Northern California Discussion board for Northern and Central California.
let that Left Coast knowledge shine
Old Dec 14, 2005 | 05:39 PM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
something in the ignition portion of my car is giving me a hell of a time
outta nowhere, the thing wouldn't start, and then stumbled when I tried to give it gas under load (only sometimes). I got it home, and it started stumbling EVERYtime I gave it gas, then I turned it off, and it hasn't started since.
It cranks fine
if i put an aftermarket coil in it, it'll fire up, and run pretty rough and crappy... but i think it's just giving enough juice to jump whatever gap is the bad spot in the system, its not actually fixing it.
plugs and wires seem fine, cap and rotor is pretty new (all of it is)
any funky experiences or ideas? lemme know
Old Dec 14, 2005 | 06:09 PM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Re: let that Left Coast knowledge shine
Not as funky as your "super crunchy rock guitar"
Old Dec 14, 2005 | 09:16 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
Even if the plugs/wires/cap/roter look fine, their could be a bad wire, bad plug (broken insulation, carbon fouling, ect), cap could be cracked, or less likely the roter could be bad(worn out)
Check them all out.
Old Dec 16, 2005 | 12:44 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
ignition module 'nuff said.
Old Dec 16, 2005 | 10:44 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
rofl i knew the crunchy guitar was gonna come up
check ur ignition module like travis said, and double check your cap/rotor.
Old Dec 17, 2005 | 04:48 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
SES light flash to the miss? If so, I'd be thinking PU Coil.
Don't know if a IM could cause weak spark...for sure would cause no spark.
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
drumstixer
Sep 29, 2015 03:02 PM
Dragonsys
Sep 25, 2015 03:51 PM
