GTG, BBQ and Dyno testing......
#103
Car: 89 IROC-Z
Im gonna be there and i will dyno to, even though my car is gonna pull some low numbers but its ok. can i get the address so i can mapquest it.
#105
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
& Auto Repair
3100 Arden Way
Sacramento, CA 95825
916-974-SMOG(7664)
#109
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
I added him to the list Travis, assuming to Dyno.
Also. .. Terrell's mom w/ the 'vette.
souperman, great, come on down, you're on the list, name?
#111
Engine: 383/LGX
was worried about getting March 29th off so I could take my licensing examination and I forgot to ask for April 2 off. Im gonna see if I could come in a couple hours late so I can hang out for a second. in the morning, oh what time is this gonna start. anything gonna happen that night, like a late nite cruz?
#116
Engine: 383/LGX
Originally Posted by PHAT89TA
souperman name is garrett
I wish I could call in sick but I have a project to finance
#118
Car: '89 GTA
Okay. ..added Garrett's name.
JMJ2003. ..what's your name doll?
You're added to the "spectating/hanging out" list.
+ 1 for your boy?
Anybody else confirmed or unconfirming?
+ 1 for your boy?
#120
Car: A beater.
Engine: Not enough HP.
Transmission: Automatic... I can't drive a stick!
OUtatime, the name's Elle honey.
And, no, boyfriend isn't coming!
I'll be making the trek alone.
#121
1 Post
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
Del,go ahead and take off my truck.The new throwout bearing is screatching.I still have to do my rear swap,header install,wonderbar,torque arm mount,centerlink by the 2nd so all my extra time is on the t/a.
#123
1 Post
Car: 00 Camaro SS
Engine: 5.7
Good,I was going crazy not being able to drive it while I was in Florida.I have been driving it for the last 2 days.The driverside rear wheel is clunking pretty bad so I need to buy a rear asap,I am going with 3.23 and will just upgrade to 3.42 gears next winter.I need the master cylinder and prop valve too.I just got a new radio pod so I could mount the deck and my TDS wonderbar arrived while I was gone so that goes in too.Sorry to hear about the t/a.Told ya to buy tires
#124
Car: '89 GTA
Changes made.
Talked to Bennie and we're still on track for the 2nd it seems, he's waiting for the dude to install the anchor/strap thangs.
I wouldn't sweat the susp. mods Steve, just get those headers in.
My motor is just being pulled out, so not holding my breath to dyno that day, but I'll be there and my ride will be present on the lift at least, hah.
So you and your mom's 'vette will not be dyno'ing?
Not sure about a late night cruise seeing that it's Sunday and most folks would probably be needing to head home after.
If people want to come the night before and stay the night somewhere, that's an option and we could hang in the eve.
Last edited by OUTATIME GTA; 03-24-2006 at 12:30 PM. Reason: Automerged Doublepost
#128
1 Post
Car: 00 Camaro SS
Engine: 5.7
Yeah,I can't find a 3.42 anywhere.I had 1 bought yesterday but after having the guy triple check the ratio it was a 3.23 and I didn't want to pay 450 for it.
#129
Car: '89 GTA
i must have missed it, but why is your motor being pulled del?
I've got a lot of stuff going on it and to make the install easier, insure no leakage, Bennie is pulling it and sealing it the right way.
I probably have close to 2K worth of parts going in.
Heads/cam/rockers/timing chain/cover/pushrods/waterpump/full gasket set, oil pan gasket/arp bolts/AFPR/uhh. ..yeah, so there you go.
A lot to be done and it can't be rushed.
#131
Car: '89 GTA
Nah, no secret, very mild setup, but all quality parts.
Just a ZZ4 cam, 208/221, new.
The heads are nice though, the new Trickflow Kenny Duttweiler 23* 195cc/64cc CNC-ported.
#132
Car: 2006 yamaha r1 50th anniversary
Engine: 1.0 ;)
ohhh good stuff man looks like those low 13s are coming quick!!!!! or maybe 12s......i wish i could afford heads and cam
#133
Car: '89 GTA
No real 1/4 predictions yet, but I would expect to drop 1 full second.
The tuning will be key and is what I will focus on when this is done.
It ran really great before so I want to make sure my driveability/smoothness is still there with the newly added power.
#134
Engine: 1.0 ;)
hopefully you get your baby done soon man cant wait to see it purrr when its done!!
damn i just noticed iam not a senior member anymore is that because i dont post enough?
#135
Car: 1986 IROC-Z
Engine: 350 5.7 TPI
Transmission: 700R4 2500 stall
thats cool del i have the same cam in mines right now zz4 cam since ure running the higher compression im only 8.1 and ive been able to pull 13.4 out of mines last year full weight on a weds night and last night figured my new pump made my fuel pressure really stupid high over 60 usualy run 48 to 52 max so im pretty sure that were my mph went still need to go double check it again get air fuel reading out the back
#136
Car: '89 GTA
Wow, 60, that's way high.
I believe 50 is optimal for most, but every car wants something diff.
Yeah the ZZ4 will give me what I need, an improvement over stock, smooth idle and powerband through 5500.
I'm all about combo matching, not trying to invest all this $ and go slower.
#137
Car: 1986 IROC-Z
Engine: 350 5.7 TPI
i had it at 50 52 fuel pump was leaning out on the top and i upgraded the fuel pump and guess with all that pressure shot it up past 60 65 i have the stock 22 pound injectors in it ill get it dialed in pretty soon lose power running to rich but with ure combo are u runing a lil thinner on the head gasket with the zz4 cam in mines i shift at 5500 and on the spray in third i cross the line at 5400 5500 with 3.23 gears
#138
Car: '89 GTA
What heads are you running?
You need to put a sig. up man, so we stop askin' ya.
I bought the standard trickflow rec. gasket set.
When I first started racing my GTA I was granny shifting, barely over 4K.
At it's peak I was shifting @ 5000, and that's all it had in her, 14.1 best.
I'll probably end up in the same situation, a 13.1-2 and not enough for 12's
#139
Car: 1986 IROC-Z
Engine: 350 5.7 TPI
but thal be way better then erics car lol hmm see the thickness u might wana go thinner on the gaskets but hey if u can pull a 13.1 13.2 on a weds night u can pull a 12. on a weekend and if not borrow someones skinnies thall do it hey u can make up alot on the a spray and blow in to the 11.90 mark im more then happy hey car still passes smog and i can hop in it and go to la and back no problem i drive mines from stockton all the time go rip on it at the track hop in it and drive it home
#141
Car: '89 GTA
Eric isn't working on it is he?
1. Only Bennie touches my car, period.
2. Eric doesn't work there anymore.
3. Eric didn't work on cars there.
4. Even if he did, wouldn't touch it.
I'm sure I could 'hack' my own car apart and learn something if I didn't have to work for a month and had a decent garage/tools, but I'd rather leave it to the man who will do it right.
#143
Car: 92Z28,91Z28,91Z281LE,95ZR-1,08Z06
Engine: 406, 350, 305, 350, 427
Transmission: auto, auto, 5-speed, 6spd, 6 spd
Axle/Gears: all stock
6 anchors were installed today. Set-up for RWD and FWD. Luckily I had a 4th gen RS that was there as a jig and an Integra.
#145
Car: 1986 IROC-Z
Engine: 350 5.7 TPI
so is there going to be a way to check the air fuel ratio on every pull whos actaully going to dyno theres andtry to tune on it ' as in timing changes fuel pressure regulator
#146
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
Transmission: T-56 fully built WOOHOO
too late lol
i changed your o2 sensor haha, yes ill be there as far as what ill be doing i dunno
and yes ive been working on my car mainly getting all the peformance heads off, which the head gaskets/intake never really sealed up it was burning lots of oil from the wrong intake angle, and the head gasket from when i pull the bolts out to put rtv on them oh well its what i call the 14.3 mix . i picked up an entire t5 setup today
and i am abandoning ship on the 87 ta the underbody is bent up so taking parts off of it and sending it away picking up another 87 ta hard top from jason ru-qwick when i can find someone with a truck and he is free
#148
Car: '89 GTA
psht, that almost counts as work.
i recall having a hand in it.
list updated, i've got you on the hang out list sir.
what's the deal on the sale, you're putting a t5 in for Robby?
#149
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
hey del, on topic, what time is this all taking place? i may have some morning plans however my buddy don with the nova has to be at work by 2:30 i believe. so i may have to come earlier with him so we make sure to get him set up.
#150
Car: '89 GTA
Travis - I would think by 9-10am, I'll see what Bennie thinks to get set up.
I'm not going to assign time slots as of yet, it will be first come first serve since the list isn't hugemongous and people will arrive at diff. times.
valencia1z - The first page is the sign up list, just let me know and I'll add you.
If anyone is going to try to tune or make changes between pulls, you should have your equipment in hand and prepared in the interest of time.
Do we have anymore confirmations for a dyno?
Only 6 days left.
Looks like about 7-8 definites.
I'll dyno my Supra if I have to.
Only 6 days left.
