Northern California Discussion board for Northern and Central California.
compression test?
Old Jun 22, 2005 | 12:58 PM
irocdaddy's Avatar
Car: 89 iroc,2012 eco 150,roadglide
Engine: zz4
Transmission: t56
compression test?
will this tell me if my rockers are adjusted properly?
Old Jun 22, 2005 | 02:20 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
not to my knowledge.
pop off the valve covers and check the pushrods for play?
Old Jun 22, 2005 | 04:44 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Re: compression test?
No it won't. Pop the covers and check your valvetrain for play, and make sure that the lash is adjusted correctly.
Old Jun 28, 2005 | 09:53 AM
irocdaddy's Avatar
Engine: zz4
Transmission: t56
a leak down test would work though...wouldn't it?
If a valve is being held open because of rocker over adjustment, wouldn't that show up on a compression test?
Old Jun 28, 2005 | 05:32 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i can see that working, but you would have to crank the engine manually to get each cylinder to the compression stroke when both valves are closed.
Elephantismo
Feb 13, 2019 12:51 AM
FormulasOnly
Jul 23, 2018 08:47 AM
NZKnight
Oct 15, 2015 02:47 PM
RedLeader289
Sep 23, 2015 06:50 AM
WhteRbt
Sep 21, 2015 09:48 AM
