Garage Sale Third Gen Camaro Parts!!!
Old Jan 26, 2017 | 08:32 PM
dahuntin's Avatar
Car: 89 Camaro
Engine: 385
Transmission: '94 T-56
Axle/Gears: Broken 10 Bolt
SOLD!!!
I have a lot of random parts that have accumulated throughout my restoration and modification of my '89 RS. I'm going to try to list all that I have, but will undoubtedly forget something so don't hesitate to ask if I have a certain part. I live in Chesapeake, VA, but I am willing to ship anything, but I will charge what it costs. That said I will try to combine what I can if you want multiple things. I'm posting a few pics, but please ask if you need any.
TPI Air Box - $40 SOLD
Black Carpeted Center Console - $40
Steel Spare Wheel w/ CO2 and all jack stuff - $100
IROC Tail lights- $80
OEM Heater Bypass Valve and Hoses - $10
Steel Drive Shaft - $20
Aluminum Rear Drums - $50
OEM 153 Tooth Flywheel and used Zoom Clutch from T5 - $50
OEM Strut Mount Caps - $10
OEM Drum Rear Proportioning Valve - $10
Reman Stock Front Loaded Brake Calipers w/ Lines & Bolts w/ 300 miles - $30
New-ish High Pressure Power Steering Hose w Pressure Switch - $10
OEM Strut Mounting Brackets and Hardware - $15
Factroy Torque Arms - $10
Used Energy Suspension Factory Torque Arm Bushing - $10
Serpentine AC Compressor for Core (Works, but sounds like it needs bearings) - $20
Carmine red seats with red and white trim need recovered, but trim is good - $40
OEM AC Condensor - $20
Interior Heat/AC Unit with control and ducting - $40
OEM Factory TBI Fuel Lines - $10
TBI MAP Sensor Tubing - $10
OEM Rear Control Arms - $10
OEM Panhard Bar - $10
OEM Front Control Arms with Poly Bushings (needs ball joints) - $20
OEM Spindles - $40
Carmine Red Arm Rests (Need Fixed) - FREE
Sun Visors with Good Mounts (Need Recovered) - $10
LO3 305 w/ Rod Knock - $150
OEM Starter Brace - $10
Reman Starter with Bolts - $20
(4) Rear Spring Isolators - $10
Chrome Heater Hose Cover - FREE
E-Brake cable from Lever to under car - $10
Hood Release Cable Assembly - $10
T-5 Torque Arm Mount with Exhaust Hanger - $40
(1) Front Spring Isolator - FREE
Decent Leather E-Brake Handle Cover - FREE
Decent Plastic E-Brake Handle Cover - FREE
3 Wire Mechanical to Electrical Speedo Converter - $10
Hood Safety Latch - $10
Hood Latch w/ big and little brackets - $40
T-5 Slave Cylinder, Master Cylinder, Reservoir and Guard - $40
T-5 Clutch Fork & Good Throughout Bearing- $20
3/4" Tilton Master Cyclinder (needs flushed out) -$30
Hood Latch Catch - $10
Passenger Power Lock Switch Panel (White Letters) -$10
Carmine Red Console Vents - $10
Battery Hold Down Block & Bolt - $10
Bose Kick Panel Speakers without Plastic Trim or Carpet - $10
Windshield washer fluid tubes and fittings that go in wipers - $10
Complete Carmine Red Seat Belt Set (Works, but the front belts where in the sun are a bit faded and the inner belt plastic is cracked) - $20
fuel tank shields - $10
Radiator (I know nothing about it, but it looks good) - $20
15x7 Two Stripe IROC Z Wheels and bald tires (nearly perfect wheels) - $200
Driver Side Door w/ shaved handles - $50
Passenger Door - $50 SOLD
'87 IROC Roller w/ bad interior, body is good, but paint is not, some parts missing - $400
700R4 Cross-member - $20
Flow Master Muffler (has a small hole that I tore in the tail pipe trying to remove it, can be easily repaired with welder) - $40 SOLD
Attached Thumbnails Garage Sale Third Gen Camaro Parts!!!-20170126_191219.jpg   Garage Sale Third Gen Camaro Parts!!!-20170126_180713.jpg   Garage Sale Third Gen Camaro Parts!!!-20160825_195416.jpg   Garage Sale Third Gen Camaro Parts!!!-20160603_192644.jpg   Garage Sale Third Gen Camaro Parts!!!-20160416_125048.jpg
Garage Sale Third Gen Camaro Parts!!!-20160416_125217.jpg   Garage Sale Third Gen Camaro Parts!!!-20160603_192003.jpg   Garage Sale Third Gen Camaro Parts!!!-20150802_120543.jpg
Old Jan 26, 2017 | 09:26 PM
M G Brewer's Avatar
Car: 1988 IROC-Z
Re: Garage Sale Third Gen Camaro Parts!!!
Dang! I can't find the 16" wheels for nothing lol.
Good prices on this stuff!
Old Jan 26, 2017 | 10:53 PM
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
Will you ship just the wheels to 31326 and can I see better pics ?
Old Jan 27, 2017 | 06:24 AM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Do you have the pair of 87 grey door panels? What condition and price?
Old Jan 27, 2017 | 06:53 AM
dahuntin's Avatar
Car: 89 Camaro
Engine: 385
MG Brewer - I do have some 16" 2 stripes, but they are on my Chevelle. If I ever get a new set I'll list them.
Purely - The grey door panels that I do have are on the door that you can see. The panel is in good shape, but the cloth is falling off. They would need to be recovered.
Tony91RS - I can, but would need to figure something out to get them dismounted. I will post some good pics of them tonight. Three of the wheels are perfect and the forth one has two small spots of scraping. If you use the zoom function it can be seen on the lower right wheel. The center caps are included as well as seen.
Old Jan 27, 2017 | 04:08 PM
dahuntin's Avatar
Car: 89 Camaro
Engine: 385
Tony91RS - I have attached pictures of each of the wheels for you.
Attached Thumbnails Garage Sale Third Gen Camaro Parts!!!-20170127_164755.jpg   Garage Sale Third Gen Camaro Parts!!!-20170127_164452.jpg   Garage Sale Third Gen Camaro Parts!!!-20170127_164102.jpg   Garage Sale Third Gen Camaro Parts!!!-20170127_163936.jpg
Old Jan 27, 2017 | 05:43 PM
tonys91rs's Avatar
Car: 91 Camaro RS
It's about 25-30 a wheel to ship. What's the total minus the tires?
Old Jan 27, 2017 | 07:20 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
washer fluid lines+complete carmine red seat belt set shipped to 06460?
Old Jan 28, 2017 | 07:14 AM
dahuntin's Avatar
Car: 89 Camaro
Engine: 385
Tonys91RS - Looks like the wheels are going to be $100 shipped using two boxes plus what it costs to dismount the tires, probably $20 Let me know if that sounds ok and I can get them dismounted and boxed up this weekend.
TylerSteez - The washer lines and the seat belts will be $20 shipping, so $50 total. Do you want to see any pics of condition?
Old Jan 28, 2017 | 07:43 AM
TylerSteez's Avatar
Engine: 383 stroker
Pics would be awesome
Old Jan 28, 2017 | 08:56 AM
dahuntin's Avatar
Car: 89 Camaro
Engine: 385
TylerSteez here you are
Attached Thumbnails Garage Sale Third Gen Camaro Parts!!!-20170128_094914.jpg   Garage Sale Third Gen Camaro Parts!!!-20170128_094920.jpg   Garage Sale Third Gen Camaro Parts!!!-20170128_094932.jpg   Garage Sale Third Gen Camaro Parts!!!-20170128_095041.jpg
Old Jan 28, 2017 | 12:56 PM
TylerSteez's Avatar
Engine: 383 stroker
will have to pass on the seatbelts since they don't match the red of my firebirds interior, also are those washer fluid lines for a pump thats mounted on the resovoir or a pump thats mounted in the wiper motor?
Old Jan 28, 2017 | 06:25 PM
dahuntin's Avatar
Car: 89 Camaro
Engine: 385
These are the fittings and sprayers that come through the firewall and into the cowl to connect to the wiper arms.
Old Feb 2, 2017 | 06:54 AM
dahuntin's Avatar
Car: 89 Camaro
Engine: 385
These things have got to go. Make me an offer on combos of things, I won't refuse it.
Old Feb 2, 2017 | 09:53 PM
tonys91rs's Avatar
Car: 91 Camaro RS
Do you still have the wheels ?
Old Feb 3, 2017 | 06:55 AM
dahuntin's Avatar
Car: 89 Camaro
Engine: 385
Yes
Old Feb 7, 2017 | 02:32 PM
1991camaro_z/28's Avatar
Car: '91 camaro z/28
Engine: 350ci 5.7L
Transmission: 4spd. Auto w/overdrive 700R4
Axle/Gears: 3:27
Is the drivers side door and muffler still available?
Old Feb 7, 2017 | 03:12 PM
dahuntin's Avatar
Car: 89 Camaro
Engine: 385
The drivers door is available, but the muffler has been sold, I will update that. Let me know if you have any other questions.
Old Feb 7, 2017 | 05:00 PM
Engine: 350ci 5.7L
Axle/Gears: 3:27
Ok, thank you, can you possibly add some more pictures of the door, also is it a power window/lock car? Thanks.
Old Feb 8, 2017 | 12:33 PM
dahuntin's Avatar
Car: 89 Camaro
Engine: 385
I can get some pics of it up tonight.
Old Feb 11, 2017 | 07:42 PM
Engine: 350ci 5.7L
Axle/Gears: 3:27
Looks like I will have to pass on the door. I found a local one for the same price. Best of luck to you
Old Mar 6, 2017 | 02:43 PM
dahuntin's Avatar
Car: 89 Camaro
Engine: 385
All parts are gone with the exception of 15x7 iroc wheels and aluminum brake drums.
Old Mar 6, 2017 | 10:43 PM
Kush Barnes's Avatar
Car: 88 Firebird Formula W/T-Tops
Engine: 5.0 (305)
How much for everything suspension?
Old Mar 7, 2017 | 06:55 AM
dahuntin's Avatar
Car: 89 Camaro
Engine: 385
All other parts are gone.
This thread can be deleted.
Old Nov 19, 2017 | 02:55 PM
Chris Fulton's Avatar
Want a title? Post!
Do he have a computer for a 91 camaro rs with 3.1
Old May 4, 2022 | 09:19 AM
jdhall14's Avatar
need a black console also need dash , ash tray , top of door panel driver side may need to send picture of what i have that is broke. 256-558-1075 jack . call if you have anything thanks.
Old May 11, 2022 | 10:01 AM
LitosWay's Avatar
Car: 1989 Camaro RS
Engine: 305 V8
Have anything left? I know it’s been a while but these are great prices!
