Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
Need help with 86 iroc
Old Apr 6, 2011 | 05:40 PM
jw86iroc's Avatar
Hi, not sure if this is the right place. I have a 86 iroc 305 tpi with 67k original miles. I put it in the garage to do a tune up. It ran fine when i parked it. I started with cap, rotor, icm, plugs, and wires. It would not start, since then a new batt., starter. Adjusted tps to .54, removed iac and cleaned it. Maf was new when i got the car. When i try to get the trouble codes the fan starts running and the relays by the brake booster make odd noise. Need help please!
Old Apr 6, 2011 | 07:16 PM
jw86iroc's Avatar
Re: Need help with 86 iroc
Btw I can hear fuel pump come on. I put a pressure test gauge on the rail while trying to start and it read 40. Pulled the plugs and they were soaked with fuel.
angel2794
Sep 8, 2015 06:22 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
mustangman65_79
Aug 23, 2015 02:00 AM
g.l.mos
Aug 22, 2015 12:02 AM
mustangman65_79
Aug 11, 2015 03:17 PM
