Subframe connectors - Need Massachusetts installer
Car: 1983 Z28 T-tops
Engine: 350 GM Crate
Hi all,
Any recommendations for quality/reliable welded sfc installers in MA or RI?
Thanks!!
Thanks!!
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
Re: Subframe connectors - Need Massachusetts installer
Are you looking for them just to be welded?
Car: 1982 Z-28
Engine: 383
If you are close to East Providence, I recommend SD Concept. Wendy and Scott are great and they can get those taken cared for you.
If you are closer to Grafton Mass, Johnny's Auto and Light Truck repair can do it as well.
Engine: LB9 305
Transmission: AT
"EvilOKC" and John, Great info and photos! Jegs say they will work on my '89 IROC Z Vert, will they? Won't the factoru stiffeners, at the rocker panels get in the way?
If I put my car on a two-post lift, can I install them with the bolts loose, then have access to tighten them up, after setting the car down on my flat concrete floor?
Imagening the vehicle on a drive on, muffler shop lift, is there room for the guy to weld them ?
I am also considering Sphon's SFC. Thanks!
