Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
To HVAC or not to HVAC?
Old Feb 20, 2012 | 09:55 AM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
Ladies and Gentlmen, I am at a crossroads. Last summer I rejoined the thirdgen ranks with a 91 RS, however this particular 91 RS has a heater core leak and the AC doesn't work. As a result, I'm considering doing away with temperature control capabilities completely by eliminating the AC System and bypassing the heater core. The car is my daily when there isn't salt on the ground, and I typically drive it to work, put the t-tops on while I"m at work, take the t-tops off and drive home where I park it in the garage.
Here's where you come in...I grew up a Milwaukee-an, was a Flint-toid for a while, and am now a Dubuque-er, so I know we pretty much all have the same weather during the non-winter months. So, Midwesterners, would you do the same? If you have done all or part of what I'm considering, would you do it again? Do you regret it?
...my main concern is fogging when it's raining...
Old Feb 20, 2012 | 11:16 AM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Re: To HVAC or not to HVAC?
Heater and defroster is a must have on any car in my book. Fix the heater core. I have lived without AC.
Casey Meyers
Mar 2, 2016 10:46 AM
777Shock777
Oct 29, 2015 04:30 PM
timonator
Sep 30, 2015 12:52 PM
Chevykid810
Sep 28, 2015 12:57 PM
Eric-86sc
Sep 28, 2015 11:37 AM
