. I paid 1195 plus 150 shipping for her. I will take 1000 firm. I think it is a rather "loose" converter. My name is James. My number is 1-586-615-6917. This trans also has the full 3-4 gear upshift valve er parts what ever. Meaning you can upshift with full throttle from 3-4. Also they put in a full manuel valve body.
Radiator no cracks or leaks-50.00
Dual fan setup- 75.00 working when taken off
MAF sensor-used circut board type 25.00
Old tpi setup22#injectors- everything but wires and computer 100.00 takes it!
I have other stuff else where too. will try and post later.
Also have a 355 long block. This lb has Eagle cast crank, Eagle forged rods, Hyper(brand with the lightning bolt, dont remember) pistons, edelbrock truroller timing chain, comp roller bump stick, comp roller lifters, no pushrods yet or oil pump as heads are still off the short block, torque plated block the works!, off brand water pump and cast iron ballancer- not installed but will throw it in., Crane gold 1.6 roller rockers-paid like 350 for them at scamchargers!, ummm Trickflow 23 degree heads-with the right springs for the cam!, Molly rings!
All parts are NEW except the block. Which was machined for all the new goodies. Figure 450/450 hp/tq with streetable cam!
Engine price: call me to hear the price 1-586-615-6917
Sorry guys the 1987 gta it all was going into got traded in for my new Ford "fokass".
If you have questions for me call me! James. I have recipts for all of this stuff! except the RAD,DFS,MAF as its used from the car.
You pay shipping!!!!!!!!!!!!!
C.O.D. or something just as good. I'm not trying to rip anyone off or be ripped off. If your in the metro detroit area you can come and inspect any off this stuff! Ohh yeah cash is all ways best!
