2 12" Kenwood Typhoon Subs
Car: 94 Camaro Z28
Engine: 5.7L
Axle/Gears: GU5 3.23
Up for sale is a set of 12" Kenwood Typhoon Subs. I purchased these items NEW a matter of months ago, and wired them into my 1987 Camaro. They ran beautifully with deep, rich bass. The only fault is about a 1 inch scratch near one of the screw holes of one sub, its on the plastic not anywhere NEAR the cone. They were only in my camaro for two months, give or take a few days. I'm selling the camaro and wish to keep the trunk space in my current car, so i'm letting these go for cheap. They go for about $100.00 a piece from Crutchfield - and $90.00 a piece from Best Buy. That's the absolute cheapest price i could find. I'm willing to let the pair go for $145.00 SHIPPED. Depending on where you live, I may even go cheaper.
These are the subs HERE, the amp is no longer for sale.
The 2 Kenwood KFC - W3009 Typhoon 12" Specs:
Key Features
* Double Magnet Construction
* Double Spider
* Frequency Response: 25Hz - 800Hz
* Impedance: 4 ohms
* One-Piece Cone Design: with Red Metallic Center Emblem
* Pearl Mica Injection-Molded Polypropylene Cone: 12" Typhoon-Type
* Power Handling: 800 Watts Peak
Woofer Features
* Double Spider
* Impedance: 4 ohms
* Magnet Weight: 63.4 oz
* Power Range: 35-400 Watts RMS
* Sensitivity: 93dB
* Speaker Connectors: Gold-Plated, 2-Way SB-Type
* Urethane Surround: with Perpindicular Inner Wall
* Vented Voice Coil: 2-Layer
* Top Mount Depth: 5-5/16"
Specifications:
* Thiele-Small Parameters
* DC Resistance (Re)
* Electrical Q Factor (Qes)
* Force Factor (Bl)
* Mechanical Q Factor (Qms)
* Moving Mass (Mms)
* Peak Excursion (Xmax)
* Resonant Frequency (Fs)
* Total Q Factor (Qts)
* Voice Coil Diameter (d)
* Volume Acoustic Compliance (Vas)
Anyone interested please PM me or reply here...I check often.
Key Features
* Double Spider
* Impedance: 4 ohms
Woofer Features
* Double Spider
* Impedance: 4 ohms
* Sensitivity: 93dB
Specifications:
* Force Factor (Bl)
* Moving Mass (Mms)
efiguy
Sep 27, 2015 01:30 PM
