possible inspection in pa
Car: 82 Z
Engine: 350 carb'd
Transmission: th-350
Axle/Gears: 3.08 posi
theres a car for sale on here that im pretty interested in, here are the specs:
Mystic Teal Metallic Paint, 305TBI .030 over, ZZ4 Cam, 305 Heads(416 Casting)w/ PBM High-Lift Valve Springs, Edelbrock Performer RPM Intake, TBI adaptor plate, Fully Ported Throttle Body, 90# Injectors @ 16 PSI, Walbro 255lph Fuel Pump, AFPR, Open Element, AC Delete, Smog Delete, WCT5 5-speed Conversion, Lakewood LCAs, Suspension Tequnique Rear 1" Sway, 2:73 Limited Slip Differential, Edelbrock TES headers(AIR delete), 4th gen 2 3/4" catback w/ Flowmaster 80 series muffler, and Tuned
its for sale in new jersey, but i live in pennsylvania
is there any way it would pass inspection over here?
Car: 1987 Z-28
Engine: 355
Axle/Gears: 10 Bolt/3.23 peg leg :(
Agreed, I dont think I'd make it unless you can get an emissions exempt sticker. I'd look into doing that in your county before you decide to buy it if you do.
Elephantismo
Feb 13, 2019 12:51 AM
