Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
LS swap
Old Nov 1, 2008 | 11:13 AM
mean350rs's Avatar
Car: 1989 Camaro RS
Engine: 355 LT1
Axle/Gears: 4th gen 10 bolt
LS swap
Can a person LEGALLY do a LS swap into a third gen in the st.louis area? ive asked before on the stupid emissions website but they gave me a link to some other website that was confusing as all get out. So, im wanting to put an ls series engine into my 89 rs instead of the TPI setup i was going to do. Can i do that?
Old Nov 1, 2008 | 12:17 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
Re: LS swap
Yes the LS series engines can be installed in older cars with all emissions intact, IE cat converters, air pumps, o2 sensors ect. Any engines older that the model year of the car can not be installed legally. It may vary from state to state but that is the basics.
Old Nov 2, 2008 | 07:29 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Re: LS swap
depending on location they get real specific with stuff like the converters need to be in the same location as the donor car. ( nice thing is you can cut/rotate the f-body ones to fit) need to use the ls1 air lid and so on.
some locatons are only concerned with just having all the equipment working no failure codes
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
