ct emissions
Old Mar 26, 2006 | 03:38 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
ct emissions
with ct do you have to pass emissions or just go and get tested to get your car registrered? I am not sure if I am going to pass or not and I don't want to run out of time on my temp tags before I pass. thanks
Old Mar 26, 2006 | 06:02 PM
kyles88bird's Avatar
Car: Trans AM
Engine: 305 TBI LO3
Transmission: W/C T-5
Axle/Gears: 3.42 Open
u MUST pass be4 they issue u a registration or a re-issue a current one
Old Mar 26, 2006 | 08:41 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Great!
does anyone know how to make a 350 with edelbrock carb 1409 performer intake and no egr with a cat and a cool 2 1/4 exhaust pass emissions?
Old Mar 26, 2006 | 09:50 PM
Car: Trans AM
Engine: 305 TBI LO3
edit: found it
Brett - drop the cammed car down to empty - drop a gallon of denatured alchol in there, add 4-5 gallons of gas - this will make an approx. 25-30% alchol content - not enough to bother anything in the fuel system so long as you fill up and don't let it sit in there for more than a day.
my car passed with a 520/540 lift cam, 236/242 (050) 110lsa cam... and no cats!!! you should fair a little better because you have a little less overlap...
this is over on CTFBA when a guy asked bout his car. same for u tho
Old Mar 26, 2006 | 10:23 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
thank you and where do i get the denatured alcohol? thanks though. this will not do anything to the rest of my car? will it make it run hotter? thanks again
Old Mar 26, 2006 | 10:28 PM
USMC3782's Avatar
Car: 86 TA, 00 Z28
Engine: L31 Build in Progress
Transmission: NWC T5 till it blows
not true
youc an register without a pass, have to test though
Old Mar 28, 2006 | 06:46 PM
Car: Trans AM
Engine: 305 TBI LO3
its cheaper for him to do this then spend the 600$ minium to get the car to pass. car runs fine, just do not leave it in there longer then a day. u can get it at lowes, home depot wal-mart wherever
Old Mar 28, 2006 | 07:23 PM
USMC3782's Avatar
Car: 86 TA, 00 Z28
$600
who said anything about fixing it? My cat turned out to be gutted, and i did put a dual cat flowmaster in, but not for emissions.
Hotrodboba400
Dec 10, 2019 07:07 PM
racereese
Oct 3, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
TBRays98
Sep 6, 2015 05:05 PM
