ct tunning?
Old Sep 9, 2008 | 11:40 AM
jmmass's Avatar
Car: 86 camaro irocz z28
ct tunning?
jw if there are any good places in ct for tuning my 86 camaro
Old Sep 9, 2008 | 01:55 PM
AC's Avatar
AC
Car: Used to drive a camaro
Re: ct tunning?
I haven't heard of any shop that really knows what they're doing for TPI 3rd gens, hence why most of us in the Hartford CT area DIY. What type of mods did you do that requires tuning? Or are you just looking to get your car a general tune up?
Old Sep 9, 2008 | 09:53 PM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
Re: ct tunning?
i had the same problem with finding a tuner. i decided to go with the xfi unit instead
Old Sep 9, 2008 | 10:05 PM
jmmass's Avatar
Re: ct tunning?
well it doesnt have anything crazy just flowmasters, intake, 52mm tb 8mm spark plug wires and shift kit. but i put it on the dyno and the numbers were real low. so i was told by several ppl that it needs to be tuned
Old Sep 10, 2008 | 04:19 AM
AC's Avatar
AC
Re: ct tunning?
A shift kit and 8mm wires isnt going to do anything for your HP #'s. The 52mm TB maybe a small, small amount. Sounds more like you should get an actual tune up (check the timing, new plugs gapped at the right amount, oil change, etc). Then the next thing would be to actually get a good scan/datalog on it to see how the car is running in terms of volumetric effiency, BLM and AFR. Who knows, you could be running lean, rich, etc. Who did the dyno time? Did they give you a printout of the results? Did they have a sniffer hooked up on the tailpipe so you can see what the AFR was doing during the pull?
Old Sep 10, 2008 | 05:32 PM
jmmass's Avatar
Re: ct tunning?
yea thats what i think ill do. i took it to a place in ct called AF performance. they printed out the results but they didnt put the sniffer on the tailpipes.
Old Sep 10, 2008 | 07:25 PM
AC's Avatar
AC
Re: ct tunning?
jmmass, without an AFR report you have no idea where the car was during that pull for air / fuel ration...lean or rich. There could be some power to be had depending on where your engine was running.
funstick
65
Feb 26, 2013 09:26 PM
funstick
May 29, 2011 01:16 PM
peruvious
Car Audio
Nov 2, 2003 01:33 PM
funstick
69
Apr 28, 2003 01:35 AM
funstick
34
Sep 25, 2002 03:40 AM
