Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
Is the Borg Warner 9 bolt worth anything?
Old Aug 29, 2007 | 06:29 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
I will be buying a strange 12 bolt here soon, and wondered if anyone was interested in buying a borg warner 9 bolt with 3.73 posi rear end. It has the 28 spline axles and a recent fluid change. Has only 73,000 miles on it and in great shape. Will be upgrading because of the turbo that will be going into it. I have the 10;s bug, meaning i want to get into the 10's.
Old Aug 30, 2007 | 08:51 PM
V6canvas's Avatar
Car: 1989 Trans Am GTA
Engine: Stock LS1
Axle/Gears: 3.70 9 bolt
Re: Is the Borg Warner 9 bolt worth anything?
They are worth a lot to some, almost nothing to others. I have one with the 3.27 gear set. The 3.73s would be great for my LS1 swap, but alas I have neither the money nor room for more car parts in the garage.
Sorry I can't be more helpful, you might want to mention where you are located at too.
Old Aug 30, 2007 | 09:08 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
unless you have swapped in the 3.70 gears your rear end would be 2.77, 3.27 or 3.45 from the factory. There is no 3.73 option. I would imagine it would be worth $300+ in good shape with a tight posi.
Old Aug 30, 2007 | 11:29 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
yes i did swap it for the strange 3.73 gears. If anyone is interested let me know, i am located in wi, mn, ia, or il. i live on the border close to all these states. thanks
Old Sep 2, 2007 | 01:25 PM
VERTIGO Z28's Avatar
Car: FBODYS
Engine: ALWAYS 8'S
Transmission: ALWAYS MENTAL
Axle/Gears: RUSTY AND BRAND NEW
If it has the aluminum PBR calipers with the parking brake cables I will buy it.
Kevin
Old Sep 13, 2007 | 11:11 PM
Car: FBODYS
Engine: ALWAYS 8'S
Have you done the swap yet? Still would like to buy!
Old Sep 14, 2007 | 02:18 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
make me an offer and we will go from there
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
New2Chevy
Sep 28, 2015 12:35 AM
billybob6110
Sep 23, 2015 01:30 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
