Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
355 Eaton supercharged & T56 4 Sale
Old Nov 8, 2006 | 01:49 PM
355SS's Avatar
Car: 90 Camaro
Engine: 418 LS3 whipple charged
Transmission: Magnum T56 w/ Street Twin
Axle/Gears: 3.27 9 bolt
I am selling off my 355 Blower engine and parts, contact me for more info. All of my machine work and assembly was done at Auto Rons in Davenport, IA.
1. Dart Pro1 200 cc aluminum heads ported and polished Brand new $1400
I have over $2000 in these heads they have been bolted on and never fired.
PBM 2.02 & 1.60 valves, 1.550 springs and 10 degree titanium valves and locks. Viton valve seals and 3/8s studs and ARP head bolts
2. LT-4 Crane self aligning roller rockers $200
3. Manley push rods $60
4. Polished aluminum center bolt valve covers $100
5. Comp Cams Custom ground hydraulic roller cam .544 I .556 E 230 I 236E 114 lope seperation.New $270
6. Roller timing chain New $100
7. 355 Short Block 87 roller block .030 over and blueprinted it is a 2 bolt block that has been strapped for added strength 5300 miles since freshening. Lunati rods, Lunati flat top forged pistons, Gm steel crank, Melling oil and pickup, Moroso 6 quart pan, Moroso windage tray and new GM balancer. $1800 I have over $3000 in this short bock
8. SLP 1 ¾” headers & y-pipe w/ 3” single cat adapter. Jet hot coated, never fired since coated. Wide band O2 port also welded in. Air tube removed and welded closed $450
9. Stewart stage 2 water pump reverse rotation brand new $150
10. LT1 style Mini starter $75
11. Holley commander 950 part number 534-120 w/ communication cable and software, new. $500 I paid $650
12. I also have all of the serpentine brackets and accessories up for grabs all have around 5000 miles on them and are in very nice shape (no a/c parts). Other misc parts Rebuilt distributor w/ new cap & rotor, Accel 300+ ignition and coil, full set of Delphi racing wires, wiring harness.
13. Mcleod Street Twin w/ aluminum flywheel 350 miles $1000 I paid $1400
14. T56 from 1996 Camaro SS w/ 45,000 miles, I have had this trans installed in my car since 1998 it also has the JTR cable drive conversion installed $1400. Or trade for LS1 T56. Or trade parts to convert to LS1 T56.
15. 4130 chromoly torque arm for T56 conversion $350
16. Custom Eaton M112 supercharger setup. All parts are new and custom built. It is very similar to a Magnacharger setup. This unit is not completely finished As Is $1400. If completed $2800
I will entertain offers and package prices, I will sell everything for $9200, item 1-7 for $3800, item 8-12 for $1700, items 14-16 for $2500
Thanks for looking
Old Nov 14, 2006 | 09:44 PM
355SS's Avatar
Car: 90 Camaro
Here is a older picture
Old Nov 18, 2006 | 03:46 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
how much can you home down on the t-56?
AussiePr0nCar
Mar 6, 2020 04:04 PM
92projectcamaro
Jan 18, 2016 08:00 AM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
toronto formula
Nov 10, 2015 06:17 AM
