1986 IROCZ going to market
Old Mar 13, 2018 | 02:30 PM
coren's Avatar
Hello all again. I have a strange request that lends itself to third gen Camaro value knowledge. I have build a totally custom Z and will be completing it in the spring with a fresh red paint job. This is a twin turbo 350 and is wicked fast. I have no knowledge of the value of the car as its specs are listed below and need an educated evaluation as close as possible regarding the cars value when completed. It has approximately 40 miles on the new engine. I know this is a weird request but due to the lack of Camaros sold today I need some help on this.
Thanks in advance and below is the car specs and a picture of the engine bay
Gen 1 350 with all newstandard components; standard crank, rods, standard pistons, rings, bearings, camand crank
New HOWARD'S SBC ChevyRetro-Fit Hyd. Roller 270/278 495"/500" 108° Cam Camshaft Kit
New Proform 66906C StampedRoller-Tip Rocker Arm 1.5 Ratio 3/8 in. Stud
--Clamshell
New Mighty Demon blowthrough 750
New Eldebrock polishedintake manifold
New Elgin 1.94"Intake & 1.5" Exhaust Valve Set
New Felpro gaskets
New Electric water pump
New Melling high volumeoil pump with pick up
New Acel HEI Dist.
New MSD 6al2 programmableign
New Cloyes timing gearcover for roller cam
Ported and polished heads
New plug wires
New Holley 140 GPHelectric fuel pump
New Holley 4-9 PSIadjustable fuel pump reg with return port, boost --referenced
New Twin t-3/4 turbos
New MSD Tach converter box
Flowmaster Muffler, BigBlock II 70 Series, 2 1/2 in. Inlet/2 1/2 in. Outlet, --Steel, Aluminized
Corvette Fiberglass taillight panel and quad exhaust tips from C4
Custom dash and all newgauges including boost
New door and window rubbermolding
Custom gear shifter for700R4 transmission
Electronic wirelessexhausts cut-outs on both sides
New oversize Tires
4 wheel disc brakes
New Front brakes
Posi-traction 3:08 rear
New Champion 3 rowaluminum radiator
Driver and passenger seatrecovered
Old Mar 13, 2018 | 07:19 PM
TOM305T/A's Avatar
Car: 1987 GTA 350 auto
Re: 1986 IROCZ going to market
any other pics?
Old Mar 14, 2018 | 05:57 PM
coren's Avatar
I sent the pictures. did you get them
Old Mar 16, 2018 | 06:11 AM
coren's Avatar
Re: 1986 IROCZ for sale
pictures
drttrk355
Camaros Wanted
Jul 29, 2006 05:57 PM
ANDYZ28
Feb 8, 2002 09:12 PM
IROCME
Jan 6, 2002 02:59 PM
86IROCMIKE
Jan 29, 2001 08:26 AM
