Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
How to remove ignition lock
Old Mar 24, 2006 | 10:12 PM
MD88IROC's Avatar
Car: 88 IROC
Transmission: 5 speed
Axle/Gears: G92
I'm sure this has been discussed many times in the past, but the search is down and I've already spent hours trying to find a previous post on this. So here it is again....how do I remove the ignition lock cylinder from my 88 Camaro ? Thanks
Old Mar 25, 2006 | 09:26 PM
iroczguy's Avatar
you have to remove the steering wheel, the spring loaded lock ring, and the turn signal assembly, in that order, then there is a torx head screw that holds in the ignition lock assembly
this would probably get more responses in one of the tech forums rather than mid-west
Greg
Old Mar 25, 2006 | 10:14 PM
MD88IROC's Avatar
Car: 88 IROC
Axle/Gears: G92
Thanks Greg, I did look in the interior forum, but didn't see any reference to it. The PO put a different lock in it before I got it and the signal switch won't stay in either. Guess I will see what's up with that at the same time. It seems to be missing a clip on the end.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
3rdgenparts
Aug 8, 2015 07:09 PM
