Northern California Discussion board for Northern and Central California.
Flexplate
Old Jan 28, 2007 | 05:46 PM
G-Ride14's Avatar
Car: 1988 GTA
Transmission: 700-R4
Axle/Gears: 9-Bolt 3.27
Flexplate
My starter went out on the gta, so I bought a GMPP mini-starter from summit and in the process of taking it out I looked at the flexplate and saw that most of the teeth on one side were all chewed up. So now I need a new flexplate but I don't know what size to get a 153 or a 168 tooth?
Old Jan 28, 2007 | 07:16 PM
G-Ride14's Avatar
Car: 1988 GTA
Did some research and I'm going to get a 153 tooth flexplate but I'm wondering if a 3000 stall converter is too much for my car? With having to change the flexplate I figured I would change out the converter and rebuild the tranny.
Old Jan 28, 2007 | 08:47 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
I thought you were selling your GTA, no?
Here's a quick read for you in regards to selecting a torque converter since you're doing some research.
Not sure if you know how they work and it's always good to know what you're buying instead of just slapping something in because it's "bigger".
http://www.hardtail.com/techtips/sel...converter.html
Note the guidelines at the bottom.
1. Your peak torque on a stock TPI is around 3200rpm, so choose accordingly.
4. Get a tranny cooler if you're going bigger.
Hope that helps.
Old Jan 28, 2007 | 09:07 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
If your motor is stock I would say that 3k is probably a bit much. You shouls also get a transmission cooler as Del said!!!
Old Jan 29, 2007 | 01:05 PM
G-Ride14's Avatar
Car: 1988 GTA
I was going to sell it and get a new car but payments would have been too much so im just going to keep it for a while. Thanks for the info that was exactly what I needed to know. I'll probley order the parts this week i'll post pics to keep you guys updated.
Old Jan 30, 2007 | 12:51 PM
G-Ride14's Avatar
Car: 1988 GTA
I found the stall speed i need for car my car but i don't know what brand to go with. I don't want to spend the money on a weak converter.
Old Jan 30, 2007 | 02:15 PM
Comp788's Avatar
What were you looking at?
Just remember you get what you pay for.
Old Jan 30, 2007 | 10:13 PM
1TUF92Z's Avatar
Car: 92Z28,91Z28,91Z281LE,95ZR-1,08Z06
Engine: 406, 350, 305, 350, 427
Transmission: auto, auto, 5-speed, 6spd, 6 spd
Axle/Gears: all stock
TCI, B&M and SLP are always a good choice.
Old Jan 30, 2007 | 11:47 PM
G-Ride14's Avatar
Car: 1988 GTA
I was looking at the b&m with a 2000 stall speed but when I look at what other people say on this board they say the b&m and tci converters are crap but i've always liked b&m's products.
Old Jan 31, 2007 | 05:17 AM
3.492rs's Avatar
Car: 89 IROCZ
Engine: L98 4150 carb
Transmission: Transgo 700-r4
Axle/Gears: 10 bolt/3.23
if ur planning on buying a b&m holeshot convertor there over $300 u might as well look into this guys built 700r4 that already comes with a stall and shift kit
https://www.thirdgen.org/forums/west...ilt-700r4.html
Old Jan 31, 2007 | 10:15 AM
Comp788's Avatar
That looks like a pretty good deal to me.
84LsxZ28
May 17, 2020 02:21 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Stangski09
Nov 14, 2015 01:27 PM
roysatikas
Sep 22, 2015 08:15 PM
roysatikas
Sep 7, 2015 08:08 PM
