Northern California Discussion board for Northern and Central California.
More iroc progress.
Old Oct 29, 2006 | 01:43 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
More iroc progress.
Today, Will and I worked on getting the front struts and springs out, we removed the whole A arm and front suspension, After it has all been removed, I stand back, take some pics (soon to be posted) and decided that stock is junk, I am not putting it back in, So a new tubular K member and A arms from spohn are in short order.
Old Oct 29, 2006 | 01:46 AM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Right on bro, that will be a sweet setup!
Old Oct 29, 2006 | 01:48 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Thanks, All that fresh stuff sure will look good, along with fresh springs and the struts.
Old Oct 29, 2006 | 05:03 AM
ellenkitten's Avatar
Car: 87' GTA Trans Am
Engine: 5.7 350 TPI
Your car is in sac......So does that mean when im in sac next week I can see it?
Old Oct 29, 2006 | 12:39 PM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Axle/Gears: Borg Warner 9 bolt w/3.27 lim. slip
I want to do this as well some day. I want to see the pics ASAP. Last time I talked to SPOHN the weren't making them yet. Are you still going to run a standard iron V8 or have you decided yet? I know they make tube k members for LS? swaps.P.S. How much $$ for all that?
Old Oct 29, 2006 | 12:43 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
Sweet Travis, I'm doing mine this winter also. Now it'll match match the suspension in the rear. The front is ugly and heavy.
Old Oct 29, 2006 | 12:47 PM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Not fair at all!!! I'm putting all my extra $$ in my '54 right now. I keep priming my wife with the idea that when my 150k motor goes in the IROC then I'm doing it all at the same time, motor, Kmember, Aarms, 5 speed trans. etc. She's very understanding of my addiction. Of couse she has a nice Tahoe too.
Old Oct 29, 2006 | 01:29 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
hawks used to sell an "LSx" k-member but they don't any more. thats what I had ordered back in november but what came was a new spohn k-member. hawks said the old version with the mounts had some fitment issuse so they don't sell them with mounts any more. the old version was made locally(to hawks). when I ordered mine it was $450 now I think its $500 for the K-member
Old Oct 29, 2006 | 01:31 PM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Not to bad. Are the A arms much more? I won't be able to afford any of this stuff until my '54 is done and on the road. I have to be able to have 1 daily driverr running.
Old Oct 29, 2006 | 01:35 PM
kairles's Avatar
Engine: 383/LGX
$300 for coilover style, $400 for stock style
Old Oct 29, 2006 | 05:42 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Correct, A arms with spring perch are 400, the K member for gen 1/2 blocks are 445. So all in all, 845 bucks plus shipping, not too bad. I think its totally worth it.
Hey Daniel, I am keeping with the iron Gen 1 block. My car is all setup for it, as far as fitment and tranny, ecm, etc. So I will stick with it for now, Maybe when the project is done someday I will build a second engine on the side which will of coarse have to be way sicker then the current engine to warrant a swap.
But a 383 and 12psi shouldnt be bad on perfomance, even considering the long tubes, high flow heads, big cam, mini ram, etc
Old Oct 29, 2006 | 05:47 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
You better give Jesse a good run with all that, good lord.
Old Oct 29, 2006 | 08:13 PM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Sounds fast to me. What kind of 1/4 time can you pull set up that way? Do you think you will save any wieght/time with the tubular stuff? Have you weighed in recently? I'd be curious to see if there's any weight savings. I undertand it's mainly a space sace savings, but have heard there's some weight saved.
Old Oct 30, 2006 | 12:17 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
I would hope theirs a weight savings, just looking at the two side by side is incredible the amount of metal the stokc peices use.
But either way, I would hope for tens, Traction permitting. But it's all wishful thinking until it really happens, I have learned my lesson with that one.
I weighed my car at bennies shop and got a 1250 over the rear axle and a 1700 front axle, withou tme in it. Not sure how accurate that really was, Seemed on the low side.
Old Oct 30, 2006 | 12:23 AM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
I'm hoping to be @3000lbs. or less and get 375 RWHP when I'm all done. PIPE DREAMS though for now.
Old Oct 30, 2006 | 12:30 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
I hope the tubular junk and cowl hood drop enough pounds and yet i always want full interior, I want a car that appears and feels totally drivable, yet power on demand.
Old Oct 30, 2006 | 12:35 AM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
ME TOO! I took out my spare/jack and plan on retrofitting the new Optima battery there when my current battery dies. Just got one for the wifes Tahoe. $200 for the red top. But it's maintanance free and is supposed to be better performing
Old Oct 30, 2006 | 01:44 AM
JesasaurusRex's Avatar
, lonely at the top (haha im cocky)
Old Oct 30, 2006 | 11:46 AM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
if i remember correctly a tublar k member, and tublar a arms saves 80 to 100 lbs
i say traviz youll finish yours the same time terrell finishes his iroc
Old Oct 30, 2006 | 11:53 AM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
That would be worth it to me. It's al about wieght savings in the front end!
Old Oct 30, 2006 | 12:04 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
yea.... what daniel said....
Old Oct 30, 2006 | 01:24 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Nah, I'll be finished before Terrell
I expect to be all done this march at latest.
oh ya.
Will won't let me put anything old back on, so this is going on as well.
Old Oct 30, 2006 | 01:32 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
just dont forget to upgrade the rest of your suspension....
Old Oct 30, 2006 | 01:33 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
The rear stuff can wait, I am only replacing right now what I have already dissasembled.
Old Oct 30, 2006 | 01:43 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
it can wait until you blow it up right? ...i really need to find a project camaro...
Old Oct 30, 2006 | 02:49 PM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
[QUOTE= ...i really need to find a project camaro...[/QUOTE]
Old Oct 30, 2006 | 03:08 PM
Car: '89 GTA
Are those the 2-piston caliper setups from that SSBC joint Travis?
I was going to go with those, but I don't think the price can justify the stopping power.
Bigger rotors w/more stopping area would be more beneficial.
I'll probably just get new oem pads/calipers this winter.
Old Oct 30, 2006 | 03:18 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
I just dont have the place to put it...
Old Oct 30, 2006 | 04:36 PM
Engine: 5.7 350 TPI
you have a garage.... and a side spot by the side gate to your backyard..
By the way Travis, it will be tomarrow im coming to sac leaving here at 8am hopefully i can see the 'rock hopefully i will be back in time for work
Old Oct 30, 2006 | 10:13 PM
kairles's Avatar
Engine: 383/LGX
oh ya.
travis do a search on those. I remember there was a big thread about those calipers. long story short the improvment, if any would hardly be noticable. Im with del, do a real brake upgrade
Old Oct 31, 2006 | 01:34 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
The main thing is the dual piston calipers, with slotted rotors and braided steel lines is what I want. I am sure it will be a noticable improvement over my stock 160k mile stuff and worn out hoses.
Plus it looks good, and is moderately cheap, you should all know that I have never been big on brakes.
Old Oct 31, 2006 | 02:26 AM
wills83z28cfi's Avatar
Car: 07 Silverado
Engine: 5.3L V8, flexfuel E85
Transmission: 4spd. Auto
Axle/Gears: 3.73 locking diff.
Awesome job so far bish. Car is looking better everyday, and it's going to look awesome when she is all done, can't wait! The tubular sh*t is going to be so freaking sick, not only looks but performance will be way better than the old stock crap. As for the brakes I totally agree with you, SSBC is the sh*t for the money, and it looks sick. What you said about a major difference over the stock old 160k mile stuff is so true. Even if it's not the best upgrades you will still notice a huge difference just because of this. When I replaced my original pro. valve, new pads, and one new caliper on my 83 I couldn't believe the difference, it was like night and day. And of course your increase will only be better cause you are upgrading your stuff.
Old Oct 31, 2006 | 02:40 AM
kairles's Avatar
Engine: 383/LGX
https://www.thirdgen.org/forums/brak...=ssbc+calipers
after reading this seems like some good pads and rotors would be just as good as those calipers, they do look good though
also, I was talking to the guys at MSI in roseville about the SSBC 3 piston calipers for the vette. they had a couple people use them and they didn't see much of an improvment over stock.
Old Oct 31, 2006 | 10:00 AM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
You know what ? I'm gonna ask, what's the wieght savings? Are they made of aluminium?
Old Oct 31, 2006 | 10:34 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
I'm doing the c5/c6 swap in feb. I'll let you know what difference there is
Old Oct 31, 2006 | 11:09 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Not sure, but they look sweet
Old Oct 31, 2006 | 12:58 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Aren't you puting on 18's? Those little discs will look funny behind those wheels (like mine).
Old Oct 31, 2006 | 01:17 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
I actually think I will be doing 17's again. The zr1's
Old Oct 31, 2006 | 02:43 PM
Car: '89 GTA
18's aren't that great for racing.
Are you getting the red calipers as pictured, front/back?
I was going to get the silver/clear ones, they do look nice.
My slotted rotors look good, but I definitely need new calipers.
Old Oct 31, 2006 | 03:01 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
I will probably get the clear coated ones. At the time, didn't realize the red powdercoat was extra.
Old Oct 31, 2006 | 11:44 PM
Car: 07 Silverado
Yes, they are aluminum by the way, so some weight savings, some is better then none.
No matter what size wheel they will look sick I think, with the combo of nice looking calipers and slotted rotors it's going to look nice. Go for the red already done powder coated ones bish. You could always have them done later I guess but it's never the same from the factory, besides the red will match the car. Just save the extra money and do it.
Old Nov 1, 2006 | 12:02 AM
  #42
Car: '89 GTA
Yeah that's what I was thinking, the red would match.
C'mon high roller, don't skimp out now.
You lose all my rotors and getting slotted now?
I got my slotted ones off eBay for a steal if you are looking.
GTO/3rd gen progress Will?
Old Nov 1, 2006 | 12:20 AM
  #43
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
What if I don't want red :P
Old Nov 1, 2006 | 11:53 AM
  #44
porkyzilla's Avatar
Engine: 5.7tpi 350,
what happened to a stock looking iroc on the outside?
Old Nov 1, 2006 | 12:31 PM
  #45
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
I decided I want a weight loss over looks. Hey theirs nothing wrong with changing directions.
Old Nov 1, 2006 | 12:57 PM
  #46
carguy502's Avatar
Car: 1969 Nova
Engine: LT4 Hot Cam L98
Axle/Gears: 3.42 8.5" 10 bolt
Tatsefully moded is not a bad way to go, just don't do the powdercoating. bare/clear anodized aluminim is so hot.
Old Nov 8, 2006 | 01:03 AM
  #47
Car: 07 Silverado
Sorry, I totally disagree. Go for the red powdercoat, and get it done from SSBC, or don't do it at all. I still think even with the wheels you want Travis, the red will look sick, black and red go together good and it will look agressive in my opinion.
Old Nov 9, 2006 | 01:23 AM
  #48
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Enough about the color. How much wieght savings with the brake upgrade and the k member/a arms? I want Lbs!!!! I'd also like to go with aluminum heads and block if I can afford it. Anyone know what the difference in wieght between the T-5 and 700R4 is? Also, how tuff to smog a 5.7 with a T-5? Anyone done this yet in CA? Could someone ask Beanie?
Old Nov 9, 2006 | 12:41 PM
  #49
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
Daniel...Smog guys around here don't care about the trans.. Trust me.
Old Nov 11, 2006 | 10:37 AM
  #50
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
I was told I might have to burn a chip that tells my computer I have a manual trans.? Can you ask your smog guy if there's a difference?
BAMiller
Sep 14, 2015 06:38 PM
angel2794
Sep 8, 2015 06:22 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
g.l.mos
Aug 22, 2015 12:02 AM
mustangman65_79
Aug 11, 2015 03:17 PM
