Northern California Discussion board for Northern and Central California.
Quick question
Old Oct 20, 2006 | 04:54 PM
-89ca/\/\aroRS-'s Avatar
Car: '89 Camaro RS
Engine: 305 tbi
Quick question
Hey fellas,
As you might no my rear end is messed up on my car, been putting off getting it fixed but in about a month i will have the money to get it done. and some other things to
i was talking to a mechanic friend of mine and he said it would be easier to buy a used rear end and swap the components into the rearend on my camaro, instead of just changing out the whole rear end...so my question is...is that true?
Old Oct 20, 2006 | 07:21 PM
JesasaurusRex's Avatar
id swap rears any day over changing the internals and setting up the proper lash for the ring/pinion what have you. That's just me tho.
Old Oct 20, 2006 | 07:38 PM
0uTcast13's Avatar
Car: 1988 Pontiac formula Firebird
Engine: 5.0 h.o.
Transmission: 5 Speed
Axle/Gears: 3.55 10 bolt
changeing rears takes bout 2 hours if u do it have *** way better then swaping in gears so id do the rear end any day
Old Oct 20, 2006 | 08:59 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
your mechanic is retarted...
changing rear end is like 12 bolts seriously
Old Oct 21, 2006 | 12:25 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Back when I was a thirdgen noob, I tackeled a whole rearend swap by myself, and took me no more then an hour!
Old Oct 21, 2006 | 12:58 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
