chevy 355
chevy 355
I'm selling a motor that I had built for my 84 TA. I don't have the time to put into the car anymore and need to start cleaning up. It would be local pickup in the Easton, PA area. Asking 2000.
All parts are brand new minus the reconditioned block.
http://allentown.craigslist.org/pts/2464709844.html
Re: chevy 355
GM 350 4 bolt main block hot tanked, magned, zero decked. Block bored and toque plate honed. (brass plugs installed) Need Speed Pro pistons (9.5:1 compression with 76cc chamber cylinder heads). New Clevite 77 brand road and main bearings, durabond cam bearings. Crank shaft has been turned .010 on road and .010 on mains all oil holes chamfered. New Melling m55 high volume oil pump, hd drive and screen. Connecting roads resized with new bolts. Rotating assembly has been balanced. New Crane Cam 268 H cam has 268 advertised duration and .454 lift 110 lobe cent. New Cloys brand double roller timing chain and gears. New lifters. Head, GM 76CC, three angle valve job, cut for seals, new guides, new stainless valves, comp springs and retainers, new push rods and head bolts, new valve covers timing cover and new oil pan installed. Edelbrock performer intake and new hardware. Engine assembled and valves adjusted.
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
codeysabatini
Nov 10, 2015 04:07 PM
z28venezuela
Oct 24, 2015 08:15 PM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
darwinprice
17
Oct 11, 2015 11:51 PM
